12-07-2011, 02:42 PM
#2311 |
Beemerholics Anonymous
Oddometer: 7,356
I've got an akront high lipped rim set up for rim locks. It's perfect for an intended street application, but would prefer not having the extra two holes for rim locks.
Is it possible to weld them up without compromising the strength or temper? Also, I'm curious if you've ever seen any wire wheel rims fail due to having been powder coated?
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
12-07-2011, 02:49 PM
#2312 |
Oddometer: 10
I have 32000km on my F800GS and my bearings are still ok. Do you think they need to be change and my rear hub is not subject to eat the bearings and don't need modification.
thanks for the answer Woody |
12-07-2011, 04:28 PM
#2313 | |
Built to Last
Oddometer: 3,088
welding and powdercoating rims ,,does it soften em????
like i've said before,,,our preference is to anaodize any rims used for competition and hard riding...we've had no problems on any powdercoated items used for street/normal use.
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W |
12-07-2011, 04:58 PM
#2314 | |
Built to Last
Oddometer: 3,088
to change or not to change wheel bearing son F800GS???
just check em every time ya change your tires is a rough seat of the pants time schedule ![]() you can of course assist in prolonging their life by following common sense notions mentioned above AND pre-empt premature failure by packing em with high speed waterproof boat trailer bearing grease if you routinely run in wet places or like to cross deep streams and the like... ![]() later woody
12-08-2011, 01:16 AM
#2315 |
Dakar Withdrawl
2007 DL1000 wheel cost
Woody,
Spent several hours reading the last few pages on here and didn't see any mention so here goes: (search? who uses search?) I have a 2007 Suzuki DL1000 Vstrom that I am considering the wheel conversion for. One modification of note that I've done is I have a set of SV Racing Parts adapters to allow the use of 2003 (?) GSX-R 750 4-piston calipers on the front. I wasn't sure if it would cause clearance issues What would the cost be for a set of wire-spoke wheels for this bike? What I'm thinking is having a 2nd set of "off-road" wheels ( for TKC-80's in std size unless you recommend otherwise) that I'd use when I'm gonna do some exploring in Florida, and keep my stock wheels for my commute to work. Additionally if I shipped a pair of Galfer Wave Rotors to you what would it cost to check/straighten them before attaching them to the front wheel.. Thanks Dave in Dusty Doha, Qatar Deployed Gov't Contractor
Dave in Afghanistan 2011 Ride - Key West To Deadhorse - SPOTWALLA - Smugmug Photos Ned Suesse on Stage 2 of the 2012 Dakar: "You would have had to have been a blind monkey to get lost anywhere today!!" FL_biker screwed with this post 12-08-2011 at 01:30 AM |
12-08-2011, 05:18 AM
#2316 | |
Built to Last
Oddometer: 3,088
wire wheels on your DL-1000 V-Strom,,what size and can do???
![]() woody
12-08-2011, 05:50 AM
#2317 |
Built to Last
Oddometer: 3,088
950 ADV,,what's optimal street only set-up???
sstewart
Gnarly Adventurer Joined: Nov 2009 Location: Boaz,Alabama Oddometer: 439 950 ADV I have purchased another 950 ADV, I want to set it up for street only. What tire and wheel combo do you suggest? no problem ,,,,go 19/17 running 110/80x19 front and 150/70x17 rear for all around great experience,,,check this link for all the options: http://www.advrider.com/forums/showthread.php?t=439443 I would like Excel wheels with orange logos if possible? the Excel rims are no problem,,we may have a problem with the orange logos,,,silver rims come with red insignias,,black with yellow,,,FYI,,currently we have to strip and re-anodize the rims,,,[currently,there are only silver rims available,,,,although in the next bit of time i'll have factory anodized black/yellow logo rims coming my way].....perhaps some other inmate may know of orange Excel logo availability???? Would it be worth the savings to use the stock hubs and cush drive? well,,you'd save about $900 or sell the oem ones and get the stronger/beefier/bling billets.FYI,,,if ya want to go genuine tubeless,,,then the Caponord rims are the hot set-up ,,,i highly recommend using a billet hub on the rear at least with the Caponord x-laced rim [it has to do with the extra lateral forces placed on the spoke lugs,,,which is why i designed beefier lugs into the billet set-up for added ''peace of mind''] OBTW,,if ya use standard 19/17 excels ,,we can seal them for tubeless @ $99ea holler when you are ready or need more info/answers woody PS,,,hate to say this ,,BUT....if ya plan on trading your bike in to your dealer down the road,,check if he'll take your bike in with the trick wheels and hustle it as a value added feature or will only accept it with oem wheels as some inmates have reported and lamented.. ![]()
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W woody's wheel works screwed with this post 12-08-2011 at 06:45 AM |
12-08-2011, 08:12 PM
#2318 |
Dakar Withdrawl
Regarding the damper - unfortunately with the 1" up, 1" back risers I'm running (I'm only 5'4" so they were a must) I haven't found a damper that will work without some custom machining :( Also, some other questions 1) Wheel Clearance: Someone mentioned to me that the 21" wheel can cause radiator clearance issues - would there also be issues with the fender to where I'd need to fab up a high fender?2) Someone else mentioned via PM that I could go to Rad directly and save $$, and while I like saving money I'd like to give you the opportunity to tell me what added value I'd be getting from YOU that I wouldn't get from THEM in terms of service, customization or whatever else you'd bring to the table. 3) If I went with your recommended wheel sizes, what would the corresponding tire sizes be. 4) Would the recommended sizes still be tubeless? I like the ability to just plug a puncture and keep rolling after airing it up (knock on wood - in the 16,600 miles I rode in June/July I didn't have a single flat.) I'm still in the research/planning stages so it'd be months till I'd do this if I go fwd with it at all...and I'm still paying off my VISA after my Alaska trip !! Dave
Dave in Afghanistan 2011 Ride - Key West To Deadhorse - SPOTWALLA - Smugmug Photos Ned Suesse on Stage 2 of the 2012 Dakar: "You would have had to have been a blind monkey to get lost anywhere today!!" |
12-10-2011, 12:49 PM
#2319 | |
Built to Last
Oddometer: 3,088
holler when you are ready ![]() woody
12-11-2011, 02:57 AM
#2320 |
Bought a rim and some spokes from you a while ago but haven´t gotten around to lacing them until now but ran into trouble with the spokes seeing to short:
http://advrider.com/forums/showthread.php?t=472477 /Johan |
12-11-2011, 08:17 AM
#2321 | |
Built to Last
Oddometer: 3,088
spokes too short???
just checked your thread and looked at the pics,,,outside of the aesthetics of seeing threads you hav eno worries as to strength or wheel coming apart. FYI: the rule of thumb is you minimally want to have the usable minimum thread length be equal to the OD of the threads....which is why the height of a nut is normally equivalent to the OD of the bolt/screw ![]() i'll check with Zach to see what lengths he sent ya... when we Superlace our wheels we countersink the rims to achieve a perfect seat and accurate direction for the nipples,,,allowing the nipple to go in a lil bit further,,,if you look at BMW and KTM wheels the majority of them all have even more thread showing....FYI,,it certainly makes wheel lacing easier and quicker....not to mention minimizing the possibilities of scratching the rim let me know what you'd like to do skol ![]() woody
12-11-2011, 09:06 AM
#2322 |
Location: Northeast Kingdom, Vermont USA (close to Canada!)
Oddometer: 5,203
Looking to get a quote on some wheels for my X-challenge - 18/21 size, new hubs, blingtacular blue finish, excels, and super tough lacing.
Thanks - Scott |
12-13-2011, 02:20 AM
#2323 |
KTM Tragic
Oddometer: 754
G'day Woody,
You guys built some wheels for me a few years ago. I've probably put about 10,000km on them, I've noticed a crack next to one of the nipples on the rim. In a recent post you mention that you countersink the nipples when you superlace, reckon that would have contributed to this? (see pics) ![]()
12-13-2011, 06:28 AM
#2324 |
the (in)famous boxer perv
Hi Woody,
Don't know if it's been asked before, can't find any info, but can you fit R100/80GS 21" front 18" rear tubeless rims into R1100GS hubs to make true tubeless 21"/18" wheels for R1100GS??? (I don't want any superlace etc superstrong wheels, I need a true tubeless 21"/18" solution) If yes, how much it'd cost to make 'em if I send you the R1100 hubs and R80/100 rims? PS: Provided it's possible to make 'em, do you also anodize rims? (My original 19"/17" are anodized and they are a joy to clean and maintain, but I know the older (Akront?) GS rims are bastards in those terms since they corrode, so wondering if separately anadozing the rims is a solution for it) TIA, Margus (visited and used your nice workshop in 2009 during our RTW, but you were in Europe then, we even got 2 of those famous t-shirts )
12-13-2011, 07:13 AM
#2325 | |
Built to Last
Oddometer: 3,088
Superlaced wheels for BMW G650 X-challenge,,,options/$$$,,,???
If you were to send in your hubs and we laced new blue excel rims in stock sizes it would breakdown like this. Front 21 x 1.6 silver excel-138 (blue is 166) or 75 per rim to re-anodize to match Rear 18 x 2.5 silver excel-166 (blue 2.15x18 is 190) Stainless spokes/nipples-135x2=270 Superlace/true-111x2=222 New oem hubs are 325 ea. It would be $946 to re-build your hubs with stock size blue rims. $1596 if you want a whole new set. IF you have any questions, don't hesitate to contact us. thanks zach and the crew.\ PS,,and don't forget you get a www T-shirt or hat tossed into the deal.
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W woody's wheel works screwed with this post 12-13-2011 at 09:58 AM |
