Old 11-18-2009, 03:39 PM   #151
uraberg
whosaberg?
uraberg's Avatar
Oddometer: 691
I don't quite know how this tool pool works, but I have a flywheel puller that I'll happily ship out to whomever needs it. Its an M20x1.5 RH. It only includes the puller bolt. no flywheel stay. I had no problem with a wrench, a rubber mallet and engine compression to get the flywheel off.
Fits:
Honda:
CB750A 1976-1978
CB750F 1975-1978
CB750K 1969-1978
VF500F 1984-1986
XL250R 1984-
XR200R 1984-1985
XR250L 1991-1996
XR250R 1984-1985
Kawasaki:
KL250D 1985-1995
KL650A 1987-1995
Suzuki:
AN650 2003-2008
AN650A 2006-2008
DL1000 2002-2008
DL650 2004-2008
GSX1300R 1999-2008
GSXR600 1997-2000
GSXR750 1996-1999
SV1000 2003-2005
SV1000S 2003-2008
SV650 1999-2008
SV650S 2001-2008
TL1000R 1998-2003
TL1000S 1997-2001
This was typed from the application guide. I can verify that it fits the DL1000.
This is not an expensive tool, but two way shipping is still cheaper.
As a matter of fact, I have a whole bunch of flywheel pullers:
Just the bolts:
M19x1
M14x1.5
M16x1.5
M18x1.5
"push/pull set"
M28x1/M26x1
M25x1.5/M22x1
M27x1(LH)/M24x1
M27x1.25/M20x1
M26x1.5/M22x1.5
M28x1.5
I use some of these on a semi regular basis so I need to keep them here. But I'll send it out to whomever needs it.
uraberg screwed with this post 11-18-2009 at 03:49 PM
uraberg is offline   Reply With Quote
Old 11-22-2009, 06:51 AM   #152
rossthompson
rossthompson's Avatar
Oddometer: 35
I have a few things for use on site here in Kansas City, MO:
TIG welder and I'm always willing to help weld aluminum, titanium, stainless, etc.
MIG welder
Plasma cutter
Tire machine (coats 220) and balancer
Various hand tools for pretty much anything motorcycle related
Most motion pro fork seal drivers from 35mm-48mm
Some flywheel pullers for Japanese stuff
So any ADV people passing through KC who need something just let me know. jrossthompson at gmail dot com or pm me but emails are probably better.
rossthompson is offline   Reply With Quote
Old 11-28-2009, 12:09 PM   #153
The Raven
The Raven's Avatar
Oddometer: 4,811
Lookin for a tire studding tool
I want to stud some tires this winter, but don't have the tool, anyone got one to rent/loan?
The Raven is offline   Reply With Quote
Old 01-22-2010, 10:32 AM   #154
Ratski
Ratski's Avatar
Oddometer: 759
Garage to lend
I have garage space to work in and tools to work on bikes of all shapes and sizes. No Specialty tools but lots of regular ones. (A full auto techs toolbox.) I also have a truck and ramp to pick up dead bikes and am willing to drive a fer piece to help a stranded ADV'er and there is always beer in the fridge.
Ratski, Sheboygan, WI
(An hour north of Milwaukee and an hour south of Green Bay.)
Ratski is offline   Reply With Quote
Old 03-05-2010, 05:39 AM   #155
mmitchell57
Vulcan Halfbreed
mmitchell57's Avatar
Oddometer: 2,193
This is the first time I've seen this thread. It's a good idea. I have some things I'd like to add.
I have at disposal....
Air compressor - 25gallon 6.5hp
Air tools - Cut Off Wheel, Impact Wrench, Air Hammer
Paint Gear - Inline Dryer, Gravity Fed HVLP spray gun, Bottom Fed Regular guns
Enough tools to strip down a bike and build it back up.
It's a small work area, but there's a lot that can be done in it.
I'm in Fayetteville, NC.
Projects - www.Goomra.com
1969 CB350 - Restoration Project
1962 Ford Fairlane 500 - Restoration / DD project
mmitchell57 is offline   Reply With Quote
Old 04-16-2010, 04:40 PM   #156
BmoreBandit
nomo B
BmoreBandit's Avatar
Oddometer: 502
very cool thread
i might need the doo tools, seems like they are traveling around...
nice thread, seems like most of the people posting are on the left coast (does that say something...?)
Heavy is good, heavy is reliable...
A man who procrastinates in his choosing will inevitably have his choice made for him by circumstance.. H Thompson
BmoreBandit is offline   Reply With Quote
Old 04-29-2010, 01:52 PM   #157
isa671
blah blah blah....
isa671's Avatar
Oddometer: 263
R1200GS Locknut tool
Does anybody have the socket wrench insert used to remove the swing arm from the frame on an 07' BMW R1200GS. Thanks in advance!
Science is one cold hearted bitch with a 14 inch strap on. -Masuka (Dexter)
isa671 screwed with this post 04-29-2010 at 02:19 PM
isa671 is offline   Reply With Quote
Old 06-04-2010, 11:19 PM   #158
DesignerRider
Adventures Since 1984
DesignerRider's Avatar
Oddometer: 100
Anybody in the SoCal (inland empire) area have a main bearing puller for rent/loan. My 1997 LC4 is giving me signs of a failing bearing. Thanks!
97' KTM 620 EGS-E Rally Adventure
97' KTM 620 RXC-E (the "e" part doesn't work)
88' Honda XR600
70' Yamaha DT175 Enduro
DesignerRider is offline   Reply With Quote
Old 06-07-2010, 10:39 AM   #159
racedawg
Have bike will travel
racedawg's Avatar
Oddometer: 269
Bearing puller
Have you seen the one that is homemade in the LC4 Thread?
04 KTM 400 EXC plate /
09 KTM 950 SE
racedawg is offline   Reply With Quote
Old 06-08-2010, 08:14 PM   #160
DesignerRider
Oddometer: 100
This one?
I didn't see any details regarding the construction of such a tool. I guess I'd be more apt to do this procedure if I knew I had a worthy tool. Thanks.
88' Honda XR600
Old 06-09-2010, 09:40 AM   #161
racedawg
racedawg's Avatar
Oddometer: 269
This one
Post # 2 in this thread, Looks like a cheap & easy one..
http://www.advrider.com/forums/showthread.php?t=73558
09 KTM 950 SE
Old 06-28-2010, 02:24 PM   #162
jonnycos
jonnycos's Avatar
Oddometer: 52
Tool to put on rear main seal (R1100GS) SF Bay area
Any fellow adv riders have the tools to put a new rear main seal onto the crankshaft. Doing a clutch and drive shaft replacement. Figured I better renew the seals while I got her ripped apart.
Jonathan
415-828-1938 c.
jonnycos is offline   Reply With Quote
Old 07-07-2010, 01:50 PM   #163
Bobthebiker
not normal
Oddometer: 493
If any fellow riders are in the new port richey area and need a hand, or some repair/tools, I have a fairly good set of lots of hand tools, air compressor(s) and access to a stick welder, along with pretty much a complete motorcycle shop in a backyard.
these tools are all on site only, once I move, we'll have garage space for more in depth repairs if need be.
all I need is about half a day's notice roughly and I can have my stuff ready to go.
Where does this road go? screw your maps! we're gonna find out the FUN way!
error 404: common sense not found.
Bobthebiker is offline   Reply With Quote
Old 07-19-2010, 04:53 AM   #164
Wylie
Back in the saddle again
Wylie's Avatar
Oddometer: 2,234
Soon it will be time, LC4 roller bearing swap.
The left peg on my 2001 LC4 is telling me her motor wants the roller bearing swap. I've had all the parts ready to go for over a year but do not have the bearing puller needed for the job.
I plan on going through the bike just as soon as I get my DR 350R running, street legal and stabilized.
How do I go about borrowing a puller for this job?
Okay so I'm not Super Man. I'm just the jack of many trades, master of some yet to find and as the world turns that would only be for a matter of time.
Okay, screw it, stop the world I'm getting off.
Wylie is offline   Reply With Quote
Old 08-08-2010, 07:30 AM   #165
leonphelps
TAT/Prudhoe Bay
leonphelps's Avatar
Oddometer: 1,044
Motion Pro Carb Sync FJR1300
Looking for a Motion Pro carb sync for my Yamaha FJR1300. PM me with details
leonphelps is offline   Reply With Quote
Times are GMT -7.   It's 12:02 PM.
