Old 06-23-2009, 07:29 PM   #1246
fire_strom
fire_strom's Avatar
Oddometer: 1,257
I think option five might be the best. I need to sort this out and I should stop kidding myself into thinking I could build a strong wheel, let alone a safe one. Some things are better left to pros.
Originally Posted by woody's wheel works
NO PROBLEM
your choices are:
1,,get rim with euro indexing,,,ooops none available in A60
2,,upgrade to a Superlace,,send in your hub and rim and we will re-drill/angle one side of your rim and create a x3 lace pattern ie jumping over to he next hole that is pointing in the correct direction,,the other side stays x2 ie oem pattern,,,you'll end up with a stronger wheel to boot not just a stronger hoop,,remembe rit has to be kept together ,,and i've got that figured out
3,,the ss steel superlace spoke kit costs $120 with ss nipples about $15 less with zartan nipples superlace with 1 year warranty on the lace n true is just $99
4,,if you are trying to keep cost down we can sell you half ie the x3 side of a spoke kit,,ie use half your old spokes and nipples,,,and do all the prep work on rim and you can do the rest ie lace n rue,, or we can prelace and you can true,,whatever your pocketbook and talent can handle..
5,, the othe roption is to trde in your A-6o for one of our correctly drilled rims..call zach at the shop
hope that gives ya a broad range of options,,,
woody in germany
Officially motor free
9 cycles with pedals
fire_strom is offline   Reply With Quote
Old 06-23-2009, 10:05 PM   #1247
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,466
aftermarket hubs for f800gs
It will be some time before the aftermarket hub is created. We are looking into the possibility, feasibility, and the market. Should have a clearer idea in the next month. Keep you posted on the development.
Originally Posted by bumbee800
Woody,
Any estimate when the aftermarket hubs you are working on for the front of the f800gs will be available?
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 07-01-2009, 04:41 PM   #1248
Built to Last
Oddometer: 3,466
Nuetech Tublis Technology now in Stock!
They've been putting everyone off and taking backorders for over a year now, but they are now available.
They are designed for those of you with dirtbikes and/or anything that you run under 25 psi, have 1.85/2.15 x 18/19" or 1.60"x21" rims, and can put a rim lock in.
People have been raving about them, the weight savings, the lack of tube, etc. They are a bit of a pain in the neck to mount, even with the install video, seen here: http://www.nuetech.com/tubliss-video.shtml
The cost for the product is $99. Call or e-mail if you are interested: woodyswheelworks@gmail.com
Old 07-04-2009, 01:04 PM   #1249
Gedjack
Oddometer: 94
Hi Woody,
i purchased a set of 19" 17" wheels off you some time ago for my 990 ADV I have now bought a KTM 450 EXC, would these wheels fit on my new bike so i would have three bikes in one or would i have to get a completely new set ???
Regards Steve
Gedjack is offline   Reply With Quote
Old 07-06-2009, 05:04 PM   #1250
Built to Last
Oddometer: 3,466
rim swapping from KTM 990 adventure to KTM 450 EXC
Originally Posted by Gedjack
Hi Woody,
Regards Steve
BUT will have an answer manannna,,,woody
Old 07-06-2009, 05:08 PM   #1251
Built to Last
Oddometer: 3,466
OEM hubs and aftermarket hubs for F800GS
Woody,
month or two out on the billet,,HOWEVER i have 9 oem hubs on their way from Germany,,so we are ready for your projects,,,woody
PS the first two are here ,,,, the others next week or so.
woody's wheel works screwed with this post 07-08-2009 at 09:15 AM
Old 07-06-2009, 11:55 PM   #1252
wheatwhacker
It's raining here
wheatwhacker's Avatar
Oddometer: 2,984
Here is a pic of the wheel you laced up for my KLR last year.
I now have a dinged front rim on my KTM950ADV.
I need a new rim, stronger and need to lace it to my existing hub. Do you have any recommendations?
European bike sales and storage.
https://www.facebook.com/motofeirme
wheatwhacker is offline   Reply With Quote
Old 07-07-2009, 07:17 PM   #1253
ducwad
Livin' the dash
ducwad's Avatar
Oddometer: 339
950 Adv --> 950 Se
If I bought a pair of 19/17 wheels used on a KTM 950 Adventure for my 950 SE what modifications would have to be done to the wheels? Can the second front disk just be removed or does the hub need to be replaced? If it needs to be replaced do the spokes also? I think the rear is no change, right? How much?
thanks!
- Ducwad
2012 Moto Guzzi Norge
1995 Ducati 900 SS/SP
1992 Ducati 900 Superlight
ducwad is offline   Reply With Quote
Old 07-08-2009, 09:18 AM   #1254
Built to Last
Oddometer: 3,466
upgrading the oem pretzel rim on KTM 950 and LC-4 adventure bikes
No problem,,,i recommend 1.85x21 excel and superlace it to your hub with beefy x3 lace pattern ss spokes n niipples...done deed,,,durable,,stronger better looking too
Old 07-08-2009, 09:23 AM   #1255
Built to Last
Oddometer: 3,466
KTM wheel swap from 950 adventure to 950 SE
thanks!
rear wheel straight swap
front wheel:
1,,you'll need new spacers for your hub
2,,you can run just the left disc on that dual disc hub,,
3,,if ya don't like the disc carrier flanges we can machine em off or swap hubs,,this would just be an aestehetic exercise on your part
that's it..and i bet you'll like that wheel combo on your SE
woody
Old 07-08-2009, 01:19 PM   #1256
Gumbeaux
The Chameleon
Gumbeaux's Avatar
Oddometer: 825
Woody, Any chance you have OEM hubs for the F650GS (thumper, dual spark, 2006)? If not, I will need to send you my originals, I guess. I am looking to upgrade to black excel wheels, 21" front and probably keep the 17" rear (maybe go 18"). I will call your shop in days coming. I got a quote last year, but some things came up and I deleted it...nwo ready to move forward...sorry for the fits and starts....
Gumbeaux
Gumbeaux is offline   Reply With Quote
Old 07-11-2009, 02:33 PM   #1257
Gedjack
Oddometer: 94
Hi Woody,
Regards Steve
Woody, have you got any news for me yet ?????
Old 07-12-2009, 09:57 AM   #1258
Built to Last
Oddometer: 3,466
can we swap 990 ADV wheels with 450EXC???
Hi Woody,
Regards Steve
NO
1,,,,the 990 rear hub is perhaps 11/2'' wider than your EXC,,so you definitely need another wheel here.
2,,,the front wheel may fit BUT has double disc on 990 vs just a single on the 450EXC,,,just checked with zach regarding the swap,,he claims it is a no go ,,different axle diameters and spacers too:(....
woody's wheel works screwed with this post 07-13-2009 at 12:28 PM
Old 07-22-2009, 06:49 AM   #1259
andrewgore
Gremā
andrewgore's Avatar
Oddometer: 3,673
Woody,
I've got a 19" front on my BMW G650XCountry. I was wondering if there was a 21" rim that would be compatible with my OEM hub. My hub has 36 spokes and is the same part as the xChallenge front hub. Thanks!
Andrew
PS. Awesome work on my GasGas rear rim. That thing just can't seem to get hurt.
andrewgore is offline   Reply With Quote
Old 07-22-2009, 01:05 PM   #1260
Built to Last
Oddometer: 3,466
19 to 21 conversion for BMW G650 X country
Originally Posted by andrewgore
Woody,
Andrew
hey you're at the wheel works,,we can make anything happen for a 21'' front conversion
holler when you are ready
woody
woody
Times are GMT -7.   It's 05:42 PM.
