Old 06-18-2006, 04:30 AM   #31
Bernd Bauer
Bernd Bauer's Avatar
Oddometer: 84
Originally Posted by datchew
Very nice. How did you attach the second rotor?
you only have to replace the original M10x100 bolts with slightly longer once.
I have used M10x105. Just make sure that the new bolts have the same strength as the old ones.
But it could be that the original bolts will be just fine, because this is depending
on the disks you are using and if you are using any spacers between the
disks ond the hub.
I am using K75 disks and with the 48mm Brembo calipers I had to use one
spacer (the 0,8mm spacer from BMW) on each side in order to have the
calipers centered.
With the 4-pot Brembos I had to remove the spacers again and now I could
propably reuse the old bolts again.
I think I forgot to mention that the left caliper is connected to the right one
with the brake tube from the R100R. So you don't need to buy an extra brake line.
Regards
Bernd
Bernd Bauer is offline   Reply With Quote
Old 06-18-2006, 01:18 PM   #32
R-dubb
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,831
disks ond the hub.
calipers centered.
Regards
Bernd
This is great info. I have an extra caliper and two rotors from the K75. Since my bike has the HPN fork with mounts on both legs, I'll only need to add a bracket, the crossover tube and perhaps some spacers. Thanks for posting!
-dubb
R-dubb is offline   Reply With Quote
Old 06-18-2006, 02:37 PM   #33
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Well, I think i found the brake upgrade I'm looking for.
I'll just have to start shopping for parts and save up.
Thanks much for the good information.
datchew is offline   Reply With Quote
Old 06-18-2006, 03:19 PM   #34
Spanish Bob
I dont know where I am.
Spanish Bob's Avatar
Oddometer: 2,081
disks ond the hub.
calipers centered.
Regards
Bernd
Bernd
do you know of shops other than wudo that sell the fork leg modified?
bob
Spanish Bob is offline   Reply With Quote
Old 06-19-2006, 10:29 AM   #35
Bernd Bauer
Oddometer: 84
Originally Posted by Spanish Bob
Bernd
bob
Hi Bob,
you can try BMW used parts dealers. At least here in Germany they know
this modification and some offer used fork legs which are already changed.
(e.g. Boxer Shop Krefeld but I don't know if they speak english)
But I would recommend just to buy the parts and have them modified by someone local.
It is really no rocket science and the left fork slider can be used as a template.
Regards
Bernd
Old 02-04-2008, 08:16 AM   #36
midnightrider
Covert Traveler
midnightrider's Avatar
Oddometer: 21
Question R100GS Stainless Replacement Rotor
I read somewhere about a replacement stainless rotor and I can't seem to find it. I need a new rotor for the front of my 95 R100GS but don't have the money for a M.A.P. upgrade.
midnightrider is offline   Reply With Quote
Old 02-04-2008, 10:01 AM   #37
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,453
I did the old-to-new Brembo swap. It's the same caliper as on my R1100S (left side), but I got mine from a K-bike.
See some info here: shave a caliper
Rapid Dog is offline   Reply With Quote
Old 02-04-2008, 10:07 AM   #38
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,453
EBC stuff
By the way, if you call cyclebrakes.com
and mention ADVRider they'll give you a discount. I got an EBC rotor and pads a while back. Very nice hardware...
I'd get the steel brake line while your spendin'' yer hard-earned cash...all available from them.
Old 02-04-2008, 10:08 AM   #39
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,822
Not mine, from www.ibmwr.org
GSPD rear shock and floater rotor
From a '93 GSPD I have a rear shock. Lower bore was cracked and weld repair carried out which has held up well for a further 20k kms until I replaced it with an Ohlins. Shock has a total of about 40k kms. See pics at my smugmug link. Also a floating front rotor from the same bike minus the carrier. This rotor is straight and measures 5mm thickness. See pic at link. Price is $40 for each plus shipping.
Price: $40 each
See more at http://gspd750.smugmug.com/gallery/477816#243433385
Contact Wayne Fedorchuk at <wfedorch@telusplanet.net>
Telephone 403 275-9360
Posted Saturday, January 26, 2008 at 15:51:22 (EST)
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 05-14-2013, 01:16 PM   #40
johnalex
Rider of rides.
johnalex's Avatar
Location: Los Angeles, CA, USA l Todos Santos, BCS, Mexico
Oddometer: 52
Originally Posted by jellycow View Post
Okay, to bad these sites are in German but have a look at the pictures
http://http://www.powerboxer.de/inde...162&Itemid=145
They use the leftside pot of a r100r, which is the same as most brembo 4 pots, eighter 2V-R, K of 4V-R.
Take a look at ther picture #2 showing how the disk will not be aligned with the pot, some machining has to be done... A good solution for this is upgrading the disk to a HE one, http:/http://www.he-motorradtechnik.de/
(Look under BREMSE, scroll a bit to the first one you see, it's on a GS) they are 320mm and add a lot of stopping power to the standard pot as well. These disks come with a large spacer to fit between the wheel and the disk itself, if you take of 4.5 - 5 mm from this spacer it'll will fit without having to destroy eighter your fork-leg or the pot itself.
I use this combination and am very happy about it There is no need to change the master cylinder as far as I'm concerned.
clement
http://www.powerboxer.de/bremsen/127...en-bremssattel
Is a new master cylinder needed? No one seems to mention one. Not necessary?
JohnA in LA
85 RZ500 - Tricked out
00 Pegaso - SOLD - 01 RSVR - SOLD
98 VFR - 133,000 miles
89 BMW R100GS - in Mexico
johnalex screwed with this post 05-14-2013 at 01:19 PM Reason: Is a new master cylinder needed?
johnalex is offline   Reply With Quote
Old 05-14-2013, 01:28 PM   #41
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,453
...I used the stock mastercylinder. Worked fine.
Times are GMT -7.   It's 05:59 AM.
