Old 01-09-2009, 07:47 AM   #1276
MARLAN TOUCHSTONE
Oddometer: 21
Question
Originally Posted by DualSport650
My Honda XR650R Mega-Dualsport:
Big Red Pigs do FLY (kind of)...
This is a great bike! I wanted a super-powerful and very reliable big-bore thumper to use as my primary motorcycle and dualsport bike. I almost bought a KTM 525 or a Husqvarna TC 510, but I went with the Honda XR becuase of their stellar reputation for reliability.
I'm glad I did. This bike is super fun and fast. It has tons of torque and big power throughout the revs. At about 300 pounds it's not light, but way lighter than a Honda XR650L or similar box-stock dualsport.
The best part about it really is that I can ride it anywhere - down to the local 711 for a 6 pack of beer, or dualsport 150 miles from my home in Bend, Oregon all the way down to Diamond Lake - like we did on our Oregon Backcountry Discovery Route Ride in August of 2006. Heck, I even race it with blinkers on! See my Virginia City Grand Prix race report.
Here is my list of modifications to my Honda XR650R:
EBC oversized front brake rotor - this is the best mod so far - it allows me to haul the beast down from speed with just 1 finger.
Uncorked - removed airbox snorkel, drilled holes in the airbox cover, UNI filter, etc, etc.
Full Yoshimura RS3 Exhaust - actually the header is an FMF High-Flo - it works with the Yosh since Yosh doesn't make a header for the XR650R. This really wakes the bike up and makes it flat out haul booty... but it's LOUD! They make a quiet insert (called a "TEC Kit" but that makes the bike run really bad. Basically it's like sticking a potato in your muffler. LAME! So, I compromised and had a custom stainless steel turn-down tip fabricated at the local auto exhaust shop. This gives me the best of both worlds - I can run it wide open to get all the power - but the turn-down tip quiets it down a lot and points the noise at the ground so it doesn't echo across the valley's and into the local nature-nazi's ears. All good!
Hotcams Stage 1 cam - this mod combined with the Yoshimura muffer and FMF header gives the bike way more power in the mid to high rpms. It takes just a little off the bottom torque, but it more than adds up for it by giving the bike huge power from mid to high rpms. In other words, when you grab the throttle and go through the gears you're up to 80 MPH really fast! (if you want to go that fast). Just make sure you're not pointed at a tree or anything.
Other Mods - Baja Designs dualsport kit, Enduro Engineering bark busters, radiator guards, Baja Designs soft tall seat by Guts Racing, steel sub-frame extension by Dirt Bagz, LED rear brake light and rear blinkers, etc., etc.
I would like my 650r to have the power band a little more towards the top than what it has on bottom .I HAVE A YOSI TIT CAN AND WANT A HEADER I THINK I WOULD PUT A STAGE 1 CAM IN BUT IS IT TO MUCH TROUBLE WITH OUT A OVERHALL OR IS IT?????
MARLAN TOUCHSTONE is offline   Reply With Quote
Old 01-09-2009, 08:03 AM   #1277
brad21
Farting in a Fan
brad21's Avatar
Oddometer: 3,605
If you need more power towards the top you're already going too fast!
101 mph across a dry lake out of my '00 stocker with 15/47 gearing, piped and jetted.
2k4 Wee-Strom, black, farkled, smells like bacon.
Use this code when opening a Smugmug account and get $5 off! HkVR4XuSGKW46
brad21 is offline   Reply With Quote
Old 01-09-2009, 07:15 PM   #1278
JESSEJAMES
vanilla gorilla
JESSEJAMES's Avatar
Oddometer: 385
Hey Ken.
I sent you a PM a couple days ago. I need to get a faring set up from you for my XR650.
please let me know if you are still making them.
thank you
Jesse James
Originally Posted by kenaroo
AJ.. make sure your fiberglass guy makes a good production mold for your fairing..
mine is over 1/2" thick so I can pull a lot of units out of the mold..
it will save you in the long run.. especially if you keep on hitting trees with your fairing.. you can get you guy to just run another unit..
JESSEJAMES is offline   Reply With Quote
Old 01-09-2009, 07:58 PM   #1279
badcooky
I see dumb people!
badcooky's Avatar
Oddometer: 1,129
OK the creamic coating Marlon,someone will do it,i think it may be called jet coating by one company in the states.
Stage 1 is good stage 2 is more better,for me that is.
Marlon if you put a set of free flowing headers on it'll go better from the mid onwards should improve the top a bit.
An early XR400 CDI keeps the bottom end strong as it's got an extra 2 degrees of advance at idle it will also rev higher by about 1200 revs or so.
The mighty XR650R.
The old trail bike that all modern trail bikes are judged by.
It's funny cause it's true!.
badcooky is offline   Reply With Quote
Old 01-10-2009, 04:18 AM   #1280
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,095
Just updated my Cyra Guards with built in LED turn signals to clean up the front end of my BRP.
I did up a "How To" article on it: HERE
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 01-10-2009, 06:20 AM   #1281
header
Chris
header's Avatar
Oddometer: 1,746
Hodakaguy
Really nice install, it makes the front end look cleaner. I think I might do that over some snowy days.
Have you had any chance to ride at all? Im stuck in cold weather and ice. sucks... I did get a new seat for the bike and ordered new tires. Ill have to get pics up tomorrow.
KTM 530exc
525exc refresh
header is offline   Reply With Quote
Old 01-12-2009, 03:47 PM   #1282
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,095
My latest mod.....I added a switch assy/clamp unit from Highway Dirt Bikes, this unit is slick! If you've added a KTM radiator fan to your BRP this is a great way to control it. I have my headlight wired to the top switch and the fan on the bottom switch.
I posted a few more pics of the unit here: http://www.advrider.com/forums/showthread.php?t=423075
Hodakaguy
Old 01-12-2009, 03:51 PM   #1283
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
Has anyone used the XR400 CDI for an extended period?
1200 revs extra on top is alot for a big 650. Held at that for extended periods couldnt be good, but for short blasts i suppose its alright.
Though we are tempted to hold it wide open for long periods on the open stuff
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 01-12-2009, 04:52 PM   #1284
badcooky
I see dumb people!
badcooky's Avatar
Oddometer: 1,129
Jake i've had the XR400 CDI in for a while.About a year or more can't really remember.
It's no problem as the Xr is so overbuilt it's not funny.
They (Honda) learned with the old XR600 that if it made too much power that things go wrong ,like splitting the cases apart on the XR680RN race bike and the like.
The XR650R has a lot left,if it wasn't happy at 9+k it would vibrate and it wouldn't make power but it's still smooth and pumping ponies.
Team Honda also have said there's a lot left if they end up in a HP war.
Shoot man it's a Honda! Reliability is first.
I bought a 2nd hand Xr400 CDI for a hundred bucks Aussie,i rode with the stock CDI on me for a while untill i just forgot about it and left it home.
And really there's not a lot of places on dirt you will keep it pinned in top cog bouncing off the rev limiter for extended periods,i do it but at 15/45 it's a very very real experience.
The mighty XR650R.
Old 01-12-2009, 05:08 PM   #1285
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
Guess i'm used to owning KTMs and concerned of these things
Might have to pick up an XR400 CDI methinks.
I'm also trying to decide between switching gearing between
13/45 - 16/45
or
13/48 - 16/48
Switching the gearing on these bikes is a no problem, as i like riding difficult stuff sometimes, the taller gearing has me strugging, and i still like the tall gearing for long open hauls and save oil consumption.
These bikes seem to drink the oil when kept at high revs for long periods
Old 01-12-2009, 05:14 PM   #1286
badcooky
I see dumb people!
badcooky's Avatar
Oddometer: 1,129
Jake go to www.hondaredriders.com then click the inside line go to article 57(?) in the archive.
At 15/45 i can climb hills that the lads on MX'ers can't get up.
The mighty XR650R.
Old 01-12-2009, 05:44 PM   #1287
brad21
Farting in a Fan
brad21's Avatar
Oddometer: 3,605
15/47 here.... good compromise
Old 01-16-2009, 12:44 AM   #1288
Iceveign
Iceveign's Avatar
Oddometer: 124
Could you guys answer a few questions for me please regarding the XR650R?
1. what is the best and worst case scenario for mpg with this bike?
2. after the most common mods/ including larger tank, what can I expect the weight to be?
3. What is the maintenance interval for oil changes(not living in a sandy desert area).
These seem to be the most important factors for me, as I'm still trying to figure out what to get. Man, the more I read and research DS bikes the more I change my mind, but currently the XR650R, DR650, and the WR250R all have something I like.
Iceveign is offline   Reply With Quote
Old 01-16-2009, 12:54 AM   #1289
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,752
According to the manual, the oil change interval is 600 miles. I was extending it out to 1000, using the honda oil. I did a couple of oil sample tests, and my main problem was my float level, which still isn't sorted out. There was too much fuel in the oil.
I was getting 30-35 mpg.
Haven't weighed it.
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is online now   Reply With Quote
Old 01-16-2009, 10:46 PM   #1290
Iceveign
Iceveign's Avatar
Oddometer: 124
Thanks for the replies, 30-45 mpg, I was hoping for a little better, no wonder a larger tank is a must with this bike. Service interval is not what I'm looking for unfortunately, oh well. The torque, kick start, no battery and weight for a bike this size is what draws me to it, it would make a great second bike for me.Thanks again for the info.
Times are GMT -7.   It's 03:13 PM.
