Old 02-13-2010, 02:58 PM   #1501
Bok Befok
Bok Befok's Avatar
Oddometer: 319
Puke
Originally Posted by Wacky Joe
Woody wheels between a 06 KTM 950 and 07 KTM990(ABS). Is the hubs the same. will the 06 wheels fit the 07 with ABS. I know i need to change the rotors. Is everything else the same?
Appreciate your help
Bok Befok is offline   Reply With Quote
Old 02-13-2010, 03:15 PM   #1502
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,426
fine tuning an F800GS transformation
Originally Posted by Gangplank
Ok, so I am clear on price here.
Front: Go it. I'd go to the 1.85 x 21 rim & reuse my hub. So price = either $270 for rim if I use my spokes and lace pattern or $400 to upgrade to superlace and SSS spokes and nipples. Right? Other options between? Recommendation for a 60/40 road/street rider. Thinking the $270 is good for me here. the other option is to go with a 2.50x19,,which will work REALLY well on road and is still more than doable on your fire-roads,,,,circa $410with upgrade to ss spokes n nipples/superlace..AND for an extra $99 can be sealed....now you are in the bailiwick of the most common dual sport rim/wheel n tire combination around,,you 'll have a plethora of dual-sport tires to choose from,,,braking improved and lowers seat heigght 1/2 inchall around street riding will be a JOY
Rear: Just to clarify here - Is the $99 to convert my rear rim to tubless?
Is that sealing my nipples and if so is it study enough for off road?
Or is that an 18" rim too?...i can tell you are an optimist
If no, then how much for the 18" rim laced onto my hub -circa $400
keep in mind I'd still want it tubless no problem add $99
and which option is better or worse?well,,,you are at the crossroads of trading off over here,,,if ya want tubeless you can't use rim locks and really low tire pressures and vice /versa,,,most people opt for tubeless over super low tire pressures that necessitate the need for rim-locks
PS..if ya go with a 19''up front ,,,you could just stay with your 17 rear,,get it trued up circa $55 and seal it for $99.... doing a 60/40 ride split would work with this provided the 40 is geared to fire-roads...remember people take their 19/17 oem shod wheels in the roughest of terrain..ya just can't go too fast!!!
woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 02-14-2010, 02:54 PM   #1503
BigM
Hello :-)
Oddometer: 766
A Woodies Wheel.
2.5 Inch Excel Rim
RAD Cush Hub
5mm SS Spokes
SS Nipples
Michelin Desert Tyre
Rim Lock
Ultra Heavy Duty Tube
Weights 15KG
Solid as a rock.
KTM 2006 625 SXC
Leo Vince X3 Pipe, Scotts Steering Dampner, Woody's Rear Wheel + Cush Hub, Race Tech Gold Suspension, 18L Tank, Bark busters, Trail Tech SCMR16 HID Helmet Mount, Comfort Seat, Bark Busters, Stealth Sproket, Trail Tech X2, Michelin Desert
Cedo Nulli
BigM is offline   Reply With Quote
Old 02-18-2010, 01:19 PM   #1504
nytrashman
old and in the way
Oddometer: 586
got the wheels for my F650GS back today and they look fantastic. i'll put them on the bike tomorrow and post a pic or two. thanks Woody, Zack (not Jack) & Jill.
George
nytrashman is offline   Reply With Quote
Old 02-18-2010, 05:05 PM   #1505
SCflyer
SCflyer's Avatar
Oddometer: 1,634
Ditto - Will get pics up when I get my set of silver Excels mounted up on the X Challenge.
Thanks all!
SCflyer is offline   Reply With Quote
Old 02-18-2010, 08:25 PM   #1506
Billd
Billd's Avatar
Oddometer: 37
Moto Guzzi Stelvio 4-1/4" rear rim
Really like the Stelvio but it's rear rim is 5-1/2"'s wide and could not get a good gravel road tire on it. Sent it off to Woody's to get a 4-1/4" installed. Talked to Zack today, it's quite a process. Custom drilled Excel 36 spoke rim, special ordered spokes because of hub spoke angle and on top of it all they have to anodize the rim black. Super lace, all SS spokes and nipples and a seal job. All for under $700.00. These guys are the best man! Will post pictures when I get it back wearing a TKC 80
Billd is offline   Reply With Quote
Old 02-19-2010, 12:42 PM   #1507
nytrashman
old and in the way
Oddometer: 586
a couple pics of my woodys
thanks again to woody, zack & jill
Old 02-21-2010, 03:26 PM   #1508
alfaris
MOTERO TORERO
alfaris's Avatar
Oddometer: 1,154
Hi Woody
Regarding the MEGAMOTO. in order to not damage the precious stock blue cast wheels when riding some dirt ..
I am looking for:
A front 17" black tubeless spoked rim that allows to fit on the hub two 320 discs. and that leaves space to the 4 piston stock calipers.
Could you use the rim and spokes from the BMW supermoto front 17" wheel for the HP2 Enduro?
I am asking this to optimize costs in case of buying a BMW SuperMoto set for the HP2 enduro. As soon as i am planning to use a rear 17" black tubeless spoked wheel for the HP2 Enduro that allows up to 160 rear tire.
If not possible to use the HP2 Enduro supermoto front rim, would you use a GS1200 front spoked hub taken from its 19" stock wheel?
then i will use a rear 17" tubeless spoked wheel coming from a GS1200.
this setup will use avon distanzia 120/70/17 tires ..rear 160/60/17, do not need wider rear rim for a 180.
Thank you very much.
Remember my invitation to Spain still stands
09 KTM 530 EXC
07 XR650R
alfaris is offline   Reply With Quote
Old 02-23-2010, 07:24 PM   #1509
Built to Last
Oddometer: 3,426
alternative solutions using 17' wire wheel s instead of mags for the bmw Megamoto
Originally Posted by alfaris
Hi Woody
I am looking for:
A front 17" black tubeless spoked rim that allows to fit on the hub two 320 discs. and that leaves space to the 4 piston stock calipers.no problem,,we have 3 choices
Could you use the rim and spokes from the BMW supermoto front 17" wheel for the HP2 Enduro?yes if we use any oem hub off a R1200GS or GSA,,,you will need a set of adapter nipples,,,a better stronger more aesthetic alternative would be to use a set of my Monzter spokes and redrill the rim accordingly,,,it can be sealed for tubeless too
then i will use a rear 17" tubeless spoked wheel coming from a GS1200.FYI there are no 3.5x17 front bmw rims available,,,, the closest i can do is use the 2.5x17 rim bmw uses on the back of the r100GS/PD or HP2..you would be better to use the larger2.5x18 or even 19 on the front for a nicer street ride....these i can x-lace tubeless and re-anodize to match an oem black 4x17 that comes with the sumo kit[FYI it's the same as rear R1200GSA] you must know this rim is optimal for the 150/70x17 tire size or a 160/80x17..the 160/60 or 70x17 need a wider 5-5.5 rim width check this chart
http://www.woodyswheelworks.com/rim_and_tire.htm
woody
woody's wheel works screwed with this post 02-24-2010 at 08:06 PM
Old 02-24-2010, 12:03 PM   #1510
alfaris
MOTERO TORERO
alfaris's Avatar
Oddometer: 1,154
Originally Posted by woody's wheel works
woody
Thank you for the answer Woody,
Ill think on the right combo for my ride, then ill go back to you with measures and details so we can order it.
Cheers
09 KTM 530 EXC
07 XR650R
Old 02-25-2010, 02:03 PM   #1511
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,483
Question Dingit!
Hey Woody,
These are new wheels on the same bike, can these be fixed or need to be replaced?
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 02-27-2010, 07:04 AM   #1512
kkesp
UPSIDERIGHT
Oddometer: 226
Woody
I'm going to do a 18" rear conversion on my F800GS. You recommended a 2.5" width. I'm going to want to use a more road oriented tire 80% of the time. What would be the largest size I could use easily on the 2.5" rim. I was thinking a 3.5 would be better for me to running a 140/80. Thoughts?
"Political Correctness is a doctrine fostered by a delusional illogical minority, and rapidly promoted by an unscrupulous main- stream media which holds forth the proposition that it isentirely possible to pick up a turd by the clean end."
kkesp is offline   Reply With Quote
Old 02-27-2010, 10:03 AM   #1513
Built to Last
Oddometer: 3,426
straightening bent rims..95% success rate....
well Rapid Dog if anyone has taken on stuff like this and made it usable again your're talking to him,,,,
are those Dirt-Stars???,,7000 series is tougher than the 6000series to straighten,,the rim need to be partially unlaced in order to be able to do the straightening,,,hey ,,,its junk now so all we can do is see what happens,,if it doesn't work we do not charge,,,we'll just install another hoop new or used got everything from patching to perfection
FYI,,,those dents look like $100-120 to straighten and true..
NOTE!!!! when dented like that PLEASE do not hammer on them,,it invariably leads to the rims cracking ...thus necessitating welding etc
Originally Posted by Rapid Dog
Hey Woody,
Old 02-27-2010, 10:12 AM   #1514
Built to Last
Oddometer: 3,426
optimal rim combo for F800GS 50/50 dual sport use
the 2.5 width is optimal for mostly dirt oriented use,,with the proper tires it works finon the street,,if you're on the street more than the dirt we use a 3.5 x18..it's narrower than the 4.25 which can bend too easy sticking way out to the left/right of center-line...it works better on the the 140/70 lower profile...
remember the lower the profile the stiffer the tire will be on the road,,ie the sidewalls are almost vertical so they don't flex nor want to distort and tuck under the main thread.
herre's a tire fitment chart link to my website..peruse it and notice the correlation between aspect ratio and rim width
later,
woody
Old 02-27-2010, 11:15 AM   #1515
riceburner30281
misADVenturer
riceburner30281's Avatar
Oddometer: 647
this maybe the wrong place to ask but what sizes of tires will work on a stock 2006 KLX250s?
"I've seen the look of "Just shoot me" on the face of the poor fellow stuck in his generic sedan, wife reading People magazine, kids in the back fighting over what movie to watch on the portable DVD plaver as I pass them and we make brief eye contact. I choose not to be that person." Pluric.
http://i174.photobucket.com/albums/w...VisitedMap.jpg
riceburner30281 is offline   Reply With Quote
Times are GMT -7.   It's 12:44 AM.
