Old 09-16-2009, 01:19 PM   #1
Mad Kaw Disease OP
Dual Sport Diseased
Mad Kaw Disease's Avatar
Oddometer: 534
Radiator Guard
I've tried searches but as usual end up with 500 threads that have nothing to do with what I'm looking for so....
Has anyone swapped out the stock radiator guard on a 950/990 adventure for the KTM hard parts screen type guard and had any dramatic results running cooler?
I'm looking to run cooler in traffic situations and cool down a little faster coming out of slow speed stuff. I's not a big problem so I don't want to jump into major fixes like a second fan.
2007 KTM 990 Adventure
2014 BMW R1200RTW
"I was going faster than I ever went in my whole life and I fell off...." Little Fauss
Mad Kaw Disease is offline   Reply With Quote
Old 09-16-2009, 01:26 PM   #2
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,474
There are several different radiator guards out there and the cooling obviously varies. There was one available that was made from a fine mesh of wires that I have heard was an improvement on cooling. There is another with slightly thicker slats that has good protection but does not flow as much air. My solution was to take the stock plastic wind diverter and cut out most of the fins. I kept the central spar and 1 or two on the sides and then I covered this over with 1/4" square wire mesh. Flows a lot of air and protects the radiator and it didn't cost anything. Its simple but it works well....though it does not have the bling look of the fancier units.
Seth S
Seth S is offline   Reply With Quote
Old 09-16-2009, 01:36 PM   #3
Mad Kaw Disease OP
Dual Sport Diseased
Oddometer: 534
You say it was a solution so I assume you experienced a positive cooling effect like I am looking for.
I'm not concerned with looks (I have highway pegs on my tank guards) but I have a bug problem too. The stock slats do collect a lot of the gnat splatter...not sure about 1/4" mesh though.
2014 BMW R1200RTW
Old 09-16-2009, 01:47 PM   #4
Patacca
Pimp my SE italian style
Patacca's Avatar
Oddometer: 563
any link to buy one for SE?
THANX
If you aren't sure, open to MAX!!!
www.raffaellophoto.com
check out my pimped SE @
http://www.myktm.it/viewtopic.php?f=50&t=223
Patacca is offline   Reply With Quote
Old 09-16-2009, 01:50 PM   #5
Mad Kaw Disease OP
Dual Sport Diseased
Oddometer: 534
THANX
Didn't see one specifically...here's what I'm looking at.
http://www.ktmcyclehutt.com/ktmstore...ture_parts.htm
http://www.ktmcyclehutt.com/ktmstore...0035040100.jpg
2014 BMW R1200RTW
Old 09-16-2009, 01:56 PM   #6
Patacca
Patacca's Avatar
Oddometer: 563
Originally Posted by Mad Kaw Disease
yes but unfortunatly it is different the one on SE...have you seen my pic?
Old 09-16-2009, 01:59 PM   #7
SS in Vzla.
Totally Normal? I'm not!
Oddometer: 1,193
Short answer: NO, it does not run (noticeably) cooler.
Long answer:
I swapped my OEM radiator guard with the KTM Hard Parts exactly for what you describe... to help the engine run cooler in our HOT tropical heat, in traffic and especially in slow moving off road situations... The fan seems to turn on as fast as with the OEM radiator guard on... I think the bike does not like to go slow, so I might just have to become a better rider
Since every-day 100F + temps are totally normal here, I'm considering hooking up a second fan that I'd switch on manually whenever I consider is needed.
SS. '98 BMW F650 / '06 WR250F / '07 KTM 990 Adv
Caracas, Venezuela
SS in Vzla. is offline   Reply With Quote
Old 09-16-2009, 02:02 PM   #8
Patacca
Patacca's Avatar
Oddometer: 563
Hi please have you gat a pic or a link or what else to show me the part number...., as I dont' like my hand job.....otherwise I will have to buy again the original guard....
Old 09-16-2009, 02:42 PM   #9
SS in Vzla.
Oddometer: 1,193
http://www.ktmtwins.com/950adventure/60035040100.html
Caracas, Venezuela
Old 09-16-2009, 02:52 PM   #10
Gluaisrothaí
Feckin' gobshite
Gluaisrothaí's Avatar
Oddometer: 547
Heat problems
My '09 990 will overheat- 12 bars flashing- if left to idle stationary in 85/90 degree weather, the fan alone can't cool it enough. Even running at 35 MPH in 65 F weather the fan cycles on and off quite frequently, and in stop and go traffic it's on more than it's off.
My '04 950 definitely ran cooler, perhaps something to do with the head2wind jetting that was likely richer at light throttle/low RPM than the EFI.
I'm starting to think there's something wrong. I have done the dynamic flush and made sure the system was fully bled afterwards.
Second fan has been received. It's the SPAL that Pyndon fitted to his 950, I just ordered it directly from SPAL rather than through KTM. It consumes only 25 W (2 A draw at 12.5 V). I confirmed this using an ammeter. Given the small additional draw, I'm going to wire it in parallel with the stock fan to see how much it helps......
2009 KTM 990 ADV
2006 DRZ400SM
1974 Aero Commander 112A (AC11/G)
2010 FJ Cruiser Trail Teams
2013 Tesla Model S 85kWh
Gluaisrothaí is offline   Reply With Quote
Old 09-16-2009, 02:53 PM   #11
Patacca
Patacca's Avatar
Oddometer: 563
thanks but it's adv only....
Old 09-16-2009, 03:08 PM   #12
Tafella
Tafella's Avatar
Oddometer: 85
check the propeller in the waterpump!
Had the same heat problems and they were caused by
a worn out propeller.
cheers
Richard
CARPE DIEM, But not without my KTM !
KTM Adv. 990R '10
KTM Enduro 690R '14
www.lc8.nl
Tafella is online now   Reply With Quote
Old 09-16-2009, 03:18 PM   #13
SS in Vzla.
Oddometer: 1,193
Do you have a link for the SPAL fan?
SS
Caracas, Venezuela
Old 09-16-2009, 03:47 PM   #14
Gluaisrothaí
Feckin' gobshite
Oddometer: 547
I hear ya but
cheers
Richard
Hopefully not the case at 4100 miles! I do get plenty of flow through the radiators, and plenty of heat coming from the fan, it just seems like the engine is putting out too much heat!
2009 KTM 990 ADV
2006 DRZ400SM
Old 09-16-2009, 03:49 PM   #15
Gluaisrothaí
Feckin' gobshite
Oddometer: 547
SS
Here you go: SPAL fan link
2009 KTM 990 ADV
2006 DRZ400SM
Times are GMT -7.   It's 02:17 PM.
