02-12-2012, 07:11 PM
#2416 |
Carbon-Based Humanoid
Oddometer: 2,715
It's the front that I'm having trouble with. I'll report back, I feel the odds of my not becoming your customer are starting to diminish.
08 GS ● 02 KLR ● 12 WR250R ● 04 KDX200 ● 00 VFR |
02-12-2012, 07:13 PM
#2417 |
Built to Last
Oddometer: 3,088
ok,,now i know exactly what you are trying to do...R100GS 21 front wheel to KTM front
1,,since you have aleft disc and a floating axle that pulls up against the left fork leg,,your first order of business is getting th elocating/left spacer measure up and made so that your wheel is centered in the forks 2 now that the wheel is snugged against left forks you can measure the distance from the disc mounting surface to center-line of your calipers,,, 3,,you can nowfigure out where your rotor needs to end up and what package ya can come up with to get you there...,,don't forget to take into consideration the width of your disc,,have you tried using an OEM r100gs rotor,,, just for grins to see if it coincidentally lines up??? 4,,don't forget to measure from th eouter edgeof the pads to centerlin eof axle x 2 = diamete rof rotor ya need that should do it... let me/us know what ya come up with ![]() woody
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W |
02-12-2012, 07:18 PM
#2418 | |
Built to Last
Oddometer: 3,088
![]() now how'd i think you were talking about the rear wheel.... hmmmnnn w
02-17-2012, 10:34 AM
#2419 |
Oddometer: 2,715
Hey Woody, I got me some vidoes of the front wheel spinning on my Marc Parnes balancer. Comments?
02-17-2012, 11:11 AM
#2420 | |
Built to Last
Oddometer: 3,088
if a pic is worth a thousand words ,a video is worth a million,,,
![]() the good news is we can get it back to you better than stock specs. FYI new wheel is circa $1134,,, you'll spend circa $200-300 with one year warranty depending on how bad it is. holler when you are ready woody
02-17-2012, 03:29 PM
#2421 |
Built to Last
Oddometer: 3,088
NOTICE: Buchanan's latest price catolog is out.
well there's good news and bad news....
the good news is that most all their services ,,,their Sun rim and spoke prices haven't changed...all other rims have taken an across the board 10% price hike ![]() FYI BSR builds the sun rims in house as well as the spokes so can control a good bit of the machining/manufacturing costs...getting stuff from overseas is getting ever costlier... just giving you all a heads up... w
02-19-2012, 05:45 AM
#2423 | |
Built to Last
Oddometer: 3,088
what's the deal with the welded area on X-laced BMW rims???
folks,,,more has been written about this area on your X-laced rims.... FYI,,yes you are right ,,,it is the area that was manually ground down by some yoyo in the Behr factory...it is the same area that the BMW tech bulletin says to ignore when measuring for warranty claims... the gouges and divots are all 'normal' in their eyes,,,,IMHO any divot that is deeper than circa .030'' get's filled in and machined...some of these divots that we hav erepaired were .080''/2mm deep and and 4-5'' in length![]() this same area will have .040-.100'' variation in width...they get real agressive in blending the weld area out why they simply use a technique similar to Buchannan's Sun rim building,,ie after 'normalizing the rim, BS&R tosses the rim in a lathe and voila and machine it down to size,,VOILA, a beautiful,perfectly round rim is the result.... in the meantime look at this ugly mess ![]() OBTW,,,see the black rubber on the lower lip,,that's a sure telltale result of a divot ,,,your tire is working overtime trying to accommodate it til it heats up and transfers rubber to the rim ![]() woody
02-19-2012, 06:46 AM
#2424 |
Oddometer: 2,715
edit to say that now I just need to find some boxes and get around to shipping the wheels.
08 GS ● 02 KLR ● 12 WR250R ● 04 KDX200 ● 00 VFR WeazyBuddha screwed with this post 02-19-2012 at 06:52 AM |
02-22-2012, 12:09 PM
#2425 |
after a good ride
Oddometer: 14,334
hi W, you and i have been exchanging emails regarding the HP2 set up. moving it here that way many peeps can benefit from your inputs.
your recommendation of 19/17 to replace my factory 21/17 is one way i can touch the ground, and improve handling for road/canyon riding. sticking to the tubeless for less upsprung weight, better road handling, etc. sent you another email earlier and for pricing, PM or email is good. thanks, |
02-22-2012, 03:39 PM
#2426 |
crash test dummy
Oddometer: 625
Woody
I am looking for a 2nd set of wheels for my Tiger 800XC either 19/17 or 17/17 are you making them yet, is there an aftermarket hub? what are your thoughts? ta Marty
Marty '10 Multistrada 1200 '11 Tiger 800xc (90%) '79 CB900 (225% in boxes) |
02-23-2012, 05:30 PM
#2427 |
In the flow...
![]() Thanks Woody! Dual purpose dual fun! Mortard wheels are just cool... Cheers Pilbara Pilbara screwed with this post 02-23-2012 at 05:42 PM |
02-23-2012, 05:42 PM
#2428 | |
Oddometer: 115
SS & SS spoke and nipple set for Super Teneres are in !!!
Quote: Originally Posted by AndyCBR Hello Woody, Do you have a spoke kit available for this model yet? Corrosion of the stock Zinc spokes/nipples is a known issue with this model. I was thinking of trying the one at a time replacement method but need proper SS spokes/Nipples. Thanks in advance, Andy Quote:
Thanks, Andy
2012 Super Tenere/2009 crf450x/2006 sm610/2003 xr650l/1990 cbr1000f "The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles." - Jeff Cooper |
02-26-2012, 10:59 AM
#2429 | |
Built to Last
Oddometer: 3,088
will be home 1st of mar soon w
02-27-2012, 10:02 AM
#2430 | ||
after a good ride
Oddometer: 14,334
the word was out....you were playing.... ..... good you found the time.....![]() Quote:
http://www.advrider.com/forums/showt...=753732&page=2 |
