Old 03-17-2010, 05:59 AM   #1531
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
Send a message via MSN to r00t4rd3d
Will a 18inch tire fit on a 19inch wheel ?
03 Honda XR250R
r00t4rd3d is offline   Reply With Quote
Old 03-17-2010, 02:12 PM   #1532
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,095
18'' tires on 19'' wheels???? WHOA!!!!!
i don't think soooowithout getting major stretchmarks
tires have to fit on matching rims not only in diameter but also on rims with the matching /appropriate width
woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 03-17-2010, 02:17 PM   #1533
Built to Last
Oddometer: 3,095
ooops
Originally Posted by kkesp
I don't want to seem argumentative, but I recounted the spokes on my F800GS and still come up with 36. Am I missing something?
ohh lordy,,,how could i possibly....there ya go,,,aanother senior moment
folks!!!the F800GS front and rear wheels come with 35/thirty-six spokes/nipples
woody
Old 03-17-2010, 02:58 PM   #1534
kkesp
UPSIDERIGHT
Oddometer: 220
Woody
Then this Excel rim from the DRZ would lace to an F800GS Hub?
Woody, last year I had you make up a set of 19"/17" black Excel rims with the large SS spokes and nipples with black powder coated OEM hubs for a DRZ400. I sold the bike but the guy didn't want the rims. I only had them on the bike for about 500 miles of road riding and have been trying to sell them. I'm asking $900 for the set which I think is more than fair and would cover the cost of my 18x3.5 upgrade for my F800GS. My question is would the rims work for any other application? I see a lot of guys getting the Excel rims for F800GS, would these rims be able to lace to a BMW hub? If the rims would work on bikes other than just the DRZ I would have more options for a sale. The rim sizes are 19x2.5 and 17x4.25.
"Political Correctness is a doctrine fostered by a delusional illogical minority, and rapidly promoted by an unscrupulous main- stream media which holds forth the proposition that it isentirely possible to pick up a turd by the clean end."
kkesp is offline   Reply With Quote
Old 03-17-2010, 07:44 PM   #1535
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
Another tire question for a different bike , I got 100/100-18 rear tire now , I really want a Teraflex but they only come in limited sizes.110/100-18 which I know would work but the one I want is 150/90-18. What are my chances there ?
03 Honda XR250R
Old 03-18-2010, 02:11 AM   #1536
Tjakura
Tjakura
Tjakura's Avatar
Oddometer: 7
Air leak through spokes on front spoke rim
I have a slow leak in front wheel (19 inch) on GS1150 (2000 model). When I spray detergent on the rim it shows the air is leaking through the ends of 5 of the spokes.
Tyre has been removed and no damage to tyre or leaks along bead when tyre fitted. The only possible explanation seems to be the rim is double skinned and a light crack exists on the inside of the rim allowing air to move into the gap and then out through the spoke ends. Is this possible?
If so can the rim be welded? Other option is to insert a tube but this could be a hassle when repairing flats in remote locations. Any advice greatly appreciated
Tjakura
Tjakura
Tjakura is offline   Reply With Quote
Old 03-18-2010, 03:10 AM   #1537
Built to Last
Oddometer: 3,095
rim swap from DRZ to F800GS hubs
kkesp...there are 3 other factors besides having the right number of spokes that need to be considered,,,
1,,the diameter of the spoke hole pattern on the 2 hubs
2,,the width and location from centerline of the spoke holes on your hubs
3,,the indexing should be the same
so you can check this by holding the 3 wheels up against each other,,,if these 3 elements are close/match then a swap is possible,,,,FYI,if we SUPERLACED the new wheel then we'd automatically reconfigure the nipple holes provided they were close enough,,,if the indexing is different we can usually add or subtract a spoke X on one side
woody
Old 03-18-2010, 03:24 AM   #1538
Built to Last
Oddometer: 3,095
can you install a150/80x18 instead of 100/100x18??
what you need to find out first is that 150mm wide tire will fit inside the spatial area of your frame/swingarm/chain/chain-guide/fender without rubbing...then your 2.5 rim[iassume that's the rim size for an oem 100/100 tire ]would be too narrow for the 3.5 speced rim needed for the 150/90 tire
assuming the tire could fit in your space,,we could always install a wider rim for that upgrade
woody
Old 03-18-2010, 03:31 AM   #1539
Built to Last
Oddometer: 3,095
air leaking through spoke holes on GS1150 X-lace/tubeless rim???
Tjakura
Tjakura-san,,,now that's a new one!!!,,,,how about a pic or two???,,,,is it leaking out on the inner side by the spoke/rim interface,,,or on the outer diameter from under the head of the spoke....there'd have to be a crack going through the rim in that neck of the woods,,,whatever it is i am confident at finding the cause for that effect you are experiencing
woody
Old 03-19-2010, 03:59 AM   #1540
Tjakura
Tjakura
Tjakura's Avatar
Oddometer: 7
woody
Hey Woody thanks for the response. It is leaking on the outer rim diameter from under the head of the spokes, this is happening on at least 5 spoke heads. I spray detergent and bubbling shows air coming from the spoke heads and not the bead edge. I took photos but after 3 hrs of resizing and reformating pictures (using a mac so recommended pc upload sites of no use) I have run out of steam.
Tjakura
Old 03-19-2010, 06:03 AM   #1541
Built to Last
Oddometer: 3,095
just send em in and we'll figure it out
woody
Old 03-23-2010, 06:49 PM   #1542
Stovebolt
Team Ruptured Buzzard
Stovebolt's Avatar
Oddometer: 396
Plus + 1 for Woody
Gotta give Woody a prop for EXCELLENT customer service. He definitely knows his thing about wheels. And aircraft. And people. And customer service.
My project wouldn't be the same without him; can't wait to pull the trigger on it.... He'll have my order soon.
Thanks Woody
Stovey
Stovebolt
http://bustedcompass.com
http://www.spotadventures.com/user/p...?user_id=47618
"Never Give Up"
Stovebolt is offline   Reply With Quote
Old 03-24-2010, 09:20 AM   #1543
Uhuru
Wildest place I've been
Uhuru's Avatar
Oddometer: 151
Great Service
Originally Posted by Stovebolt
Gotta give Woody a prop for EXCELLENT customer service. He definitely knows his thing about wheels. And aircraft. And people. And customer service.Thanks Woody
Stovey
Second that! Zack is a great guy. He gave me good advice in going to the Supersized, Superlaced Excel rims Woody's did on my Dakar a month ago. After listening carefully to what I wanted to achieve, and where and how I usually ride (long rides on twisty, mountain tarmac) Zack recommended I go to a 19" front wheel for improved handling. I did, and absolutely LOVE it. And, I have the 21 for offroad when I feel like it.
Thanks, Zack!
Butch to gambler: "What would you think of maybe asking us to stick around? You don't have to mean it or anything."
Uhuru is offline   Reply With Quote
Old 03-24-2010, 12:27 PM   #1544
overlandr
Bend it Bend it
Oddometer: 5,433
Thanks, Zack!
+1. Getting asked the same stuff week after week requires guru like patience...
overlandr is offline   Reply With Quote
Old 03-24-2010, 02:17 PM   #1545
Built to Last
Oddometer: 3,095
thanks for the warm fuzzies
+2,3,4 etc
don't know what's cooking,,, but i've been slammed with a bunch of warm fuzzies in the last 24 hours,,,is it the planets lining up??? are the bio-rythms aligning...hey we appreciate it and continue to strive for excellence,,and we are human,, and there are days when shit happens but less and less...
woody n the gang
Times are GMT -7.   It's 05:23 PM.
