Old 11-27-2008, 09:07 PM   #991
Lav1200
Pig Pen
Lav1200's Avatar
Oddometer: 1,263
Fit of inner spacer between the wheel bearings...
Hi Woody:
On my Husky TE610, the inner spacer is just slightly longer than the space between the rear wheel bearings when both bearings are seated on the shoulder of the hubs. The result is that when I am replacing wheel bearings, they usually end up applying some preload to the spacer. Should I be reducing the length of the spacer slightly so that it fits with no preload?
Thanks.
Lav1200 is offline   Reply With Quote
Old 11-27-2008, 09:17 PM   #992
Bruce
Bruce's Avatar
Oddometer: 91
Is there any wheels that can be used on a KLR to run tubeless
Bruce is offline   Reply With Quote
Old 11-28-2008, 04:46 AM   #993
Gedjack
Oddometer: 94
Originally Posted by woody's wheel works
we compiled a list of tire sets for you,,,and forgot it at the shop,,,will pick it up manana
OBTW,,,how did you like the Road Attacks and the 19/17 set-up over the oem 21/18????
Total transformation, love every minute of it, worth every penny
Gedjack is offline   Reply With Quote
Old 11-28-2008, 07:53 AM   #994
The Toad
Let There Be Light
The Toad's Avatar
Oddometer: 1,159
11GS rusty spokes
Recently picked up an 11GS.. its got several rusty spokes... rust has eaten away top layer (i assume chrome???) on many spokes...
is there any way of saving these spokes and preventing it from becoming any worse ???
is it possible for a backyard mechanic to replace spokes on these wheels or is this a job for a spcialist ???
does the cost of repairing/replacing make more sense to just buy new or new/used ???
I know its near blasphemy to ask.. but are there any non-spoke wheels (maybe RT) that are a direct fit ???
am asking the right questions in the right place
MondoMotos - LED Auxiliary Light Kits - Tusk Panniers
RoadRUNNER Magazine - Blog
Ride Reports - Four Corners - Amish Country - Costa Rica - Expedition Michigan (or not) - Tellico Plains
The Toad is offline   Reply With Quote
Old 11-28-2008, 09:22 AM   #995
dbhummer
Oddometer: 5
21/17 or 21/18
Hi Woody,
What can you tell me or advise me about putting a 21" wheel on the front of my "07 R1200 GSA I have heard the 21" wheel will improve handling in sand and gravel. Do you think it is worth it? Or would a 21"/18" combination be better.
I love the look of the wheels I've seen posted : ) So you should consider me a new customer trying to figure out what i should order. Thanks so much for all your help.
dbhummer is offline   Reply With Quote
Old 11-28-2008, 01:45 PM   #996
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,424
whoa!!!! there IS a reason why inner bearing spacers are longer!!!
Originally Posted by Lav1200
Hi Woody:
Thanks.
folks,,,your inner spacer between the ball bearings on th emajority of bikes should be minimally circa .010"" for a steel spacer and .020'' if you have an aluminum spacer...longer than the edges in tha hub that the outer races of you bearings rest against!!!
this way you allow the crush on all the components that you are squeezing together when you tighten your axle NOT to put unwanted side loads on your bearings between the inner and outer races
the only bearings that operate ok with pre-tested sideloads are on tapered bearings,,,ala BMW using 9inch lbs of drag when tightened to a pre-scribed torque value circa 28 ft/lbs on front axles and 32 ft/lbs on their back axles.
Harley on the other hand had the loosest end play norms resulting in you always feeling like you were riding on a bunch of little marbles,,,circa .003-.018''end play,,,we always made a trick machine steel custom spacers and set the endplay to.001'' +/-.0005'',,eventually after many years and many talks to hog owners groups they came out with their 'new ' shim pack and identical bearing spacer material and a new norm of .003-.006''..
OBTW on all BMWs i set them up to .000'' endplay,,ie the axle turns freely with no endplay at the desired bmw torque spec...NEVER ever had a bearing set-up spin or fry and no adverse handling issuesremember spun/burned up bmw bearings are the bane of that marque if you do not have them
properly set-up and follow through with replicating the exact torque settings specified...
'nuff said on that
woody
ps,,,someday i'll regale you with the story of how i personally learned about endplay and preload,,on my first BMWR75/5,,,highlights include freezing the front bearings up while toodling along @85mph in the fast lane and needing a sledge hammer to knock out my front axle!!!!
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 11-28-2008 at 02:06 PM
Old 11-28-2008, 02:05 PM   #997
Built to Last
Oddometer: 3,424
the benefits/negafits of going to 21'' front wheels on your GS series BMWs
Originally Posted by dbhummer
Hi Woody,
for general true dual sport riding especially in more challenging dirt terrain you WILL APPRECIATE and note the improvement at the expense of no longer being able to smoke through the twisties on the pavement
search for yellow pig's great assesment report somewhere in this thread several years ago...i wouldn't worry about swiching to an 18'' rear,,,i've got this combo on my own R1200GS as i write...it' handle great but raise the ass end an extra inch for my vertically challenged inseam,,,true i have a greater selection of knobbies available,,,but the 150-70x17 oem rear size allows me to go alittle slower throught he tricky stuff the larger 18'' knobbies raises the gear ratio a bit.... and with the 21'' front and oem rear size you essentially raise th front 3/4'' inceasing trail and making the bike feel more stable in the dirt and everywhere
i have a variety of ways to put a 21'' up front including the bmw x-laced tubeless oem style rims ala HP-2 or R100 GS/PD
woody
Old 11-28-2008, 02:28 PM   #998
Built to Last
Oddometer: 3,424
some tips for rusty X-laced BMW wheel spokes
so sorry,,get rid of em sooner rather than later!!!!
you can replace one or two that have snapped,,,i've posted several times already on the steps involved ....the old chrome spokes are fairly brittle and usually snap/crack right under the head,,,most folks would agree that x-laced wheel repair is a specialist's domain,,,and yours truly has mastered the mystery of that art
FYI,,,since BMW sez they are unrepairable,,,they'll want you to buy another one circa $1100 these days,,,used ones are fetching circa $500
i can rebuild yours with the upgraded ss spokes and nicer nipples,,,the PER WHEEL costs are:
1,,,ss spoke and new powdercoated nipple kits are$190
2,, labor $200+/-30...realistically though in your case...with rusted spokes etc it is an enormous job dismantelling and prepping the rim so count on the upper limit for sure...
HOWEVER...IF you dismantle the wheel and provide me a perfectly prepped rim ie NO crud/dirt in spoke holes at all,,,i only charge $150 for a X-lace lace and true...the best part about it is you'll get a wheel that will be truer than a new OEM unit and will hold the true longer than an OEM wheel
no problem,,,yes there are some mag front wheels that interchange
so there ya have it...several day turn around for your wheel...and if ya want to make them purty/bling/etc,,,you're at the right spot too. nows the time to upgrade,,,whatever lights your imagination 'cept chroming em or asking me for the oem gold HP-2 and Adventure blue/purple ...later woody
woody's wheel works screwed with this post 12-15-2008 at 09:22 AM
Old 11-28-2008, 02:34 PM   #999
Built to Last
Oddometer: 3,424
tubeless wheels on KLR
we have buildt tubeless wheels for this bike but only with rims that sport a safety bead,,,i also don't do the 21'' any more...this also means there won't be a rim-lock on the rear
woody
Old 11-28-2008, 03:16 PM   #1000
dbhummer
Oddometer: 5
woody
OK then that's a very direct answer and I thank you for it. I saw on one these many pages a custom lightweight hub with your superlace system. Would it be possible and advisable to get a Trio of those wheels two fronts 21" &19" as well as the 17" rear wheel? And while you are at it could you put some rubber on them as well? I did warn you that I really wanted to be a customer.
Old 11-28-2008, 07:23 PM   #1001
Built to Last
Oddometer: 3,424
with my time and your dime we can accomplish anything
sort of joking,,,,what ya need to know is that i traverse a very broad spectrum of needs and wants from my customer base,,,,
you will hear it from me time and again...'tell me where you are and what you hope to achieve and i'll help you get there ,,,as reasonable and directly as possible,,,
my Superlite wheels actually cost about the same as an oem wheel 'cept are stronger and 4-5lbs lighter,,,and waaaaayyyy better looking,,,,in a variety of colors to boot
inuff said,,,call me toll free at the number below,,,it's easier on me..woody
woody's wheel works screwed with this post 11-29-2008 at 01:32 PM
Old 11-29-2008, 06:29 AM   #1002
Gedjack
Oddometer: 94
Woody, any news on that tyre list yet ?
Old 11-29-2008, 10:45 AM   #1003
Built to Last
Oddometer: 3,424
amnesia and multitaskin gwoes...
well i went to work yesterday ,,,found it ,,set it out ,,and walked right past it on the way out the door
getting old and multitasking DO NOT mix
am walking out the door,,,heading to shop to try again
wish me luck,,,or remind me in half an hour...
woody
Old 11-29-2008, 01:30 PM   #1004
Built to Last
Oddometer: 3,424
alternative street tires for 950/990 KTM ADV with 19/17 setup
Hi Woody and Chris.
I purchased a set of 19" 17" wheels off youb earlier in the year for my 990 Adv. I have Conti Road Attacks on them and i was wondering with the exception of the Conti's what other road rubber are your customers using on this wheel set. It will only be used on the road.
Regards Steve
Metzler Roadtech Z6 100% 110/80x19 150/70x17
'' Tourance 95% street x 5%dirt
michelin Pilot...100% same size
BridgestoneBT020...100% same sizes
Pirelli Scorpion Sync 95%x5% dirt same sizes
Continental Road Attack...100% same sizes
Dunlop D607...95%x5%...same sizes
,,,and here's what 'gedjack' thinks of ths conversion: ''Total transformation, love every minute of it, worth every penny''
...ok,,,woody
OBTW...these will work for any wheel we build for any bike with our 19/17 set-up
woody's wheel works screwed with this post 12-02-2008 at 03:09 PM
Old 12-02-2008, 12:26 AM   #1005
Tony990adv
Oddometer: 32
Thumb KTM 990 adv wheelset request
Hi Woody,
Ive own my KTM990ADV for 2 years, Im satisfy with its sound, engine output and light weight, but due to most the weather in Taiwan is wet (and Im lazy to wash and dry my bike every time after riding ), the stock spoke has already rusted , and since most of my journey are on flexuosity mountain blacktop road, it is not very good handling in both small low speed and large high speed cornering (compare with 1200GS), as I check from internet it seems Woodys wheel work is the most recommended solution to resolve my KTM990ADV wheelset problem .
Please give me an advise of type and size of wheelset and please also advise front and rear sprocket size, please PM me for quotation with shipping fee to Taiwan and how to pay for this order, Thanks a lot!!!
BTW, due to KTM dealer mention change size of wheel might impact to ABS warranty, I don't really care about that, but in your experience, anybody has met ABS problem after he/she change wheel size?
Thanks and best regards
Tony990adv
Tony990adv is offline   Reply With Quote
Times are GMT -7.   It's 08:54 AM.
