Old 04-15-2008, 11:07 PM   #766
SimpleSimon
Aspiring advrider
SimpleSimon's Avatar
Oddometer: 3,393
Cafe build wheel questions
I've been daydreaming about a project I'm about to start. As part of that project, I'd like to work over the wheels. I have a 69-71 Honda CB175 with front and rear drum. I'd like to pull the hubs off and powdercoat them black while converting the hoops and spokes to black anodized aluminum to match (excel or DID?). Can you PM me with some ballpark figures on what I should budget? Also, the sizes of the stock tires are 2.75x18 and 3x18...I was wondering if a tire rim width change might make getting conventional street tires easier than the vintage sizes.
Any advice or guidance is appreciated.
Sean
5f? Is that like riding down a 90 degree cliff face into a lake of fire? I thought 4f was bad. Abdelhub
"Assembled Spectator Scoring With Incriminating Photographic Evidence" or A.S.S.W.I.P.E. - Granparacer
SimpleSimon is offline   Reply With Quote
Old 04-17-2008, 07:16 AM   #767
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,362
CB-175 wheel upgrade
Sean
sean,,,we can handle ALL of the above services,,,circa $700 w stronger ss spokes and zartan nippleas,,,does not include tires
regarding tires,,,,i have to ask,,,what is your intended use for this dream bike?,,,and how much clearance do you have on the existing tire sizes????
later,,,woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 04-18-2008, 06:24 PM   #768
Built to Last
Oddometer: 3,362
Billet Hubs for HP2/R12GS/R12GSADV
Check out Woody's newest creation here:
http://www.advrider.com/forums/showp...0&postcount=65
Old 04-19-2008, 03:47 PM   #769
iqbaliqbal
Oddometer: 44
950 Adv superlacing...
Sorry to be redundant- I have this in another post in the Vendor area! I’ll take down the previous posting.
Back in Dec, Chris @ Woody’s helped me with an order; a new front rim & spokes with a Superlace pattern for my ‘05 950 Adv. I’ve put-off building the wheel long enough and I finally unassembled the front wheel this AM.
I checked out http://www.woodyswheelworks.com/superlace.htm to get a better understanding of how to lace the wheel, but I still had a couple of quick questions:
1) Do I apply the brown/reddish fluid to the threads on the end of the spokes (I know, embarrassing Q- go ahead, get out of your system guys!). Is that a thread lock or lube?
2) Is there a larger picture that illustrates how the Superlace looks on the wheel once completed? I’m having a hard time getting my walnut-sized brain wrapped around the Superlace pattern. From the pic on the website, is it safe to conclude every spoke will connect to the rim at that ‘near 90 degree angle’ when using the hub’s diameter as a reference?
I’m sure there’s probably a clearer way to ask these questions, so I’m keeping my fingers crossed!
Thanks in advance for the feedback!
iqbaliqbal is offline   Reply With Quote
Old 04-20-2008, 11:37 AM   #770
Built to Last
Oddometer: 3,362
the rudiments of lacing up you wheel using the SUPERLACE pattern...
the hat fluid is a special formulated anti-seize to be used when tightening ss on ss
your rim was predrilled and countersunk for the new improved x-3 pattern,,,,your oem wheel used a x=2 pattern,,,,assemble the spokes in the hub and 'wind them up so that the spokes going the opposite direction cross 3 spokes going the opposite way,,,,align rim so that when you put the nipple in it points to the spoke that is in alignment with it ,,,do that 36 times and start to snug nipples evenly,,,check the centering left and right,,,,keep on truing your wheel til you are satisfied ,,hopefuly you get to a point where the radial and axial run-out are +/- .020'' 0r less in ALL directions
afterwards,,,:sup er
woody
woody's wheel works screwed with this post 04-24-2008 at 05:24 AM
Old 04-21-2008, 11:25 AM   #771
iqbaliqbal
Oddometer: 44
Originally Posted by woody's wheel works
your rim was predrilled and countersunk for the new improved x-3 pattern,,,,your oem wheel used a x=2 pattern,,,,assemble the spokes in the hub and 'wind them up so that the spokes going the opposite direction cross 3 spokes going the opposite way,,,,align rim so that when you put the nipple in it points to the spoek that is in alignment with it ,,,do that 36 times and start to snug nipples evenly,,,check the centering left and right,,,,keep on truing your wheel til you are satisfied ,,hopefuly you get to a point where the radial and axial run-out are +/- .020'' 0r less in ALL directions
woody
I think I understand!
So using a clock’s face as a reference, if I had a spoke pointing to 10:00, that spoke would have 3 spokes crossing its path – say to 12:00, 2:00 and 3:00?
Old 04-21-2008, 09:40 PM   #772
Built to Last
Oddometer: 3,362
how to tell your lace pattern...once more
when you follow the path of one spoke from the hub to the rim.....
count how many spoke going in the opposite direction that you have crossed..
that equals the lace pattern,,,ie cross none= radial lace,,,cross 1spoke=x1,,,cross 2=x2 etc
the smaller the hub diameter the more crossing you'll need ,,conversely,,,the larger the diameter of hub for the same diameter rim you'll need less crosses to get that optimal 90degree angle
woody
Old 04-22-2008, 08:39 AM   #773
Built to Last
Oddometer: 3,362
Custom Hawk Project
These photos are from a custom Hawk GT 650 Project.,,,,,the idea is to make awire wheeled dual sport out of the road-bike,,,,since the original mags were inappropriately sized and had a rather large dish/offset to the left on the rear wheel,,,we had a few hurdles to overcome,,,VOILA,,,a few months later thanks to reconfiguring a Superlite BMW rear hub we lucked out,,,,Buchanans custom drilled a4.25x17 excel to my specs,,,,we missed the center'line of the bike and the centerline of the wheel by a whopping.0005''
the front wheel was straightforward 21'' using RAD hub
Below are a couple photos of the rear wheel. Comments and more photos to follow:
left side view with spindle/axle in place,,,,
right side view of rear wheel with mounting cone and axle nut,,,,
i usually sign off on my handiwork,,,someone has to claim responsibility
woody's wheel works screwed with this post 04-22-2008 at 12:25 PM
Old 04-22-2008, 11:44 AM   #774
TymeRider
TymeRider's Avatar
Oddometer: 373
From another Woody thread:
Originally Posted by WaterOx
So I spoke with Woody again today and the options at this point (for the X Challenge) are:
1. use BMW OEM hubs and superlace to Excel rims
+ less expensive and no customization required
+ yields good strong wheelset
- no trick looking, lighter hubs
2. use RAD KTM hubs, use KTM rear rotor and sprocket set, use stock front rotor, add some Woody work and superlace to Excel rims
+ trick RAD hubs
- requires using KTM rear rotor and sprocket
- slightly more money since can't re-use BMW rear rotor/sprocket
3. wait until RAD or someone else is willing to make BMW XCh specific billet hubs...Woody is currently tied up with the HP2/R12GS custom hubs
I chose option #1 for my purposes...I don't care about bling. That said, Woody is great to work with and will build almost anything you come up with.
Woody or Chris: please correct me if I didn't capture the currently available options correctly
Woody, a couple questions:
1) Are these still the options for X-challenge wheels or have you made your superlite hubs for the X-Challenge?
2) Do the RAD KTM hubs use larger bearings than the stock X-Challenge hubs?
3) When I've decided on a desired configuration and want a quote, should I call you, send you a PM on here, or email you?
2007 BMW G650X Challenge
2005 KTM 950S Adventure
2002 BMW R1150GS Adventure
TymeRider is offline   Reply With Quote
Old 04-22-2008, 12:15 PM   #775
Built to Last
Oddometer: 3,362
still no Superlite hubs for the X=challenge
still in hibernation
can't pull that answer off the top of my head,,,,i believe they were bigger and i basicallu swapped bearings and spacers
any of the above works
thank u 2,,,waiting to hear from you
woody
Old 04-22-2008, 12:23 PM   #776
winterhk
*Disminuya Su Velocidad*
winterhk's Avatar
Oddometer: 2,316
Hey Woody and crew,
I have a bungled rear wheel on my 2000 1150GS. I need 7 spokes and seven nipples and no dealers have them and they're months out from the factory in Germany. Do you have any spokes/nipples you'd be willing to sell? Or do you only build wheels and such?
Thanks,
Brian
It's one thing to tempt Fate, and another thing entirely to spill its drink and step on its blue suede shoes.
winterhk is offline   Reply With Quote
Old 04-22-2008, 12:40 PM   #777
Built to Last
Oddometer: 3,362
we've got the parts,,,but do you have what it takes to fix it????
Originally Posted by winterhk
Hey Woody and crew,
Thanks,
Brian
hi brian,,,send me an address and the parts will be on their way,,,,there are enough previous posts on installing a few spokes,,,,
just be forewarned that dealing with x-laced rims is a major brain exercise,,,, put em all in gently and tighten evenly,,,til they sound like their neigbors...and make sure the rest are at least snug,,,
again,,,a wobbly wheel with tight spokes will at least get you further than one with loose and missing spokes,,,chill on the speeds you carry,,,,because the remaining 33 spokes have been doing the work of 40,,,,expect some of these to snap too !!!!!
good news is we can help ya down the road and rebuild it for far less money than anew one,,,besides it'll end up truer and stay true longer to boot
holler if we can be of assistance,,,
woody
OBTW,,,,don't forget the lil grub screws hiding way down in the nipples,,,they've snookered more than one wheelsmith,,,myself included
woody's wheel works screwed with this post 04-22-2008 at 01:59 PM
Old 04-22-2008, 04:54 PM   #778
GaelicDog
Lesser of Two Weasels
GaelicDog's Avatar
Oddometer: 7,322
Woody, you have a set of wheels for sale on you site for the KTM 125 to 525, black Excel rims with orange Talon hubs. Will this set up fit the 2008 530 XCRW's?
Political Correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
GaelicDog is offline   Reply With Quote
Old 04-22-2008, 06:34 PM   #779
Crashed Bad
Big man, little bike
Crashed Bad's Avatar
Oddometer: 2,195
950 Adventure rim
Hi Woody,
How much to replace the front Behr Rim (hoop only, reusing my spokes and hub) with Excel (double label or A60, whatever you recommend) and what is your turn around time?
Thanks,
Rick
Nothing upsets a woman like a man at leisure.
Crashed Bad is offline   Reply With Quote
Old 04-23-2008, 05:56 PM   #780
Built to Last
Oddometer: 3,362
G650 X-Challenge options
These are still the options on the X-Challenge. We can do the front billet RAD hubs without much difference, but the rear billet hubs are a ways out. The stock hubs are the only matching hubs available at this time.
The bearings are 52mm OD on the Rad's and 42mm OD on the G650's.
If you're intersted in getting a quote, please e-mail me at: woodyswheelworks@gmail.com or call us at the number below.
Thanks,
Chris
Times are GMT -7.   It's 09:34 PM.
