04-12-2012, 04:24 PM
#2461 | |
Built to Last
Oddometer: 3,088
supermoto wheels to taiwan
FYI,, the Superlace n true etc will work just fine on them ![]() same one year warranty and a free t-shirt or hat ![]() woody
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W |
04-17-2012, 09:13 PM
#2462 |
Oddometer: 1,493
Woody,
Received the xt225 wheel yesterday. Looks awesome, thanks for the great job and quick turn around. I don't think my wife will be able to break this one. ![]() And I really like your ad on that advlife website. ![]() Thanks,
"You can follow me, but it's gonna hurt" |
04-18-2012, 04:43 AM
#2463 |
Oddometer: 1
Wheel Polish
Recently bought 2011 Bonneville with alloy wheels. Triumph couldn't advise if aluminum or alloy. Wheels have corrosion(?) specks. Specks are whitish in color. Tried Wenol, S100 metal polish, and Never Dull. None removed the specks but cleaned around specks. Boms Away has good write ups but figured if anybody could recommend a product you could. Thanks in advance.
04-18-2012, 10:57 AM
#2464 | |
Built to Last
Oddometer: 3,088
thanks for the kudos...
regarding that wheel we built,,worry not there's not a one of the hundreds we've done that has veer returned for anything... now if you're really happy here's alink for picsnd comments,,we like seeing your smiling mugs,,,it's kinda tuff building stuff for folks out there in the ozone...in the old days ,folks tracked me down,,i knew who they were and what they needed...you get the drift.. so here's a link http://www.advrider.com/forums/showthread.php?t=646947 enjoy ![]() woody nthe gang
04-18-2012, 11:09 AM
#2465 | |
Built to Last
Oddometer: 3,088
white specs on anodized Triumph Bonneville wheel
FYI,,we see it all th etime in corrosive environments...we've found that whe we strip the old anodizing off and rebuff em theylook super fine,either re-anodizing or powdercoating will reveal how deep the corrosion actually went ,,,hence some folks just leave un-anodized ,,and maintain their wheels wit mother's or never dull,,,some use a quick coat of Xrystal clear krylon...protects a bit better than wax and can readily be removed by spraying the clear with carb cleaner and wiping it of,,buff/polish th erim and start over with another coat of Xtal clear hope that helps for now holler woody
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W woody's wheel works screwed with this post 04-18-2012 at 11:18 AM |
04-29-2012, 04:38 AM
#2466 |
Oddometer: 246
Hi woody
Re BMW f650gs single Can you lace a 17 inch rear rim on to the front hub of this bike. Looking to make a 17/17 sm setup and I already have a spare rear hoop. Thanks K
07 F650 Dakar,02 Husqvarna CR250, 01 Husaberg Fe650 |
04-29-2012, 05:16 AM
#2467 | |
Built to Last
Oddometer: 3,088
can rear 17'' rim of F650gs be used on front???
we have a broad range of tricks to re-cycle/swap rims and hubs everyhting from re-drilling nipple holes,,re-angling the nipple seats,,changing lace patterns to accommodate different indexing etc,etc i believe in your case if the indexing is the same as the front you can get by with a custom spoke kit and re-angling the spoke hole and countersinking the rim to accommodate the different spoke angles,,,the rear hub is wider and bigger in diameter than the front if we superlace or custom lace it,,that cost gets factored in ,,otherwise we charge $30 for this process holler if we can help woody
04-30-2012, 03:00 PM
#2468 |
Oddometer: 1,812
Got my Excel A60s on Thursay, and rode the bike for the first time yesterday...fantastic finish, quality and they look build for anything! Been wanting to say this for 5 years: finally got me some wheel-wood!
![]() (currently on a business trip so pictures this weekend)
Adventurer transitioning from 4x4 to 2x1 '07 G650Xch - Under Mod-struction |
04-30-2012, 03:45 PM
#2469 |
Creaks When Walks...
Oddometer: 1,142
No doubt this has been asked before, but I can't find it... so my apologies if you have answered it a thousand times. ![]() Is there a good way to convert a Yamaha WR250R to run tubeless tires? If so what do you think is the best way? I may have a line on a nice WR250R (have always wanted one), but since a ton of its use would be getting to-and-from the trails, and I already have all the pump, plugs, etc. to fix tubeless flats that I carry on my other bikes, I thought is might be worthwhile to do the conversion. Of course, that assumes there are decent tubeless dual-purpose tires in 18" and 21"... ![]() Also wondering if you are aware of any way to mount up a larger diameter front disc to the little Yamaha other than fitting the WR250X front hub? Thanks! Dallara ~
~ You never see a motorcycle parked outside a psychiatrist's office ~
Dallara screwed with this post 05-02-2012 at 08:18 AM |
05-02-2012, 01:00 AM
#2470 |
Oddometer: 222
WR250R Excel A60's
Not sure if this has been covered. Sorry if it has.
Can Woody build me a set of Excel A60's for my WR250R? I heard the hubs and rims don't match. Thanks, Everett. |
05-02-2012, 05:39 PM
#2471 |
I'm better now.
Oddometer: 1,601
This winter I had Woody's build a new front wheel for my 08 990. The oem was ben tup! Well I took my first ride this weekend and the new 50/50 sticks much better on fire roads, much. In fact it was great. I did not feel the need to stand as much to get weight on the front.
Great improvement Woody's.
I ain't a going without my hog, my gun, my whisky and my Bible. |
05-02-2012, 07:58 PM
#2472 | |
Built to Last
Oddometer: 3,088
if anyone can you're talking to him call Zach at the whel works ,number belowmmi#m in germany with äm family... he'll take care of ya prosit ![]() wody
05-02-2012, 08:01 PM
#2473 | |
Built to Last
Oddometer: 3,088
tubeless on a WR250R,,,why not
DON'T WORRY;;;FRET NOT!!! if anyone can you're talking to him call Zach at the whel works ,number belowmmi#m in germany with äm family... he'll take care of ya prosit ![]() wody
05-03-2012, 12:51 PM
#2474 |
Oddometer: 10
05-03-2012, 10:34 PM
#2475 | |
Built to Last
Oddometer: 3,088
hope that helps ![]() woodz
