Old 07-17-2012, 11:36 AM   #2536
Caprilian
Oddometer: 15
21 inch conversion ESA and pressure monitored 1200GS
Any experience with 21 inch conversion on ESA and tyre pressure monitored 1200GS?
A friend recently did the conversion on his non ESA GS- comparing it with my bike (ESA), there seems to be less space between wheel and shock as result of ?sensor/pressure valve on ESA system.
He has the tubeless option 21"- the well of the rim appears too narrow to allow the fitment of the Tyre Pressure Monitor (standard on my bike). Have you encountered this scenario? Could just ignore the flashing dash light but not ideal.
Thanx for any feedback.
Caprilian is offline   Reply With Quote
Old 07-17-2012, 12:12 PM   #2537
DIRT2THE STREETS
DIRT2THE STREETS's Avatar
Oddometer: 3
Wheel fit
Hiya Woody,
First time long time! Will wheels from a 2002 ktm sx fit a 2007 ktm 525 exc? I appreciate the help !
DIRT2THE STREETS is offline   Reply With Quote
Old 07-17-2012, 03:28 PM   #2538
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,447
R1200GS with 21'' wheel!!
We haven't heard any issues with it yet, I'm sure the mud can build up around there pretty easy though without a guard.
We can't get the sensor's in the 21'' rims because they are too narrow to fit in the drop center.
I am sure it doesn't mess with the computer's with them off, I have our abs ring removed on our 05 R1200GS with tubed 21/18 wheels and actually like it much better than not having it stop you off-road.
Thanks Zach
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works is online now   Reply With Quote
Old 07-17-2012, 03:30 PM   #2539
Built to Last
Oddometer: 3,447
KTM Wheels interchangeable?
The front hub for the 2002 will not work on the 2007 they used a smaller inside bore and cant fit the 26 mm bearings in the hub.
The rear should fit no problem.
If these are aftermarket talon or Rad hubs you can change the spacers to make them work, but would need to know what hub they are.
thanks zach
Originally Posted by DIRT2THE STREETS View Post
Hiya Woody,
Old 07-18-2012, 02:51 AM   #2540
LukasM
Oddometer: 5,426
Originally Posted by woody's wheel works View Post
the LC-4s have narrower rims and hubs than the LC-8 series,,,i assume ya have an LC-8 series bike,,,,,
FYI,,cush-drive hubs interchange with non cush drive hubs on all the single cylinder dirt bike series
Not all single cylinder wheels interchange, the 690 rear hubs are wider than the older LC4 and <530 bikes. But not wide enough to fit on the LC8....
thanks zach
You could also get a $25 adapter kit from KTM that allows you to fit a 20mm axle and wheel into your 26mm axle forks. It contains two split bushings and one wheel spacer.
Old 07-18-2012, 05:07 AM   #2541
Built to Last
Oddometer: 3,447
Talking fine tuning what works on LC-4hub/wheel swaps,,,,
Chao ong LukasM,,,fromSaigon,,,,
check with Zach,,,but i'm positive the hub wheel assy on the 690 is identical to all the others,,'cept it sports a wider spacer on one side,,we got snookered on that once before,,'tis a simple spacer swap,,Zach will remember better than i can these days
good call on the kit,,,my memory sez we found another solution,,,whatever,,,those early hubs were all replaced with beefier ones ,,not to mention the billets i designed and had RAD build me...
woody
Old 07-18-2012, 06:02 AM   #2542
LukasM
Oddometer: 5,426
woody
Hi Woody,
I haven't actually measured them myself but I am 99% sure that the 690 hubs are wider. Not that this necessarily proves anything, but they do have a different part number and Rally Raid Products even offers a specific kit with a disc spacer to get the width the same when using a (narrower) 640 hub wheel in the 690.
Billet aluminium Adaptor Kit to allow the use of older LC4 rear wheel in the KTM 690 Enduro.Uses KTM 690 Sprocket Carrier and rubbers.
I have both 640 and 690 cush hub wheels at home so I'll get some measurements to confirm tonight.
Cheers,
Lukas
PS: Have a good time in HCMC, I spent a few months there a few years ago after a diving accident, first stuck in the hospital and then grounded until I was cleared to fly. Fun times!
Old 07-18-2012, 07:23 AM   #2543
DIRT2THE STREETS
Oddometer: 3
Thumb KTM Wheels interchangeable?
"You could also get a $25 adapter kit from KTM that allows you to fit a 20mm axle and wheel into your 26mm axle forks. It contains two split bushings and one wheel spacer. "
You guys rock ! You wouldnt happen to know the part # I would need? Again I appreciate the help.
Old 07-18-2012, 07:27 AM   #2544
LukasM
Oddometer: 5,426
SXS03540400.
Don't forgot to get a cheap used 20mm axle with the wheels.
Old 07-18-2012, 08:54 AM   #2545
Built to Last
Oddometer: 3,447
awesome lukasM,,,
Hi Woody,
Cheers,
Lukas
LukasM
look i'll pass this and front 20mmaxle to 26mm coversion kit to Zach and the other young bucks doing the day to day stuff ,,,leaving me more time to R&D stuff for you guys,,,answer all ,,well at least what i do know
yeah,,Saigon is ahoot,,,especially driving through traffic,,,l
here' a ba muoi ba (33) beer to you n the troopies
ong woody
o Saigon
Old 07-18-2012, 07:17 PM   #2546
kkesp
UPSIDERIGHT
Oddometer: 226
Question about Excel Rims
Has anyone had a set of Excel rims made up by Woody that had the over SS nipples and spokes?
"Political Correctness is a doctrine fostered by a delusional illogical minority, and rapidly promoted by an unscrupulous main- stream media which holds forth the proposition that it isentirely possible to pick up a turd by the clean end."
kkesp is offline   Reply With Quote
Old 07-18-2012, 07:18 PM   #2547
kkesp
UPSIDERIGHT
Oddometer: 226
Has anyone had a wheel made up by Woody with the oversized SS nipples and spokes?
Old 07-18-2012, 07:19 PM   #2548
kkesp
UPSIDERIGHT
Oddometer: 226
Anyone have an Excel rim made up by Woody with oversized SS nipples and spokes?
Old 07-18-2012, 07:22 PM   #2549
kkesp
UPSIDERIGHT
Oddometer: 226
Anyone have an Excel wheel made up by Woody with oversized SS nipples and spokes?
Old 07-18-2012, 07:24 PM   #2550
ebrabaek
Oddometer: 4,815
Not sure if these are over...... Got what they recommended....
http://www.advrider.com/forums/showt...=759024&page=4
Erling
ebrabaek is online now   Reply With Quote
Times are GMT -7.   It's 06:07 PM.
