06-25-2010, 11:32 AM
#15001 | ||
Aven'Tourer
Oddometer: 9,744
Experience is what you get when you don't get what you want. |
06-25-2010, 11:38 AM
#15002 | |
PowerPoint ADV
Oddometer: 5,210
And my stuck seat post is Campy SR, so I care a bit about recovering it. The bike it is stuck in is my old team bike. Treviso Itallia, Pinarello so I am proceeding with caution. Don't want to buy the next bike I want quite yet. Aluminum expands more than steel by about 3X. Maybe a heat gun on the frame and a block of dry ice on the post?
...Dick "...the road goes on forever and the party never ends..." - Robert Earl Keen Go Pyndon! Go Ned! Eight Years |
06-25-2010, 11:46 AM
#15003 |
Always Learning
"Goin' to "The Farm" - wherever it may be - makes JM what it is. It ain't the basement - more like a foundation...... and it's better with rough edges." ---DireWolf "Knowledge is an unending adventure at the edge of uncertainty" ----- Jacob Bronowski "I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man." -----Thomas Jefferson Smugmug coupon ----- 5w5TPcXpTtBdw --- Save $5.00!! |
06-25-2010, 04:04 PM
#15004 |
Aven'Tourer
Oddometer: 9,744
omg, this is like a disease.
went out at lunch today hitting the local recycled bike shops looking for some 700c wheels and stuff. found another bike instead, its not complete, but it has decent 700c wide rim wheels (rims are labeled 28x1-sumtin, but they had fat 700c tires on them, which I replaced with 700x40's that fit sweet) and the seat post isn't terminally jammed in. guy in used bike shop said it was gonna cost him over $100 to fix up and wouldn't probably sell for more than $150 anyways, so he let me have it as-is for $45, hah. wanna change out the handlebars. already got a seatpost and new tires on it, and need to put v-brakes (has posts already), rear derailleur, chain on it, I'll probably swap out the cranks too, as it has those cheap riveted triple-rings, and I'm just going to turn it onto a 7-speed. mild bummer, its a threaded on freewheel and not a cassette, but ah well. its notably lighter than my existing fat-tire cruiser, these wheels should roll great. I've got to true up the rear a bit, but its a 36 spoke wheel with heavy stainless spokes, so it should be pretty easy. (chainless, brakeless, etc) so... this makes TEN bicycles, EEEK. ![]() edit: hah! stuck those bars on a little longer gooseneck (more forward), and since they had one old brake lever on them already, I stuck a junk spare V-brake I had lying around on the front wheel, and shortened the funky chain it had and hooked it up as a midrange fixie, and shit, this is gonna be a good ride when I get it tweaked out. I think I want slightly straighter bars, maybe a little wider, like some modern mtn bike bars, and a lower long gooseneck (the one I had lying around was kinda high), and it will be perfect. a pseudo-cruiser that can book across the flatlands, and still climb a hill if I have to. heck, I might just keep the 3-speed front, since the 7-speed freewheel cluster on this wheel isn't nearly as high range as I'd like for a 7-spd. I do believe its a 1999 Diamondback, originally this cheap thing http://www.bikepedia.com/QuickBike/B...kway&Type=bike if thats correct, the cluster is a 13-28, and the front is a 28/38/48
Experience is what you get when you don't get what you want. pierce screwed with this post 06-25-2010 at 04:48 PM |
06-25-2010, 04:53 PM
#15005 |
1.5 Finger Discount
Oddometer: 20,097
Well, if you need to ditch a few, we can help.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy "Never bring a Nerf gun to a shovel fight." - My Brother |
06-25-2010, 04:56 PM
#15006 |
Slacker
Oddometer: 29,533
The frame looks different. No angle with the top bar and wheel stay, or whatever the top bars to the rear axle are called.
The finishers medal is satisfyingly heavy... Neduro on Dakar The other 10% are sociopaths , serial killers and KLR riders. You wont get much sympathy from them. -Furious D |
06-25-2010, 06:32 PM
#15007 | ||
Sumo Biker!
Oddometer: 5,014
'08 WR250R |
06-25-2010, 07:13 PM
#15008 |
PowerPoint ADV
Oddometer: 5,210
Seat Post Success
Out at last!
![]() The yucky part: ![]() All cleaned up and ready for grease ![]() All greased and ready to go back in ![]() All done save the final adjustments
06-25-2010, 07:22 PM
#15009 | |
Aven'Tourer
Oddometer: 9,744
the parts that are still on it match the 1999. even has Z chain. has a sunrace 13-28 7-speed freewheel. shimano branded cheep triple-crank. etc. its been fun riding around my driveway as a fixie, in a 38-18 kinda gear (not sure what rear I shortened the chain to, but one bigger needed a half link, so I put it in 4 out of 7). even kinda like the bars after playing with them and two different stems I had kicking around, but I think I want a lower more forward stem with a straighter bar. I even flipped the bars over to be track style, hahahaha, since there's only one brake lever on them right now, was easy. slapped some oury fat soft grips on there. the michelin 'city' 700x40's I got ride sweet. I need to fix a spoke and true the back wheel. :-/ its got fender and rack inserts on the back, and fender mounts on the front. bunch of Taiwan parts on it, the bearings feel decent quality, but the back axle needs tightening a hair. threaded headset looks pretty heavy duty, too. the rims say 28x1-5/8", and some odd taiwan brand. the sunrace 7-speed freewheel is heavy :( btw, I do believe I'm swearing off gumwalls. the tires that were on this bike had plenty of tread, but the gumwalls were totally rotted out and sidewalls were frayed and splitting in places.
06-25-2010, 11:47 PM
#15010 | |
Aven'Tourer
Oddometer: 9,744
*NICE*.... except for the high state of polish, that looks a hella lot like the old campy seat post in my motobecane... except mine is the older nuovo record, not the fluted super-record
06-26-2010, 08:22 AM
#15011 |
Slacker
Oddometer: 29,533
That seat looks anything but comfortable, but I test rode a Specialized Hard Rock yesterday, and it actually felt pretty good.
I did five miles this morning and the Cloud 9 seat I have wasn't feeling too good. The more I ride, the more I realize that seat should be on a tricycle at a trailer park in Texas.
06-26-2010, 09:21 AM
#15012 |
1.5 Finger Discount
Oddometer: 20,097
Got a rack for my wife's bike a few weeks ago.
So the other day I made this block to rest things on with so extra hooks for strapping. ![]() ![]() Just gotta figure out what color to stain/seal it.
06-26-2010, 10:59 AM
#15013 | |
Slacker
Oddometer: 29,533
06-26-2010, 11:03 AM
#15014 | |
1.5 Finger Discount
Oddometer: 20,097
You're going to get me in trouble!
06-26-2010, 11:13 AM
#15015 | |
That's MR. Toothless
Oddometer: 25,895
The exception is 27" to 700c. You can get a an adaptor for that. M
There. I've moved back to VA. Can you PLEASE change the weather?! |
| Thread Tools | |
