12-06-2012, 06:02 AM
#2671 |
Lampin' it
Oddometer: 4,141
Yo,
I am building up a Ninja 650R into a dirt machine. I am using KTM 450 suspension including swingarm. Since the countershaft sprocket is much further outboard on a sport bike vs dirt bike, I currently have a chain alignment issue. I solved this on the CBR i built by spacing out the rear sprocket and machining down the CS sprocket (to get it closer to the block). That took care of all alignment issues. Someone in my build thread suggested that instead of centering the KTM swingarm (it is narrower than the Ninja frame and needs spacers) I should move the swingarm all the way to the left so that the chain aligns with everything stock. Then relace the wheel to the right to get the tire back on center. I did that last night (moved the swingarm) and it made the packaging of the KTM shock much nicer too so I think I want to run with this. The distance the tire needs to be offset is about 0.55". Is that too much? Would I need new spokes? $$? This is how it looks with swingarm centered ![]() This is how it looks with swingarm offset to the left ![]() ![]() The last bike you guys helped me with was the FZ1 but that was running a KTM 950 swingarm and cush and was much wider I did not need to do anything to get that to work. Thanks Peter
We're not out here to rough it. We're here to smooth it . Things are rough enough in town. Nessmuk |
12-06-2012, 08:34 AM
#2672 | |
Built to Last
Oddometer: 3,087
can we accomodate moving rim .550'' to right in order to.....
....in order to compensate the swing-arm having been moved to left??/
we should be able to if the rear hub flanges/spoke holes are wide enough to still have some decent geometry..this is accomplished several ways: 1,,lengthening spokes on left side and shortening on right,,,we can figure out how much 2,,the nipple holes will have to be re-angulated and countersunk to accomodate the different angle of attack 3,,we'd want stronger spokes on right usually to accomodate extra stress 4,,custom spoke kit ss heavy duty w ss nipples circa $125+/- 5,,having us superlace it would be cheapest/bullet proof option ,,includes re-angling/countersinking as part of process with a 1 year warranty= $111 holler when you are ready ![]() ![]() woody Quote:
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W |
12-06-2012, 08:59 AM
#2673 |
Lampin' it
Oddometer: 4,141
If I'm going to spend the money to do this is there a better hub like a 640 or rad that I can get that will give me cush drive that fits the swingarm?
I'm ready btw
12-06-2012, 12:30 PM
#2674 | |
Built to Last
Oddometer: 3,087
are cush drive hubs available for special conversion project???
1,, the spacing/lining up of your sprockets CS and rear 2,,location of disc relative to caliper 3,,axle diameter 4 location of rim relative to hub and center-line of bike 5,,your pocketbook...FYI most RAD cush drive assemblies are circa $550 these days oem ones a little more or less,,used ..circa 30-70% of new depending on condition and demand 6,,ya need to draw a sketch/take pics and show me the node points /fill in the data i mentioned above 7,,lot's of folks just bring the bike by or at least the wheel/axle/swing-arm with caliper on it,,and we can take it from there perfectly holler woody
12-10-2012, 10:51 PM
#2675 | ||
Built to Last
Oddometer: 3,087
wow,,wow..WOW!!!! 3000 posts !!!
for some reason,,i just checked my ''signature'' to see if i could add my Skype address for those that prefer that medium...me???,,i love it 'cuz i can talk n do show n tell at the same time,,,you can show me your problems etc etc..
guess what??? in the statistics section..it showed the following: Mini Statistics
![]() thanks for asking all those questions over the years sincerely, woody
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W woody's wheel works screwed with this post 12-11-2012 at 01:00 AM |
12-15-2012, 06:07 PM
#2676 |
Dark Knight
Oddometer: 116
18" rim on a stock 21" w/ drum
how much would it be to relace an 18" rim onto the hub of a stock 21" from a '75 xl350? please and thank you.
2005 klr650 sold 1996 vulcan 1500L sold 1980 cb900c w.i.p. riding is so much better than not riding |
12-17-2012, 12:15 PM
#2677 | |
Built to Last
Oddometer: 3,087
relace a n 18''rim to '75 XL-350,,,$$$ = ???
1,,you'll need another spoke kit circa $100 ss spokes n nipples $60 used 2,,you'll need a rim $100-200 depending less used 3,,custom lace n true= $99,,want it super strong= Superlace @ $111 with one year warranty ![]() woody
12-17-2012, 02:47 PM
#2678 |
Will Work for Food!
Oddometer: 1,425
When will mine be done???
Rangers Lead the Way, Hooah! |
12-18-2012, 07:50 PM
#2679 |
Will Work for Food!
Oddometer: 1,425
Thanks Zach, got your PM, can't wait until they get here!
12-19-2012, 08:47 AM
#2680 |
Built to Last
Oddometer: 3,087
BigDave75's Wheel's getting built!
Hi Bigdave,
Thought I'd throw some teaser's of the wheels, they are being sealed right now ![]() z
12-20-2012, 12:40 AM
#2681 |
Life is beautiful !!!
Hey Woody,
I have an '90 Africa Twin RD04 rear hub (not the whole wheel, just a hub) , could you superlace 18X2.5" gold excel rim on it ???
Engineer, mechanic, philosopher,adventurer...totally out there Reliable '90 Africa Twin aka "Desert queen" Mighty 2008 VTX 1800 T3 aka "Jumbo jet the queen of the skies" |
12-20-2012, 07:14 AM
#2682 |
Built to Last
Oddometer: 3,087
Superlaced Africa twin hub
Hi,
Yes we have superlaced the africa twin hubs to 18 x 2.5 gold excel's before, Are you putting it on the Transalp? IF you supplied the hub it would be 430 + shipping to superlace it with an 18 x 2.5 gold excel and heavy duty stainless steel spokes/nipples. thanks zach
12-20-2012, 08:35 AM
#2683 | |
Will Work for Food!
Oddometer: 1,425
Damn those look good!!!!
12-20-2012, 08:38 AM
#2684 |
Will Work for Food!
Oddometer: 1,425
You're Killin' me here Zach!!!
Those are going to look great with the Galfer Wave Rotors!
12-20-2012, 12:51 PM
#2685 | |
Thanks for fast reply Zach. I will be sending to you soon.
