Old 03-29-2009, 10:23 PM   #1126
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,362
a quickie lesson in x-lace wheel tightening
Originally Posted by TheEnglishman
I've just been flicking all the spokes on my R1200GS wheels. The majority of the spokes 'ping' about the same pitch. However a couple (one front and 2 rear) sound noticable lower in pitch.
Is that something to be expected???
As far as I can tell, the run out ???(wobble) is almost completely true on each wheel - certainly less than 1mm.
P.S. - Have I missed a 'guide' on how to check your spokes and what to do if you find a dodgy/broken one???
hi..you need a 5mm allen or t-40 torx bit depending on early or late vintage wheels...plus a 2mm allen wrench for the grub/set screws inside your nipples
1,,,locate the dead ones
2,,notice if it is going clockwise or ccw
3,,use the allen or torx bit and loosen nipple 1/2 turn ccw,, i do this to take pressure off the lil set screw
4,,use 2mm allen to unscrew the grub-screw several turns
5,,tightn the nipple slowly so that it sounds the same as the spokes to the left and right of it that are going in the same direction,,,
6,, stop when they have the same pitch
7,,tighten the grub-screw to 2Nm,,ie snug it up
8,,repeat process on the other loose ones
9,,this same technique can be used in replacing a broken spoke
10,,,DO ONLY ONE SPOKE AT A TIME!!!!,,or else,,well i won't go there
'nuff said
woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 03-29-2009, 10:25 PM   #1127
Built to Last
Oddometer: 3,362
rear spoked wheel for Kawasaki Versys
Originally Posted by benh
This thread is getting long; I did a search with little return, but...
What is the possiblity of making a rear spoked hub for a Kawasaki Versys? Is this possible, any ball park figures on price?
sorry haven't seen one,,but will look at it when i get the chance...
woody
Old 03-30-2009, 07:18 AM   #1128
mag00
Outa Control Dave
Oddometer: 421
Looking for a set of spoke wheels for a 09 GSA to run knobies on, do you get stock take offs?
2012 Ducati Multistrada
08 SE Ultra,
2012 Triumph explorer 1200
09 R1200GSA
IBA #25226
mag00 is offline   Reply With Quote
Old 03-30-2009, 09:48 AM   #1129
Built to Last
Oddometer: 3,362
stock wires for BMW GSA
magoo,,,i'll put you on the waiting list
i have several new rear wheels and could probably build you a nice front,with a new hub,,and reconditioned rim/spokes/nipples
holler if that would work,
woody
Old 03-30-2009, 07:23 PM   #1130
mag00
Outa Control Dave
Oddometer: 421
Might as well get in line for a set, thanks.
08 SE Ultra,
09 R1200GSA
IBA #25226
Old 03-31-2009, 11:52 PM   #1131
tdv
Oddometer: 134
17" supermoto wheels for BMW XChallenge
Hi Woody,
I'm considering a set of 17" supermoto wheels for my XChallenge (in black). Basically, something very much like this: http://www.advrider.com/forums/showp...&postcount=806
How much would that be (with all your hardware, including hubs, + distanza tires)?
Dmitri
If only I knew what I'm talking about!
tdv is offline   Reply With Quote
Old 04-01-2009, 05:48 AM   #1132
Built to Last
Oddometer: 3,362
17' supermoto wheelset for Xchallenge
Originally Posted by tdv
Hi Woody,
Dmitri
dmitri,,that link had the basic price of circa $2100 for everything minus the discs.
what do you mean by "all my hardware"...???
clue me in ,,,so that i know what you are talking about,,,,thanks
woody
Old 04-01-2009, 05:59 AM   #1133
Built to Last
Oddometer: 3,362
pics of Neil Reynolds..my secret ''test driver'' for 21'' R1200GS
Unbeknownst to many of you i have a private testing crew scattered about...i figured it's time to share....so i'll start with an ol stalwart roadracing and canyon carving buddy of 35 years..Neil Reynolds
1..flogging the 21'' tubeless x-laced on oem front hub out in the desert.... http://picasaweb.google.com/EarthRid...79594155621202
2..his unique way of checking for tire wear...
http://picasaweb.google.com/EarthRid...77054657351394
3..heading down this humongous hill in antelope Valley,he reports: "FURTHER WHEEL TESTING: THE TALLER 21" FRONT WHEEL RAISES THE FRONT END UP AND MAKES DOWNHILL RUNS LESS INTIMIDATING ... ON THE OTHER HAND, GOING BACK UP STILL REQUIRES BIG THROTTLE AND BLIND LUCK... ANTELOPE VALLEY 3-28-09" during one of "EarthRider's" Skilz-drillz,,photo to come
more to come
woody
PS.....for those out west..i highly endorse these dualsport training gurus
1....Blaine alias EarthRider" at http://earthrider-amgi.blogspot.com/
2....Jim Hyde at http://www.rawhyde-offroad.com/ this is a fun video intro
and the main website : http://www.rawhyde-offroad.com/home.html
woody's wheel works screwed with this post 04-01-2009 at 06:23 AM
Old 04-01-2009, 12:30 PM   #1134
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,295
G650X wheels
Woody,
I'm looking to get the rims on my G650X fixed/replaced.
I need pricing and delivery on 2 options:
1. Rebuilding my wheels with upgraded rims & spokes.
2. Purchasing a complete set, sans brake rotors.
Thanks,
Tim
tbarstow is offline   Reply With Quote
Old 04-01-2009, 04:06 PM   #1135
Built to Last
Oddometer: 3,362
G650X wheel upgrades
Originally Posted by tbarstow
Woody,
Thanks,
Tim
hi tim just answered something similar
1..circa $800-900 depending on color,,superlaced on rims of your choice
2..circa $1.8-2k depending color/sprocket/etc supelaced of course on oem hubs...which seem plenty strong and light
woody
Old 04-01-2009, 04:57 PM   #1136
tdv
Oddometer: 134
woody
I think you answered my question in another post, but I meant you supply the rims, hub (oem, right?), sprocket, etc, sans brake discs.
Basically I want a second set of wheels except for brake rotors (and keep the stock ones for dirt).
Dmitri
Old 04-05-2009, 12:42 PM   #1137
olasjet
Sancho
olasjet's Avatar
Oddometer: 33
Props to Woody's Wheel Works
Woody,
I was so impressed with how quickly you got my wheel back to me. I shipped it to you on a Thursday and it was back on my bike on the following Tuesday. You did exactly as I had indicated and everything looks and works great. You took care of the rotors and braking is as smooth as butter, but stops a lot faster. Before being shipped overseas, I took it out for a spin and it is nice to run very high speeds without the flat spots and wobbles again. Thanks for all of the professionalism with you, your staff and the entire shop. These days, it is hard to find such great service. I will never hesitate to send you my wheels again and will always recommend your shop to anyone. Thanks a ton!
JT
olasjet is offline   Reply With Quote
Old 04-06-2009, 09:49 AM   #1138
muddyrabbit
Lost Boy
muddyrabbit's Avatar
Oddometer: 3,765
Hey Woody, I'm curious if any race teems are using your wheels and who they are. Mostly for my own curiosity, but I also have a friend who is a non believer of anything he isn't familiar with.
muddyrabbit is offline   Reply With Quote
Old 04-07-2009, 06:04 AM   #1139
Built to Last
Oddometer: 3,362
race teams using my wheels and services...hmmmnn
well,,most recently Team Max BMW won last years Sand blast Rallye Moto 1st &2nd place in the mega class using my Superlite/Superlace set up..ran all season without touching the wheels....last check revealed no loose spokes and amazingly still straight and true to boot!!
Chris Jones ran and finished the previous years Paris Dakar on just 2 wheel sets,swapping rubber at days end,,came to the shop with 10 wheel sets to be superlaced...talked him into trying 2 sets with my cush drive set-up[ one rear using oem KTM SM hub assy and the other with the first billet prototype]..again never touched the wheels...and NO Problems with transmission or chain stretch!!!
M3 -Racing and lot's of the AHRMA vintage racers have won championships on the Superlaced set-ups i make for them...
Team Eye-Ball Engineering not only won the AHRMA 350 GP class for the first time evr on a highly modified 305 Honda Superhawk,,but then went on to Japan's 'Time tunnel world championship shootout at Tsukuba' to win the Super Vintage Senior class,,set a new track record with legendary David Roper doing the riding chores....that was a fun project and wonderful season...lot's of tall tales to tell someday
Team Spirit my own roadrace team has won more overall #1 plates and class championships in the rocky mountain region...'nuff said..
I have wall's full of pics and attaboys.....you ought to stop by sometime,,,it's been written up in Cycle News as being 'one of the better watering holes in the west'
my favorite racing team consists of my happy customers,,,they provide me a deeper quieter form of satisfaction,,,,
yours truly
woody
woody's wheel works screwed with this post 04-07-2009 at 10:20 PM
Old 04-07-2009, 08:02 AM   #1140
muddyrabbit
Lost Boy
Oddometer: 3,765
Any GNCC or SCORE teams by chance?
Times are GMT -7.   It's 07:09 PM.
