Old 07-13-2013, 09:25 PM   #2791
dwj - Donnie
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 14,451
Hi!
I will be leaving Lazaro Cardenas, MX tomorrow morning on a KTM 990ADV that hit a curb and not only put a v in the front rim, it also split the rim. After substantial welding by some guys that have been racing Motocross for many years, I will be starting the 1,900 mile ride home. Yes, I will be watching for topes and pot holes very carefully! The rear rim was also bent and was heated and re-shaped. What would a ball park figure be to replace the front rim with one of the stronger rims, replace what ever spokes may be needed, lace and true it and send it back to Mississippi? What are your thoughts on using heat to re-shape the rear rim? It was not bent as much as the front and had not lost air pressure with the Goop tubeless method. It has a tube in it now because the heat melted the goop. You can PM me or put it here if you like. The moto is insured and I will definitely start things happening when I get home. Thanks!
Donnie W. Jennings
Donnie
Donnie - Retired & Riding - 2010 990ADV - 42,200 Miles - 1 Continent - 10 Countries
Traveling Mexico 2014 - SPOT
dwj - Donnie is online now   Reply With Quote
Old 07-15-2013, 12:32 PM   #2792
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,386
Excel Sticker's for Re-anodized Black rims.
We do have the sticker set's for $28/set of eight sticker's. We'll sell ya 1/2 set for $14.
If you want to have them, it would be best to call us at 303-936-0232 or email us at [email]woodyswheelworks@gmail.com
thanks zach
Originally Posted by OZZY-GS View Post
Cheers that would be great!
Get back to me re the price when you can.
Thanks heaps
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 07-17-2013 at 02:00 AM
Old 07-15-2013, 12:50 PM   #2793
Built to Last
Oddometer: 3,386
Front hubs on rear rims.
You do have a Jap index rim and Jap index hub, but unfortunately the rim needs to be re-drilled and countersunk to make the nipple's point in the correct direction and width or it will cause them to bind at the nipples.
We have normally used our superlace to allow the rear rims to work best with the front hubs. The main issue is the angles on the rim are too wide and it won't work correct until it's drilled/countersunk right.
We can supply a spoke kit for the rim and hub you have, but the rim still needs to be drilled for it to work properly.
It would be 110 for a stainless steel spokes/nipple kits for each wheel.
If you have more specific questions, email us at woodyswheelworks@gmail.com
thanks zach
Originally Posted by ontic View Post
Hi Woody,
I am trying to build a 19" front wheel for an older KTM set of forks and would like to buy some spokes to suit, from you if you can provide them?
This might be a standard spoke, but I can't figure it out.
The hub I have is a 36H, 17mm axle, KTM hub (for WP50 extreme forks) which I am pretty sure is in Jap spoke pattern (my 21" stock wheel for these forks with what looks like the same hub is Jap pattern- but I don't know how to tell if this bare hub is the same- assuming it is).
The rim is a "J 19X1.85" 36H Excel, Jap pattern- originally described as a rear rim suitable for a range of smaller Jap bikes.
Holes for the spokes by my closest measure
hub = 5.1mm
rim = 8.7mm (same size holes as a spare 'ktm' 21" excel Al7 rim I have)
Are you able to sell or recommend a set of spokes to lace this together? I would probably prefer stainless, but will take what I can get.
Shipping would be to Australia.
here are a couple of photos and extra info below.
This front wheel is actually for my R80G/S for the fork swap I have done on it- I've got a set of 18" rear 21" front wheels for knobbies, and this 19" front wheel will be for road-oriented dual purpose tyres and matched to a 18X2.15 rear wheel.
Thanks heaps,
Old 07-15-2013, 12:53 PM   #2794
Built to Last
Oddometer: 3,386
Off-seting X-laced wheels.
Yes we can off-set oem X-laced wheels with the oem spokes up to 1/4" safely. If it needs more it would require new spokes to allow the off-set.
We can true them over for around $180-300 depending on if the rims bent or not. If the wheel needs new spokes it would be $200 for lace/true + $200 for stainless steel spokes/nipples set.
thanks zach
OBTW!,Doing this will change the centerline of the rear wheel,,which normally can be corrected by re-aligning/adjusting the swing arm location via ear axle pivot bolt adjusting nuts.(sez woody)
Originally Posted by 10doh View Post
Is it possible to offset the standard R100R cross laced wheel so I can fit to an older bike(mono lever) The 17inch Rim touches the swing arm in the factory position.
woody's wheel works screwed with this post 07-17-2013 at 02:09 AM
Old 07-15-2013, 12:59 PM   #2795
Built to Last
Oddometer: 3,386
KTM 990 rim options.
We would recommend using a 1.85 x 21 front excel rim with our superlace and stainless steel spokes/nipples for the best all around 50/50 riding wheel. If you are going more off-road and are more aggressive then the 1.6 x 21 will be best.
The oem rim is only worth fixing if you are in need of getting home. Otherwise it's basically too soft for any off-road riding at all.
We can lace your hub with new stainless steel spokes/nipples superlaced with a 21 x 1.85 black excel for $531 + shipping. We can re-use your oem spokes if they are good, but it would be $412 for the rim and unlace/lace/true.
The 21 x 1.6 black excel rim would be less expensive and would require new stainless steel spokes/nipples. It can be from $399 for a Takasago rim, stainless steel spokes/nipples and superlaced, up to $500 for the strongest 21 x 1.6 Excel A60 rim, superlaced with stainless steel spokes/nipples.
Thanks zach
PS,,woody chiming in,,Please note,,for the big Adv bikes I highly recommend going the Superlace route,,,they truly are the toughest solution out there,,,in fact we warranty em for a year against spokes loosening.
Regarding the heating business,,,it depends on how much heat was put on it. We also use heat sparingly.mostly on cast wheels. Your rim has probably lost it's tensile strength in that spot. It was a temporary solution that got ya going again.
Originally Posted by dwj - Donnie View Post
Hi!
Donnie W. Jennings
Donnie
woody's wheel works screwed with this post 07-17-2013 at 02:20 AM
Old 07-15-2013, 01:04 PM   #2796
Built to Last
Oddometer: 3,386
BMW G650X wheel options
We have plenty of options for wheel's on the G650 oem hubs. We have built many superlaced wheel's with oem hubs, excel rims, and stainless steel spokes/nipples. We can re-use the oem spokes with a 21 x 1.6 and 18 x 2.15, but not excel 2.5 x 18 the drop center is too small which makes the oem spokes too long. It can be $400-550 for excel rims to use your oem spokes.
It can be up to $1100 to rebuild your oem hubs with black excel rims, superlaced with stainless steel spokes/nipples.
If you have more questions, it's best to call us at 303-936-0232 or email us at woodyswheelworks@gmail.com
thanks zach
Originally Posted by rjudge View Post
Hi Woody,
I've browsed the thread and have seen a few posts on the G650X XChallenge but either I'm blind, dumb or both. So, what are my options for getting good rims on front and back, 21x1.6 and 18x2.15? Can I use the stock hubs or no? What's this going to cost?
BTW, I had you guys work on the rear wheel bearings on my F800GS, 6k mi and they still seem ok. I still have my fingers crossed. We'll see at >10k. Thanks!
Rick
woody's wheel works screwed with this post 07-17-2013 at 02:21 AM
Old 07-15-2013, 08:12 PM   #2797
dwj - Donnie
Oddometer: 14,451
We can lace your hub with new stainless steel spokes/nipples superlaced with a 21 x 1.85 black excel for 531 + shipping. We can re-use your oem spokes if they are good, but it would be 412 for the rim and unlace/lace/true.
The 21 x 1.6 black excel rim would be less expensive and would require new stainless steel spokes/nipples. It can be from 399 for a Takasago rim, stainless steel spokes/nipples and superlaced, up to 500 for the strongest 21 x 1.6 Excel A60 rim, superlaced with stainless steel spokes/nipples.
Thanks zach
Thanks for your info! I like the idea of the Superlaced rim and the SS spokes. Would that all be in black like the current spokes and rim? I use this moto for adventure touring. Meaning that I ride gravel and dirt if it is in the way of where I am going, but nothing more. Think Prudhoe Bay and Inuvick, NWT. I know nothing about rim sizes, but it seems that I have read that a wider rim is better for more street oriented riding. The most aggressive tire I will ever use is the Heidenau Scouts, which is what is on it now. The stock rim is 2.15, correct? I would want Excel or what ever is the best rim. There are millions of speed bumps down south where I ride, pot holes too.
I am now 900 miles and two days from home!
Old 07-15-2013, 11:37 PM   #2798
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,997
Just picked up an 08 990 ADV that came with your 17x19 super lace setup.
Outstanding!
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 07-16-2013, 04:01 PM   #2799
Built to Last
Oddometer: 3,386
Spokes and rims in black!
The rim would be black, but it's an extra $100 to powder-coat the spokes/nipples. Which actually comes off easy with a lot of off-road riding.
The 1.85 x 21 would be best for the 90/9021 Heidenau Scout tire's for the type of riding you are doing. The 2.15 x 21 would be best for pure street, as the 1.85 x 21 is best for 50/50 riding.
If you would like to order, it's best to call or email us at woodyswheelworks@gmail.com
thanks zach
QUOTE=dwj - Donnie;21875216]Thanks for your info! I like the idea of the Superlaced rim and the SS spokes. Would that all be in black like the current spokes and rim? I use this moto for adventure touring. Meaning that I ride gravel and dirt if it is in the way of where I am going, but nothing more. Think Prudhoe Bay and Inuvick, NWT. I know nothing about rim sizes, but it seems that I have read that a wider rim is better for more street oriented riding. The most aggressive tire I will ever use is the Heidenau Scouts, which is what is on it now. The stock rim is 2.15, correct? I would want Excel or what ever is the best rim. There are millions of speed bumps down south where I ride, pot holes too.
I am now 900 miles and two days from home! [/QUOTE]
woody's wheel works screwed with this post 07-17-2013 at 02:23 AM
Old 07-16-2013, 04:02 PM   #2800
Built to Last
Oddometer: 3,386
Second hand WWW 19/17 KTM 990ADV set-up...
Looks great, let us know how you like them on the bike.
thanks zach
Outstanding!
woody's wheel works screwed with this post 07-17-2013 at 02:25 AM
Old 07-16-2013, 11:44 PM   #2801
gen
gen's Avatar
Oddometer: 800
Zach,
Would you say the same thing for the OEM 690 Enduro rim as well? Is it also too soft?
How about the OEM rim on the 690 SMC? Also soft vs. aftermarket rims?
DoD#1458 | GaijinRiders | 2010 KTM 690 Enduro
gen is offline   Reply With Quote
Old 07-17-2013, 04:45 PM   #2802
Built to Last
Oddometer: 3,386
OEM rim qualities!
Originally Posted by gen View Post
Zach,
The 950/990 adv and BMW F800GS rims were essentially the same 21 x 2.15 BEHR rim's that were drilled for different hubs. They are ok for street but the 6000 series aluminum and wider rim is too wide for any off-road riding without easily bending.
KTM did use the SAXXESS label which they did use stronger aluminum, but was only after 2011. They are still easy to bend, but better than the older rims.
The 690 rims are the same aluminum as the SAXXESS rims on the 990 adv, but since they are narrower they are stronger.
The SMC rims are the same aluminum, but since they are wider it's easier to bend them.
thanks zach
Old 07-20-2013, 01:58 PM   #2803
dwj - Donnie
Oddometer: 14,451
Hi Zack!
I will call you as soon as I get some insurance issues handled. I hope for this to happen by next Wednesday. What kind of turn around time should I expect? Thanks for your help?
Donnie
thanks zach
[/QUOTE]
Old 07-22-2013, 12:59 PM   #2804
Built to Last
Oddometer: 3,386
Turn around time's?
,QUOTE=dwj - Donnie;21912982]Hi Zack!
Donnie
Hi Donnie,
Great, hope that works' out for you.
Our turn-around on simple project's right now is around 3-4 days. I'll be gone from thursday to monday for the RMAR Rendezvous in Silverton.
thanks zach
[/QUOTE][/QUOTE]
Old 07-23-2013, 07:59 AM   #2805
LukasM
Oddometer: 5,415
Hey Zach,
I don't think that is correct if you are talking about the 690 Enduro (R). This bike uses the same DID Dirt Star rim as the 950 Super Enduro, both in 1.85" width, both have proven to be very strong.
KTM doesn't give out any specs but it would suprise me if they were not the same 7000 series rims that DID normally sells under the Dirt Star brand, even in this OEM application.
Times are GMT -7.   It's 06:32 PM.
