Old 12-13-2011, 07:23 AM   #2326
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,431
genuine tubeless X-laced 21/18 BMW rims to R1100GS,,Possible??? ,,,$$$,,,???
Originally Posted by tsiklonaut View Post
Hi Woody,
Don't know if it's been asked before, can't find any info, but can you fit R100/80GS 21" front 18" rear tubeless rims into R1100GS hubs to make true tubeless 21"/18" wheels for R1100GS??? (I don't want any superlace etc superstrong wheels, I need a true tubeless 21"/18" solution)
If yes, how much it'd cost to make 'em if I send you the R1100 hubs and R80/100 rims?
PS: Provided it's possible to make 'em, do you also anodize rims? (My original 19"/17" are anodized and they are a joy to clean and maintain, but I know the older (Akront?) GS rims are bastards in those terms since they corrode, so wondering if separately anadozing the rims is a solution for it)
TIA,
Margus
(visited and used your nice workshop in 2009 during our RTW, but you were in Europe then, we even got 2 of those famous t-shirts )
Hi margus,
We can build up the wheels with the tubeless rims.
The front 21'' is no problem, it would be 200 for spokes and 150 for labor, if the rim is straight.
The rear r100gs is a 17'' but the R100R front uses a 2.5x18. There is no oem spokes that will work so we would need to use aftermarket Stainless spokes/nipples. WE do have to re-drill the rim/hub to make the spokes/nipples point in the right direction. The front 2.5x18 rims are drilled for the smaller hubs. It would be 200 for labor, and 200 for the spoke kit.
We can anodize or powder-coat the rims.. If it's been dinged up or oxidized it would be best to powder-coat the rims to cover the finish. Otherwise if we anodized the rims it would show all the corrosion on them.. It's 65 per rim to powder-coat most colors.
If you have any other questions, you can email us at woodyswheelworks@gmail.com
thanks zach and the crew
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 12-13-2011 at 10:03 AM
Old 12-13-2011, 08:30 AM   #2327
theturtleshead
Tits on a fish
theturtleshead's Avatar
Oddometer: 805
Norton Commando
Hey Woody!
Just bought a 1977 Commando 850 mklll down here in Colombia
What size and width of rims would you recommend for a good handling Commando!
I,d prefer handling than an original bike-I will be upgrading suspension and brakes!
Better that way here what with the drivers and the road conditions!
Cheers Al
theturtleshead is offline   Reply With Quote
Old 12-13-2011, 10:15 AM   #2328
Built to Last
Oddometer: 3,431
'77 Norton Commando better handling wheel upgrade???
Originally Posted by theturtleshead View Post
Hey Woody!
Cheers Al
hi al,,,
for all you Commando-philes ,,we 've done dozens of these upgrades especially the road racing crowd...
the most common conversion was a 2.15x18 front and 2.5x18 rear
get rid of the chrome plated discs by switching to better ones or having the discs turned/re-surfaced just enough to get rid of the chrome [circa $30 ea],,,plain cast discs work really well,,however are prone to rusting,,,,the rust of course will build up on the brake pads,,,which of course can easily be removed with a little 320 grit regular or wet/dry sand-paper
holler when you are ready
Old 12-13-2011, 10:56 AM   #2329
Built to Last
Oddometer: 3,431
2.5 x18 excel riim with cracked dimples,,,causes ???,,Rx=???
Originally Posted by 1WD View Post
G'day Woody,
You guys built some wheels for me a few years ago. I've probably put about 10,000km on them, I've noticed a crack next to one of the nipples on the rim.
In a recent post you mention that you countersink the nipples when you superlace, reckon that would have contributed to this? (see pics)
G'day mate,,,
FYI ,,,this is not the first time that we have run across this problem,,,it has been mainly confined to the 2.5x18 or 19''excel rim...the narrow nature of this extrusion and dimpling puts alot of stress in a confined space...
we have also tracked down that the majority of these incidences[3-4 at most] were exacerbated by over-tightening of the nipples by one of my overzealous technicians...he thought if tight was good, tighter would be better all these incidences stem circa 3 years ago...everyone was reminded that there are distinct parameters to abide by.and have had none fail since.
FYI,,,our countersinking is essentially confined to a slight cut that matches the exact direction of the spoke and matches the mating surface to the nipple. so IMHO,,,it hasn't ever been ascertained as the cause of the cracking...OBTW our suppliers reported that we weren't the only ones reporting this problem...
i believe we have as a good will gesture replaced the rim at cost and tossed in the Superlace prep[ie the re-angling/countersinking process],,even though they are out of the one year warranty period....since you are down -under,,,and it's X-mas,,we'll mail it down on our dime
will that work for you???
holler,
woody
Old 12-13-2011, 02:17 PM   #2330
1WD
KTM Tragic
1WD's Avatar
Oddometer: 799
Originally Posted by woody's wheel works View Post
That's a great goodwill gesture mate!
I'll endeavor to dig up my original invoice as requested.
You'd also be pretty close to the 3 year mark on the build, I reckon it was January '09 when I bought them.
Cheers,
Aaron.
1WD is online now   Reply With Quote
Old 12-14-2011, 12:13 AM   #2331
FlyingFinn
Oddometer: 1,118
Thanks Woody & Zack!
Mikko
"It is not when or how you die but how and if you truly were ever alive!" Dr. Jerri Nielsen FitzGerald
FlyingFinn is online now   Reply With Quote
Old 12-14-2011, 03:51 AM   #2332
pavegel
Adventurer Douche
pavegel's Avatar
Oddometer: 153
Rim and Spokes Only
Hi Woody,
I am thinking about building my own set of wheels for my 950 Adv. Starting with the rear, I'm looking at going with an silver Excell 3.5x18 plus spokes. I would like to have you guys build these, but I really need to save $. Plus I have the tools and knowledge to do this on my own. Do you redrill all of your rims, or just the ones for oversized spokes?
"A mind is a terrible thing to taste."
'06 KTM 950 Adventure S
'96 Toyota Landcruiser FZJ80
pavegel is offline   Reply With Quote
Old 12-14-2011, 08:47 AM   #2333
Built to Last
Oddometer: 3,431
superlace kit for self builders,,???
Originally Posted by pavegel View Post
Hi Woody,
a smoking deal is getting a Superlace kit,,,
a,,,rim silver excel=$236
b,,, drilled/countersunk/re-angled for Superlace patterns = $30,,,,plus
c,,,optimally sized spoke/nipple kit = $135[ss n ss] or $115 [ss n zartan/nickel platted steel nipples]
d,,,plus S&H circa $15-25
e,,,and if ya screw up,,ya have a parachute
=awesome deal
holler,
woody
woody's wheel works screwed with this post 12-14-2011 at 11:51 AM
Old 12-14-2011, 08:49 AM   #2334
fudgypup
Oddometer: 2,199
Mikko
What mine looks like right now. Can't wait to get it back from Woody's!
fudgypup is offline   Reply With Quote
Old 12-19-2011, 08:43 AM   #2335
angrywhiteguy
i wanna ride!
angrywhiteguy's Avatar
Oddometer: 154
double sig excel rims
Hey Woody,
Any sign of those double sig Excel rims factory black yet....I'm getting anxious for my wheels for my F 800 GS.... 18/21.
angrywhiteguy is offline   Reply With Quote
Old 12-19-2011, 06:06 PM   #2336
Built to Last
Oddometer: 3,431
new black oem custom double signture black oem Excels,,,when will they get here???
Originally Posted by angrywhiteguy View Post
Hey Woody,
sorry,,,the importer is clueless,and will give me a heads -up after checking again
w
Old 12-19-2011, 06:13 PM   #2337
Built to Last
Oddometer: 3,431
supere Tenere spoke loosening issues and Rx,,,
here's a request for info on the matter,,,via an e-mail from PS:
''I noticed there is a potential long term problem with the spokes on the new Yamaha SuperTenere and wondered if you had any ideas. I don't believe I will be affected, but some on the ST forum who use their bikes extensively and roughly off-road are breaking spokes frequently. It doesn't seem normal. I've thought about it and it seems that the nipples are backing off, allowing too much spoke flex and resulting spoke fatigue. My theory is that because the nipples are at the hub, they experience a lot more flexing than if they were at the rim. I'm sure spokes stretch and compress under load and it seems that combined with drive torque at the hub, the nipples and spokes would loosen/fatigue at a higher rate.
My thought would be to use a longer spoke combined with some sort of seating washer (perhaps conical or round to allow radial movement) at the hub combined with a nylok nut to retain tightness of the spoke. On the forum they've come up with bandaids such as LocTite (not an answer, in my opinion) and simple zip tying the spokes to keep them from damaging other parts of the bike when the spokes fail. Neither of those address the basic problem.
Maybe you could come up with some ideas. If my solution is something you could develop, feel free.
Thanks,PS''
BWOE: here's a pic of parts on bmw style X-laced tubeless wheel
FYI the set screw is screwed into the end of the nipple like a jam nut after everything is trued n toqrued down properly..so we made new beefy ss spokes AND ss nipples ,,they look gorgeous,,and then jammed with a zinc plated set/grub screw.....the new ss nipple is long enough so that no threads will be exposed like the shlock oem rendition
woody's wheel works screwed with this post 12-20-2011 at 06:08 AM
Old 12-20-2011, 12:33 AM   #2338
dendrophobe
Motorbike Junky
dendrophobe's Avatar
Oddometer: 859
w
I keep checking this thread every couple days, hoping. I won't see them until April anyway, I guess I'm just anxious to give you my money!
Doug
Semper Fi
2009 BMW F800GS, Olive Drab
2006 Ducati Sport 1000, Black
Custom built Ducati GT1000 Scrambler, Red
dendrophobe is offline   Reply With Quote
Old 12-20-2011, 09:43 AM   #2339
angrywhiteguy
i wanna ride!
Oddometer: 154
Me too....I want my new wheels!!!
Old 12-22-2011, 12:54 AM   #2340
Aarono2
Oddometer: 76
Hey,
What would it cost me to get my 2000 KLR650 rear rim remade with a black 18" CACR in whatever width you recommend? Would new spokes be needed? Cheers
Aarono2 is offline   Reply With Quote
Times are GMT -7.   It's 11:52 PM.
