10-01-2010, 09:35 AM
#17356 |
PowerPoint ADV
Oddometer: 5,131
Thinking of heading over to the Red Hook in the morning and go for a ride.
http://www.cascade.org/EandR/Activit...?eventID=14683
...Dick "...the road goes on forever and the party never ends..." - Robert Earl Keen Go Pyndon! Go Ned! Eight Years |
10-01-2010, 10:11 AM
#17357 |
Oddometer: 1,917
![]() my pretend to be fast guy bike Salsa Pistola |
10-01-2010, 11:23 AM
#17358 |
Slacker
Oddometer: 29,466
I saw a Surly at the LBS yesterday. The one for traveling. I drooled.
The finishers medal is satisfyingly heavy... Neduro on Dakar The other 10% are sociopaths , serial killers and KLR riders. You wont get much sympathy from them. -Furious D |
10-01-2010, 11:24 AM
#17359 |
Zombie Holocaust
Oddometer: 2,302
New Raleigh's are NICE!
Move over, Fargo...
![]() Lugged steel...
VIVA LOS MTNADS
10-01-2010, 11:55 AM
#17360 | |
Oddometer: 940
10-01-2010, 11:59 AM
#17361 |
Oddometer: 1,917
[QUOTE=Flaco]Move over, Fargo...
Sojourn - one came up on cl for $700 - very tempting but I have way too many now. Raleigh has a very nice lineup - the clubman and port townsend look sweet as well |
10-01-2010, 05:16 PM
#17362 | |
Hard to be Humble
Oddometer: 863
"It sucks, It's always gonna suck. You've got to learn to enjoy it." Unknown Marine Recon Instructor Wind,Rain,Hills,Cold. on a Bicycle see above. |
10-01-2010, 05:18 PM
#17363 | |
Hard to be Humble
Oddometer: 863
10-01-2010, 05:19 PM
#17364 | |
Hmm...
Oddometer: 4,085
I got my tires mounted and it wasn't too bad. The slime thorn tubes are thick! The tires are Conti Gravity 2.3's. Conti is very optimistic with their sizing. It's more like a 2.1. Fits the frame easily. I was able to get all of the shifters and brake cables adjusted as well. Ratchet straps over the exposed rafter sure beats working on it on the ground. I rode it a whole mile and almost died. Never stopped but my muscles didn't like it. I need to build up the muscles again. 15 years of lounging has taken their toll. I had a guy offer me some new wheels and V Paul Brakes if I wanted to go SS. I think I'll take him up on that offer. I know I'll have to buy new levers but that's not a big deal. I want to get some bar ends and I'll definitely need some bar plugs. I don't need to be taking any core samples. ![]() The bike looks a lot better with some decent tires on. At 50 PSI they roll pretty fast. I've scrubbed 90% of them but need more seat time before I can feel confidant cutting turns.
"I'm going to shift gears now.... This will involve man touching." - Jeremy Clarkson |
10-01-2010, 05:22 PM
#17365 | |
Oddometer: 2,461
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
10-01-2010, 05:29 PM
#17366 | |
Hard to be Humble
Oddometer: 863
10-01-2010, 05:44 PM
#17367 | ||
Aven'Tourer
Oddometer: 9,706
![]() why would you want an SS ![]() Quote:
for dirt, you likely want them a lot softer than 50 psi. 30psi or less, even, unless you're on the heavy side.
Experience is what you get when you don't get what you want. |
10-01-2010, 05:50 PM
#17368 | |
Oddometer: 2,461
10-01-2010, 07:11 PM
#17369 | |||
Hmm...
Oddometer: 4,085
There are rolling hills around here. Some roads are kinda steep as well. SS would be a little crazy but then again people think fixies are crazy too. I'm not sure what I'll do just yet. Maybe gather some parts and see what happens. The one thing I'm wondering is if I'll like the bike enough not to buy a new one. ![]() I pumped the tires up to their rec pressure since it was just around the block. I had them at 35 which felt pretty good still.
10-01-2010, 08:00 PM
#17370 |
Aven'Tourer
Oddometer: 9,706
if you have (or get) a chain punch, you can shorten the chain your existing sprockets and bypass the rear derailleur and make it into a temporary fixed gear.
first, open the chain, then wrap it around the middle sprocket in front, and try different sprockets in the rear til you find one where the chain links line up when you hold it tight. punch the excess chain off on that link, and put it back together as a fixed speed... you likely have something like a 22/34/42 front, so 34 and one of hte middle gears should hit the sweet spot. me, I'd remove the rear derailleur, and tape the cable back temporarily to try it out, but ou could probably leave it on there. also of course, set the front shifter on MIDDLE! and don't touch them. now go ride it. do you like it? then find a 34 or so tooth front that will fit your crankset and a rear wheel with exactly whatever sprocket worked, and remove the shifters, derailleurs, and cabling....
| Thread Tools | |
