Old 02-10-2007, 11:27 AM   #346
2dumbnotto
Oddometer: 464
Originally Posted by Zapp22
hey gang
what brushbusters do you use with stock bars??
Check out Cycra. The bend to them is unique and seem to offer more room for the old dick beaters. I replaced my acerbis rally pros with them and love them.
You're born completly free, give up half of it, and wave a flag about it.
2dumbnotto is offline   Reply With Quote
Old 02-11-2007, 11:41 AM   #347
Miguel
off road junkie
Miguel's Avatar
Oddometer: 590
Dual sport kit ??? (yes I've done a search)
I'm at the point of ordering a D/S kit for the XRR. It's down to Baja Designs vs. Trick Dual Sport. They each have their strong points. Has anyone with the Baja Designs kit found problems with the components behind the headlight shroud being exposed to the elements? With the Trick D/S kit, will the UFO integrated signal/tailight hold up to the XRR vibes without a subframe? Would the "Dirt Bagz" fender brace fix that? Thanks for input.
"If everything seems under control, you're just not going fast enough." - Mario Andretti -
"I reject your reality and substitute my own." - Adam Savage -
2009 KTM 990 Adventure R
http://www.advancedridertraining.ca/
Miguel is offline   Reply With Quote
Old 02-11-2007, 11:54 AM   #348
Mudshark
Ride Addict
Mudshark's Avatar
Oddometer: 48
I've had the BD DSK on my XRR for just over a year now. It's been exposed to all
sorts of weather and high pressure cleaning... it's great, no problems.
I wasn't born in Texas,
but I got here as fast as I could.
Mudshark is offline   Reply With Quote
Old 02-11-2007, 01:40 PM   #349
Miguel
off road junkie
Miguel's Avatar
Oddometer: 590
Thanks Mudshark. What did you do with your stator when you put on the d/s kit?
Old 02-11-2007, 01:51 PM   #350
Mudshark
Ride Addict
Mudshark's Avatar
Oddometer: 48
I went ahead and got the one from Ricky Stator. It bolts right in and hooks
up perfectly.
I got the extra Headlight relay form BD as well and run the "main" lights off
the one 100watt coil in AC, using the stock regulator.
The other 100watt coil is used the run the charging system that takes care
of the brake lights, turn signals, running lights and horn.
This makes it 100% street legal.
BD and Ricky Stator will provide you with really good diagrams to get it all
set up.
Old 02-11-2007, 08:51 PM   #351
GuinnesS
GuinnesS's Avatar
Oddometer: 785
Question for you fellars with the acerbis sahara tank. How is it holding up to to your wipe outs, does the tank push on the radiators in any way and if so what have you done to protect the rads? I read over on the HUBB that some had a concern on this issue. I have the tank waiting but the bike has yet to show up . I want to take care of this fix if needed
Cheers
Other rides; 6'0" Mini Driver, 5'10 Dominator, 6'0" HellFire,5'6" Tomo Vader,6'1 Hashtag and a 9'6" Model T
GuinnesS is offline   Reply With Quote
Old 02-12-2007, 07:01 AM   #352
Red_Chili
Fresh Ground
Red_Chili's Avatar
Oddometer: 2,077
Gaspipe fabricated a brace for the lower part of the tank to the downtube of the frame that works well. Should be able to search for it.
-Bill
'06 Buell Ulysses 'Odysseus' a.k.a. 'Ody', '00 XR650R plated & farkled- 'Nuclear Thunderpig'
'06 PS1000LE Paul Smart. One cannot do without a Duc or two.
'97 KDX 220 for woods work
SMUGMUG COUPON RSKbiM6oytjtw, save some money and have a great online picture gallery!
Red_Chili is offline   Reply With Quote
Old 02-12-2007, 11:10 AM   #353
GuinnesS
GuinnesS's Avatar
Oddometer: 785
Will do
Cheers
Old 02-12-2007, 12:28 PM   #354
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,485
The newer Acerbis 6 gal come with brackets that reonforce the lower edge of the tank.
Old 02-14-2007, 09:51 PM   #355
APG
Oddometer: 10
xr650r adventure conversions
If anyones intersted, I've got some pics of my XR650r bought in greece, already street legalized (they are street legalized in Italy by a company called Dallara, and appear identical to australian spec xr650rs) w/ staintune headers and exhaust and an interesting australian 25 litre tank, and other mods, but apparently my photos are too big to upload. the photos I see on the site seem pretty detailed. am I missing something? Tx
APG is offline   Reply With Quote
Old 02-14-2007, 11:10 PM   #356
GuinnesS
GuinnesS's Avatar
Oddometer: 785
Try Smugmug.com
Old 02-15-2007, 01:03 AM   #357
mattybag
Parrothead/Singlespeeder
mattybag's Avatar
Oddometer: 89
Precision Concepts makes a brace that support the tank right down to the top bolts for the skid plates, which is what I use. I think they're a good combination of radiator support and allowing the tank to flex without puncturing. It's the same brace that Johnny used with the Sahara tank when he ran the Dakar in 2000.
Matt
"we never failed to fail, it was the easiest thing to do."
mattybag is offline   Reply With Quote
Old 02-15-2007, 01:12 AM   #358
Curvesurfer
Oddometer: 387
hey you guys who have a GPS mounted to your XRs....how are you powering them?
Curvesurfer is offline   Reply With Quote
Old 02-15-2007, 05:06 AM   #359
swinterc
clotheslinetinyhomes
Oddometer: 233
For my garmin 2730 I bought the hard wire kit for it, from tourtech.
swinterc is offline   Reply With Quote
Old 02-15-2007, 07:17 AM   #360
Red_Chili
Fresh Ground
Red_Chili's Avatar
Oddometer: 2,077
I haven't gotten around to getting a ram mount yet, but I pigtailed 12VDC off of the Baja Designs wiring behind the headlight. Good to go, especially since that side of the stator is powering only LEDs and turnsignals right now. Should be good for an electric vest too, if needed.
-Bill
Times are GMT -7.   It's 07:29 PM.
