Old 02-15-2007, 10:10 PM   #211
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,431
oops sorry ,you're overseas and it's a little more difficult
Originally Posted by LuisLourenco
That's what I tried to avoid, send the rim overseas Well, perhaps the better would be send the hub, and buy you rim, spokes & lace, and try to give back the rim to local vendor, we'll see if we have not other chance. si
So, you mean that the only way is to re-angle the rim holes, isn't it?,,, si,,, on your rim we would reangle spoke holes on one side and use x3 lace pattern
Bent to your specs! It means that not only re-angle the holes you need diferent spoke angles, true? si,,one side oem holes and oem spokes the other side longer x3 spokes
It means Buchanan does not solve the way I want, being it have a set of spokes that I can lace without changing holes and bends... si that's the problem,,x3 spokes come in to the rim at a steeper angle
Rather than send you the rim, I'll try to return the rim here. good idea,,,we can send you the right drilled rim,,,but you should be able to get that in europe ????,,it needs european lace pattern/indexing
The Excel rim I have is actually a 1.85x21 bueno,,,the optimal size,,,trade it for a rim drilled just like your original rim
I understood that one side should be two-cross and the other three-cross, at least with the set of Buchanan spokes. Is there a way to have it 3x both sides? si,,,,if the drill pattern is the same as te original and the spoke holes are drilled and countersunk for the x3 lace pattern
Excuse me if I put you no-sense questions... It would be for my weak knowledge of both lacing wheels and english language...
luis,,,if you have a problem,,,,we'll just send you the rim you want and the spokes you want,,,x3 is stronger,,,then you or a professional can lace it ,,no need to send your hub over here
hope this helps,,,woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 02-16-2007, 06:36 AM   #212
LuisLourenco
Blue orange
LuisLourenco's Avatar
Oddometer: 291
Woody!
Thank you very much. You're right, it's the better. I will try to return the rim to the local vendor.
Im leaving today for Morocco, with the stock front wheel (which means that I most probably need another stock front rim upon my return ) and two weeks ahead I will contact you.
Thanks again for your help!
Luis Lourenco
'08 Blue LC8 S
'04 525 MXC
'96 Africa Twin
R3 Roadbook Rally Raid
LuisLourenco is offline   Reply With Quote
Old 02-18-2007, 04:16 PM   #213
LaOutbackTrail
Certified Smartass
LaOutbackTrail's Avatar
Oddometer: 5,058
Would you guys be able to work a set of CBR600 wheels to make some supermoto XRL wheels for me? What would be needed to do such a task? I see on Ebay (search under XR650L) there is a guy that is selling some old CBR wheels, that he machined some parts or something for....
Thanks for your help.
LaOutbackTrail is offline   Reply With Quote
Old 02-18-2007, 09:42 PM   #214
Built to Last
Oddometer: 3,431
pal i'd bid on these ...
it's not that we can't replicate this process,,,but hey bid on em,,,and if ya want a good auction sniper,,, www,snip.pl ,,the hot set-up,,we can't build em for what you may get em for,,,
Old 02-19-2007, 06:51 PM   #215
patobravo
Oddometer: 53
2007 YZ 250 rear rim on F650 front?
Hi Woody,
I bought a 19" x 2.15 used excel rim on ebay for not much and was hoping to use it to convert my '97 F650 ST's 18" front wheel to 19" so I have more DS tire options available. The rim was from a 2007 YZ 250, I have it now and it looks as though the angles that the holes are drilled through the dimples are similar to what's on the existing wheel but the diameters are larger, something around 0.340" diameter. I was wondering if you'd be a source for nipples & spokes to make this work?
FWIW, stamped on the rim is J19 x 2.15 227 403.
---Thanks!
patobravo is online now   Reply With Quote
Old 02-19-2007, 07:47 PM   #216
Built to Last
Oddometer: 3,431
no problem
Originally Posted by patobravo
Hi Woody,
---Thanks!
yes call toll free,,,we can discuss better options,,,w
Old 02-19-2007, 07:52 PM   #217
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,368
You were Right Woody you new signature is pretty nice.
congratulations.
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 02-25-2007, 03:29 AM   #218
Hollywood
Oddometer: 210
Woody -
Any experience using the Dunlop 607 front/Trailmax rear for a set of sticky street tires to be used on a set of 21"/18" wheels? Bike is a DRZ400 and I have a nice set of Excel hubs laced to Excel rims. Other option would be to relace with 17" hoops I guess but would prefer to minimize cost if decent rubber is available for 21/18 combo.
thanks -
Everybody's gotta believe in something... I believe I'll have another BEER!
Hollywood is offline   Reply With Quote
Old 02-25-2007, 07:19 AM   #219
Built to Last
Oddometer: 3,431
sorry can't help you there...
Originally Posted by Hollywood
Woody -
thanks -
i can help transform your wheels however i choose to refrain from being a tire recommender,,,tires are like women or guys,,,how they feel and respond is a rather subjective issue,,,and soooo much depends on how ya ride em
place this question in the thumper forum,,,you'll get a response,,,remember it's subjective!!!
Old 02-26-2007, 04:16 AM   #220
Hollywood
Oddometer: 210
Point taken and quite valid I might add as well. Sounds like sage advice from a seasoned businessman.
What are the costs involved with transforming this nice set of wheels into a bolt on 17" affair? As they have the proper spacers, carriers, etc, now, is it a matter of relacing 17" hoops? If so, what is the cost?
Mike
Old 02-26-2007, 07:07 AM   #221
Built to Last
Oddometer: 3,431
transorming std wheels to supermoto...
Mike
depending on bling/new/used/size rims /rim brand etc,,,,,, we can put a set together anywhere from $600-900 on your hubs,,,our preference is to start with your wheels complete,,,so we can get proper offset
Old 02-27-2007, 01:39 PM   #222
RocketJ
Oddometer: 674
Simon's Rim
Did it arrive OK, and will it work?
RocketJ is offline   Reply With Quote
Old 02-27-2007, 04:57 PM   #223
zenben
all roads are one
zenben's Avatar
Oddometer: 595
Rim availability
Does Woody's stock, or Can you guys get a Behr 4.5x17 40 rim? (for conventional spokes).
Ben
zenben is offline   Reply With Quote
Old 02-27-2007, 06:37 PM   #224
Built to Last
Oddometer: 3,431
arrived A-OK
yes,,it arrived yesterday and i will give simon credit toward a 21'',,,which IMHO may serve him better in the terrain he'll be encountering,,,should he be dissatisfied i'll build him another 19'',,,thanks for being part of the team getting him back on the road again,,,,
while we were at it we sorta did alil upgrade,,,black anodized rims,,,ss spokes,,,an bright red powdercoated hubs,,,trtrriiiiicccckkkkkk
Old 02-27-2007, 06:39 PM   #225
Built to Last
Oddometer: 3,431
rim availability,,,
Ben
i may have a 4.5 x17 floating around,,,,i do have 4.25 x17 in various configurations,,will check and report back
woody
Times are GMT -7.   It's 03:40 AM.
