Old 08-22-2013, 11:39 AM   #2836
Careca
Careca's Avatar
Oddometer: 9
Good afternoon, woody.
First, sorry for my bad english. I wanna ask you one question, hope you help me solve this problem.
I have a 950adv and my front rim is garbish.
I have a excel 1'60 from a 450 exc to put there, can it fit without changing the spokes?
I read somewhere that it can be done only changing one side of the spokes. That,s correct? If it is, witch side and what length do i buy?
Can you help me?
Thank you.
www.TrailAventura.com
Careca is offline   Reply With Quote
Old 08-22-2013, 01:20 PM   #2837
BigDave75
Will Work for Food!
BigDave75's Avatar
Oddometer: 1,747
Originally Posted by woody's wheel works View Post
hi Dave,,,,when i see the wheel,,,i'll know what era that wheel was done in,,,and by whom it was done by.
FYI,,i have done several hundred of these over the years,,,,with many versions of sealants and protecting tapes....the protecting tape was meant to provide an extra measure of protection against errant tire irons,,,i've learned that even when we use our touchless tire mounting machinery,,,great care and much lube needs to be used when mounting and dismounting,,otherwise the machine will just squeeze the tape and separate it leading it to eventually ball up due to wheel rotation forces....it just looks ugly,,,,OBTW i recently noticed the correlation between a few wheels with messed up packing tape,,if the tape was applied in the same direction as tire
rotation it stayed in place,,,,if the end of tape got dislodged it would start flinging out and unwind itsrlf into a little ball
once again great care,cleanliness and patience in performing the sealing technique are paramount to ensure long term success. When performed that way success is enhanced.
Amazingly ,i get wheels in here for tire changes that were done 25 years ago with circa 100,000+/- miles on em,,,as the testimonials constantly appear in these posts.
woody
These were built in November 2012.
Rangers Lead the Way, Hooah!
BigDave75 is offline   Reply With Quote
Old 08-23-2013, 12:54 PM   #2838
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,398
What dou need to convert front 450EXC rim to 950/990 ADV???
Can you help me?
Thank you.
We routinely perform this conversion for folks who try to save some $$$,,,
We have the equipment and expertise to modify that rim and make it work.
The stumbling block is your rim is indexed/drilled for a standard Japanese Pattern,,your 950adv is drilled for 'euro' pattern,,by adding or subtracting one spoke cross we switch the rotation /index on that side,,we prefer using a X3 pattern because it is stronger
Minimally you will need 18 longer spokes for the X3 circa $50 in SS. You can re-use your old nipples
AND you need to re-angle and countersink the X3 side spoke holes in rim to match the new angle of the X3pattern circa $25
I'm not at the shop but will get someone to add that information here
New OA[overall] spoke length= 9 3/8'' = 9.375''= 23.8cm overall length
or 9'' = 22.8cm main body x 3/8'' =.375'' = .953cm throat x 25 degree bend
FYI in plain metric the OA total length of spoke = 23.8cm....from end of spoke by threads to under the head of the spoke,,,the spoke needs to bent up 25 degrees .953cm from under the head....that leaves 22.8 cm from center of bend to the end of the spoke that has the threads.
Woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 08-24-2013 at 09:27 PM
Old 08-24-2013, 12:53 PM   #2839
Careca
Careca's Avatar
Oddometer: 9
We routinely perform this converse for folks who try to save some $$$,,,
New spoke length= 9 3/8'' overall length 9'' body x 3/8'' throat x 25 degree bend
Woody
I'm not quite understanding this unit of measure and my english is really bad.
In centimeters, how much?
Old 08-24-2013, 09:30 PM   #2840
Built to Last
Oddometer: 3,398
the answers in cm are in my previous answer/post
go one post back ,,please re-read
answers in cm
woody
Old 08-29-2013, 05:15 PM   #2841
daveburton
Oddometer: 179
GS 1200 wheel rims on a KTM 690
Woody,
Firstly, thanks a lot for the feedback, it's clear you are the technical authority when it comes to wheels.
Quick question, can I use GS/GSA wheel rims on a KTM 690 to get to a 19/17 setup for tubeless tyres. I like that idea as there is no need to rely on sealant around the spokes. Are there any other alternatives that avoid sealing around the spokes. Are the rims from GS or alternatives classed as good quality for ADV touring. I assume the GS rims must be good given the track record on a heavy bike.
You stated that one of the cons would be a slight loss of offroad performance. How significant would that be to a novice off road rider (who needs all the help available). The reality is that in most cases I will be on sealed roads, For a bit of context I've crossed the Andes a number of times on a GSA and not had any issues.
I'm now starting to set up for a possible Russia trip which is why I have gone to the 690.
thanks,
dave
daveburton is offline   Reply With Quote
Old 08-30-2013, 03:14 AM   #2842
Built to Last
Oddometer: 3,398
genuine tubeless X-laced rims on 690 KTM??? you bet!!!!
Originally Posted by daveburton View Post
Woody,
Quick question, can I use GS/GSA wheel rims on a KTM 690 to get to a 19/17 setup for tubeless tyres.?????
sorry...NO....GS rims use 40 spokes ,,KTMs 36
yes,,,we have adapted the 19/17 X_laced rims of the aprillia Caponord for many 36 hole hubs...
http://www.advrider.com/forums/showthread.php?t=465628
they must be adequate 'cuz i've had no comebacks,,,as to the ''quality'',,well i've seen better stuff in my day....
totally insignificant in your case,,,the X-laced pattern is about as tough a wheel design that i've seen,,IMHO
After watching the two brits wrestle their behemoths across the tundra,,has me cringing in my lowers,,,,i had a similar experience trying to pick my fully loaded r1100GS somewhere in the desert outside of las vegas,,heel within a week i bought me pair of KLR650s,,,for my ''adventuring'',,have been grinning ever since
here's some more links:
http://www.advrider.com/forums/showthread.php?t=284243
http://www.advrider.com/forums/showp...31&postcount=1
thanks,
dave
psst,,ya can have Superlite,superlaced wheels sealed fro tubeless fro 1/2 the cost of the Caponord set-up....
woody
Old 09-08-2013, 11:29 PM   #2843
mungo57
mmm Beer
mungo57's Avatar
Oddometer: 15
airhead cafe
Hi Woody,I am in the process of building a cafe based on a '84 twin shock R100 bmw.For the rear wheel I am looking to use a hub from 77 RS ,X laced to a rim from a 94 R100R. Do you think this or something similar would be possible? Thanks.
mungo57 is online now   Reply With Quote
Old 09-09-2013, 10:03 AM   #2844
Built to Last
Oddometer: 3,398
swapping rims on X-laced tubeless BMW wheels,,,do-able???
been there and done that
woody
Old 09-12-2013, 10:11 AM   #2845
Buster714
VP of crash testing
Buster714's Avatar
Oddometer: 658
Just shipped my wheel to Woody's yesterday. Looking forward to retiring my wobbly, bent, dented and chipped stock front rim.
Aram :: SoloMotoParts.com :: Motorcycle Parts, Gear, and Accessories
Premier Brands / No Tax / Free Shipping / Hassle-Free Returns / Friendly Customer Service
Buster714 is offline   Reply With Quote
Old 09-14-2013, 09:32 AM   #2846
Leget
Leget's Avatar
Oddometer: 585
18/18 xrl
Hey Woody,
I have a 2007 Honda XR650L and I am trying to put together an extra set of wheels.
The rear is no issue, I will just be ordering a new set of spokes for the stock 18” setup.
The front is going to be “custom” and I need some help with spokes.
I’m going for a “budget” 18”/18” supermoto type setup for the spare wheels.
I will be using a 1993 XR600 front hub (36 spoke) and I plan to use a rim from the back of a 1983 Honda CR250 (18” 36 spoke).
I need to find out if I will need to send you the hub and rim to determine the correct spoke length/bend.
I wanted to check because I was hoping you might be able to determine the correct spoke length/bend from previous experience.
THANKS
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
Leget is offline   Reply With Quote
Old 09-16-2013, 12:36 PM   #2847
Built to Last
Oddometer: 3,398
low budget Honda XR650L rim swap to 18/18
QUOTE:
"Hey Woody,
THANKS "
hi Leget
no problem for us ,,,maybe a problem for you....the pickle yo re in is converting a rear rim that had a bigger diameter and wider hub than the front be mounted/laced to a narrower/smaller diameter hub....
Hence the spoke angles will not be the same ,,you'll have the spokes bowing inwardin both directions....leading to premature spoke /wheel failure...
send the compnents out and we'll re-angle/re-counter sink the nipple holes for perfect alignment =$30 ea rim
i highly recommend asking for a superlace kit cuz the spokes and nipple for custom vs superlace are essentially the same $$$
Psssst ya can be frugal and order Zartan nipples and SAVE circa $20 per set
turnaround time a day or two usually
if we lace n true custom =$100/wheel [includes re-drilling /re-angling]
SUPERLACING is $111/wheel with improved lace patterns nipple sizes and one year warranty
holler when you are ready
woody
Old 09-17-2013, 11:37 PM   #2848
Leget
Leget's Avatar
Oddometer: 585
hi Leget
woody
Awesome, Thank you... good to hear that you can make this work.
I'll contact you about shipping the hub and rim to get fitted for the superlace kit.
One more question:
I plan to powdercoat the hub and rim, should this be done before or after i send them to you?
(I would guess it should be done after since you'll be doing some drilling)
Old 09-18-2013, 05:10 AM   #2849
Built to Last
Oddometer: 3,398
what's the better sequence for powdercoating a hub before lacing??
One more question:
the better sequence is to do all the prep work/drilling the prep hub for powdercoating and then re-lace it
woody
Old 09-18-2013, 07:41 AM   #2850
KustomizingKid
Oddometer: 678
How much for a cush hub setup reusing the stock wheel for an XR650r? And how much more for a heavy duty black wheel and heavy duty spokes?
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Times are GMT -7.   It's 05:42 PM.
