Old 08-07-2006, 12:03 PM   #46
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,610
Something like this?
http://www.advrider.com/forums/showp...&postcount=864
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 08-07-2006, 01:29 PM   #47
street tracker
High, wide, and handsome
street tracker's Avatar
Oddometer: 1,450
Not quite... I want something closer to a classic dirt track or maybe a supermoto tire.
Bitchin' picture though! I've been following that story...
"It's useless to put on your brakes when you're upside down." - P.L.N.
http://www.gearheadsgarage.com
street tracker is offline   Reply With Quote
Old 08-07-2006, 05:25 PM   #48
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,443
no problem,,,,i know exactly what ya want,,,,
i've got a sportster set up like a flat tracker,,,,we do these every once in awile,,,you need something like a,,,,2.50x19 front,,,3.0 x18 rear and we can pick from all the street legal rubber that look like a flat track tires,,holler ,,,woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 08-08-2006 at 06:45 AM
Old 08-07-2006, 10:35 PM   #49
SennaSixty8
uber moto abuser
SennaSixty8's Avatar
Oddometer: 142
Chris @ woodys is in the process of scaring me up a 17x3.5 RT wheel for the front of my R12GS. Hopefully project Giganti-supermoto will be underway soon.
Supermoto has ruined my LIFE
SennaSixty8 is offline   Reply With Quote
Old 08-08-2006, 10:47 AM   #50
QUICKDRAW
Bug Murderer
QUICKDRAW's Avatar
Oddometer: 1,153
I sent a PM before I found this thread so..... I'll ask here too. What size Rim Lock should I use on an 06 BMW Daker rear tire?
Thanks,
Shawn
QUICKDRAW is offline   Reply With Quote
Old 08-08-2006, 12:13 PM   #51
wibby
wibby's Avatar
Oddometer: 10,610
What's the best way of balancing a spoked wheel?
I have a balancer and the lil adhesive lead weights but they look a little tacky stuck to the sides of the rim
'05 DL650
'92 KDX200
Old 08-09-2006, 10:41 AM   #52
Built to Last
Oddometer: 3,443
here's how we do it...
your basic set up here is close,,,to refine it here's what we do,,,
1. we have several axles in various diameters set aside for the exclusive use to balance,,,ALL constantly monitored for straighteness
2.where you used a bushing to prop up the shaft we use smooth worn ball bearings with no seals,,,to minimize drag
3.. tape a weight works fine,,,provided you preclean the surface with brake cleaner or acetone
4...up to an ounce of counterweight we install at the light spot of wheel assy,,,,make sure all ojects like discs n sprockets are mounted for a more accurate balance job
5, where heavier weights are needed we like to install the weights in a delta patern 1e,,more like 120 degrees apart,,,much smoother
6. for roadracers and enduro riders,,,we cover the weights with a piece of duct tape as added insurance
7, ALWAYS check your wheel /mag for true and no dents/flat spots....before ya balance,,,it's a waste of time n money to balance a crooked wheel,,,,you'll have a wheel that physically will still shimmy n hop once you ride on it
PS,,,pssst,,,FYI,,,, you don't stick the weights on the side of the rim,,,ya stick em either on the drop center portion of the rim or on the flat surface to the left n right of the drop center
Old 08-09-2006, 12:45 PM   #53
wibby
wibby's Avatar
Oddometer: 10,610
Mine would not fit anywhere else, I just put 'em on 'til I find a better weight
Whatever that is?
This is the first tire I've run balanced on the DR, never had a issue with the other tires but thought I'd try it this time
'05 DL650
'92 KDX200
Old 08-10-2006, 06:56 AM   #54
sweptwingnut
The Nut
sweptwingnut's Avatar
Oddometer: 156
Thanks Woody! I just started riding this summer and was wandering why the front tire might be hopping and shimmying on my '06 1200GS. I was going to say it was simply out of balance. But after reading all the info on this thread I think I have a better place to start now.
I will be planning to send you some wheels this winter.
2006 1200GS for me
2012 F650GS (twin) for my wife
http://www.twowheelfemales.com
sweptwingnut is offline   Reply With Quote
Old 08-13-2006, 05:22 AM   #55
hogmolly
Dude
hogmolly's Avatar
Oddometer: 3,142
Woody,
I have a R100GSPD and I'm think about having the wheels trued and spokes tightened and/or replaced. Is it possible to offset the rear wheel by 5mm when respoked? I have interference problems with my rear tire and shock and must use spacers. I would love to stop using spacers.
10 FLHCUSE-BLK, 09 FXDL, 08 FXDWG, 98 FLHR, 07 R1200GS Adv, 95 R100GSPD Classic, 93 R100GSPD, 92 CB750
hogmolly is offline   Reply With Quote
Old 08-13-2006, 06:12 AM   #56
Built to Last
Oddometer: 3,443
no problem,,,,
Originally Posted by ADVman
Woody,
i should have no problem swinging that,,,a good idea at this stage is to do one of my restorations,,,ss spokes are in order,,,i upgrade all those old chrome spokes,,they are notorious for rusting and having the heads crack off,,,am doing several as ispeak,,,one customer is taking my advice of having his rims anodized,,,the oem ones were polished akronts that get kind of crusty
send em down ,,you won't be disappointed,,,do it sooner rather than later cause i'm off to ashville on the 26th -10 sept
Old 08-13-2006, 08:18 PM   #57
hogmolly
Dude
hogmolly's Avatar
Oddometer: 3,142
Where do I get the relavent info like where to ship, approximate cost, how to pack, etc. Can you do a black anodize?
Old 08-13-2006, 08:33 PM   #58
Built to Last
Oddometer: 3,443
no problem with the anodizing,,,,
just check the website below,,everything is there,,,also the toll free number,,,thanks wooody
woody's wheel works screwed with this post 08-27-2006 at 10:02 PM
Old 08-14-2006, 03:37 AM   #59
sousap
Oddometer: 18
TDM900 mods
Hi Woody,
I have a TDM900 and I would like to make it mode Adventure...
The stock rims are 3.5x18 and 5.0x17:
I have the following options:
1. change the front rim for an Yam cast 3.5x17 and fit Pirelli MT60RS 120/70 and 160/60
2. change the front and rear for Yam cast 3.5x17 and 5.5x17 and use Dunlop D616 (Uly stock tires)
3. move to spoke rims...
My questions to are:
what do you recomend from your knowlage? (sizes, hub/rim brands, tires)
did you ever modify an Yam R1/R6/TDM?
Regards,
Paulo
Regards,
Paulo Sousa
Azores/Portugal
02' TDM900
'71 BSA B25SS
sousap is offline   Reply With Quote
Old 08-27-2006, 10:04 PM   #60
Built to Last
Oddometer: 3,443
Originally Posted by sousap
Hi Woody,
Regards,
Paulo
i've pm'd paulo numerous times trying to find out what his objective is,,,that's something i need to know from any of you wanting trick wheels built,,,
Times are GMT -7.   It's 07:45 AM.
