Old 05-03-2009, 09:50 PM   #1171
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,431
Originally Posted by Odysseus
Woody, I was in the shop about a month ago getting my rear wheel trued (rear tire blow out and running on the rim for a bit) and a little birdy told me that you are working on a new and improved tubeless system. Any news on that?
Also what do you think of the Nuetech Tubliss system?
BTW other than a couple of dings from the previous mentioned 50 MPH rear blowout the wheels you built for me 2 years ago are still rolling along perfectly.
the latest version is working better than expected,,ran into a little glitch,,that we caught and corrected,attention to detail...the devils in th eprep and application,,,
regarding the othe rsystem have nothing to add or commen ton ...sorry hav eno experience with it..woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 05-03-2009, 09:56 PM   #1172
Built to Last
Oddometer: 3,431
sealing/tubeless F800GS wheels...
Originally Posted by Stuntman
Hey Woody,
RE: 800GS wheels
What is the turn around time for this? Also, what do you think the longevity of this conversion is?
FYI the rear wheel poses no problem,,,i highly recommend getting the wheel trued before doing this,,, the front wheel is a 21''er and has no safetybead,,so NO GO!!,,,,,,!i've got several years on mine and i know customers that i've done this 10+year ago and are still riding around on the sealing job.
i have even more faith in our current version
woodys
ps..turnaround time 3-4 days
Old 05-03-2009, 10:03 PM   #1173
Built to Last
Oddometer: 3,431
low budget DRZ 19 upgrade
Originally Posted by Wreckluse
Hi Woody,
Could you get me a cost to lace up a stock DRZ front hub with a black 19" Excel rim and stock spokes, shipped to Calgary, AB
Thanks,
Wreck
circa $400 plus a hub...i assume you are sending yours in???if not add another $250 +/_ holler n thanks
woody
Old 05-04-2009, 07:43 PM   #1174
Stuntman
Stuntman's Avatar
Oddometer: 677
woodys
Thanks for the info Woody. I'm very interested in doing the rear then. Can you give me a ball park figure for re-lacing the front wheel with a R100GS 21" tubeless hoop?
Bring a compass, it's awkward when you have to eat your friends.
Stuntman is offline   Reply With Quote
Old 05-05-2009, 09:28 AM   #1175
Built to Last
Oddometer: 3,431
R100GS/PD tubeless 21'' front x-lace rim to F800GS
sorry ,,,no can do ...the x-lace rim is 40 holes and the nipples are in the hub,,F800GSs run 36 hole rims/hubs,,,simply can't reconfigure it...
there's a chance to do that with the Aprillia Caponard rims which have the x-laced /tubeless configuration like BMWs THEIR NIPPLES AE IN THE OUTER EDGES OF THE RIM,,but only available in 2.5x19''
back to the drawing board
woody
Old 05-05-2009, 09:51 AM   #1176
Herms
Oddometer: 24
KLR650 18" front conversion
Hi there
I live in South Africa. My front rim on my KLR650 is cracked and needs replacing. I'd decided to go for a 18" rim upfront. I can find no-one in my country that has done this conversion yet. I can get a 18" rim on my side, but the right length spokes is my problem.
Will it be possible to make up a kit of the correct length spokes and mail to me in South-Africa?
If not, will you supply me with the correct lengths so that I can try and source the spokes in South Africa.
I appreciate all the help and info.
Thanks!!
Herms is offline   Reply With Quote
Old 05-05-2009, 10:46 AM   #1177
Built to Last
Oddometer: 3,431
KLR650 18'' front wheel kit
Originally Posted by Herms
Hi there
Thanks!!
hi herms et al,,
we can supply a complete kit WM-3/2.15 x18 7000 series alloy rim predrilled for your hub $$140 and 8g ss spokes and ss nipples $105 OR with zartan nipples $95
your choice...pick n choose
remember you have to have properly drilled rims to match the correct spoke angles on your conical front hub...
if this won't work for you ,then i'll see about spoke specs...that's like asking a bartender for his secret recipe,,but hey when you are in god's country why not be generous...can only enhance WWW's karma
,woody
Old 05-05-2009, 12:30 PM   #1178
Herms
Oddometer: 24
Thanks Woody
I sent you an email to your shop address with all my details
Hope to hear from you soon.
Old 05-05-2009, 06:24 PM   #1179
Stuntman
Stuntman's Avatar
Oddometer: 677
woody
What's 4 spokes among friends anyways? Ugh! Thanks anyways! I'll e-mail you a little later regarding sending you my rear wheel for conversion to tubeless.
Old 05-06-2009, 08:55 AM   #1180
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 671
1985 Honda XL600R
Woody,
Old bike question here on my Honda XL600R dualsport. I have an extra rear wheel (17" rim) for my bike. If I want to swap this 17" rim onto my front hub instead of the stock 21" rim, how do I figure the spoke size for the swap?
Or is it feasible for me to ship you the front hub and the 17" rim and let you sort it out? (cost estimate?)
Thanks,
Eric
mrfixit54016 is offline   Reply With Quote
Old 05-06-2009, 11:21 AM   #1181
Built to Last
Oddometer: 3,431
rear 17 rim to front Honda XL600R hub swap
Originally Posted by mrfixit54016
Woody,
Thanks,
Eric
Eric et al,
there's an outside possiblity that we can re-angle/countersink the holes in your rear rim to match your front hub pattern...
your best bet is to send in all your stuff complete,,,so we get proper offsets,,,we always try to recycle as much as we can ,,,give ya a little credit toward putting a good combo together..BWOE,,if we have a 17 rim that'll work better for you ,,,and yours is in good shape we'll work something out,,
ok..least expensive way is $80 for custom lace n true,,$30 re-angle /countersink,,,,spoke kit anywhere from $60-105 depending if we use a good take-off spoke set or ss spokes n nipples
woody
woody's wheel works screwed with this post 05-06-2009 at 09:03 PM
Old 05-15-2009, 10:09 PM   #1182
1224R
Oddometer: 2,086
Woody, i picked up a spare set of Rims for my 07 Bmw Adv for a great deal knowing they have a slight "wow' to them, slight flat spot like they took a very hard landing to them.. it is very slight... I could almost use them as is but i want them to be true.all the spokes sound ok but what the hell do i know!!!..In your Masterful experience can little "wow's" like this be repaired?? If not how much roughly to replace with stock hubs? Thanks Sir...
1224R is online now   Reply With Quote
Old 05-16-2009, 12:48 AM   #1183
kktos
on a bright side of life
kktos's Avatar
Oddometer: 2,345
you should post a picture of them. will be easier for the Doc ;)
Vita brevis, ars longa, occasio praeceps, experimentum periculosum, iudicium difficile
08 R1200GSA Red 21" woody's
morocco 2006 | morocco 2007 | Traces of Kimangao: An HP2 in France, Spain and Italy | Morocco 2008: a F800GS test ride | where the destination is Anamur - Turkey via Greece...
kktos is offline   Reply With Quote
Old 05-16-2009, 11:24 AM   #1184
pitriver
pitriver's Avatar
Oddometer: 14
BMW Airhead 17mm to 25mm front axle
Woody, I'm interested in installing a later Bmw fork with a 25mm axle onto a bike which originally had a 17mm axle. Do you know whether the spoke type hub could be safely machined from a 40mm o.d. bearing size to 47mm? Also, do you know whether the newer type hub could be laced to an older type rim with the spokes in the center? Thanks much, Jonathan.
pitriver is offline   Reply With Quote
Old 05-16-2009, 11:37 AM   #1185
fortrider
fortrider's Avatar
Oddometer: 264
aprilia dorsoduro
Woody,
Do you think you could do a hub and wheel set up for a 2009 Aprilia Dorsoduro?
17 or 18" rear with a 21" front.
Thanks,
Steve
fortrider is offline   Reply With Quote
Times are GMT -7.   It's 07:58 PM.
