11-08-2010, 01:40 PM
#17941 | |
Hmm...
Oddometer: 4,080
The clothes for the most part is functional and not fashion even though it might look the opposite. The materials wick sweat off the body which helps keep you cool. The compression helps prevent muscle strain and fatigue. When you're starting out or are going on long rides you'll begin to feel the burning in the legs. This helps with that. I second VelvtRide's recommendation. Look for year end closeouts. Actually, this is a good time to be shopping. Usually the ugly colors are the ones to drop in price faster so if you're not caring what they look like, then it would be a better deal. If you're having issues with your seat then either get a new seat (try some out if you can and check review sites) and/or get some shorts with the chamois (cheap shouldn't be confused with deal/inexpensive. Quality is typically more expensive so you're not just paying for a name.). Otherwise just tough it out. With more miles under your belt, you'll just get used to it until it stops being an issue. With more miles, you'll sort of figure out what you need as you're body gets used to riding. In any case don't let it get in the way of riding.
"I'm going to shift gears now.... This will involve man touching." - Jeremy Clarkson |
11-08-2010, 03:21 PM
#17942 | |
PowerPoint ADV
Oddometer: 5,110
![]() I need you to shop for me. When I raced I never ever paid anywhere close to even wholesale for gear. Helmets were about $15, shorts and jersey, $40 or so and that was team gear. When all that went away I never noticed I had this big pile of gear from years of riding. Then I got, well bigger. And stuff either didn't fit or in the case of a pair of shorts, lost all elasticity. This was ugly enough to be funny. I should have taken a picture. The gloves that the padding inside the palms turned to dust, and when the seam failed it ran out like sand from an hour glass. Now I find my self with a day to look for stuff in a town I don't really know. So I go looking, but now, I'm also looking for stuff that is going to fit right. With that Jersey for instance I narrowed it down to three. I had thought about the UA warm top, but have no idea how those are sized and of course the two places I went looking didn't have anything that was even close and of course not on sale. I did manage to get that Pearl Izumi rain jacket thing that really doesn't breathe on a good sale at REI, but I suspect that is maybe why. I'm hoping one of my old riding jackets isn't too worn out to work for one more winter. And that I can fit into it. But, on the good side all that black is slimming...
...Dick "...the road goes on forever and the party never ends..." - Robert Earl Keen Go Pyndon! Go Ned! Eight Years |
11-08-2010, 04:34 PM
#17943 | |
i can haz a motrsykle?
![]() Look around - it took me nearly 2 years to find all of that. |
11-08-2010, 05:40 PM
#17944 |
Hmm...
Oddometer: 4,080
Took a quick ride, maybe 6 miles to test my wheels and brakes. Turns out my head set was loose and I ended up tightening it too much right before the ride. Gotta fix that. Also noticed that the spacer is cracked and missing 3mm in it. It's a spacer so I don't think it's an issue. Also the seal on the lock ring is torn.
Thought about maybe replacing the whole headset though. Maybe install a vintage Shimano LX or DX as it's 1-1/8" threaded. Any others I should consider? I figure prices aren't going to get any lower then what they already are.
11-08-2010, 06:27 PM
#17945 |
Oddometer: 4,770
Anyone have an old suspension fork that would fit on an old Scott threaded headstock mountain bike that they would like to get rid of cheap? It is for my wife's bike. She is not picky, just something with some spring to it to soften the hits.
Sasquatch |
11-08-2010, 06:51 PM
#17946 | |
Hmm...
Oddometer: 4,080
11-08-2010, 07:00 PM
#17947 |
2010 690 Enduro
Oddometer: 2
I have found that once you know your sizing in the manufacture of choice,many good deals can be found on E-bay but you have to be careful of the knock off stuff as it will not be up to par in most cases. In Ontario we have a show in the fall that blows stuff out at some good prices. Surely State side has some blow out shows in the fall/spring. In Canada we have Mount Co-op that offers some high quality clothing for reasonably good prices as well.
I also found that alot of the cycling gear can be used on the moto as well,like for instance some of the tops for winter cycling is nice under the moto gear in the colder weather. |
11-09-2010, 06:20 AM
#17948 | |
Oddometer: 885
11-09-2010, 07:42 AM
#17949 | |
PowerPoint ADV
Oddometer: 5,110
11-09-2010, 09:40 AM
#17950 | |
Hmm...
Oddometer: 4,080
11-09-2010, 12:57 PM
#17951 | |
That's MR. Toothless
Oddometer: 25,543
Oh, and they're pretty much 'install and forget' things. If you can find one, the American Classic Tri-Lock is another good bet. Period correct. HTH M
There. I've moved back to VA. Can you PLEASE change the weather?! |
11-09-2010, 12:58 PM
#17952 | |
Oddometer: 25,543
M
11-09-2010, 02:09 PM
#17953 | |
Hmm...
Oddometer: 4,080
Oh and on another front, I noticed that my brake cable is getting pinched. Or at least the outer plastic sleeve is. This only seems to happen when I crank the bars 90*. I have already cut the cable so I can't redo it. I have about 1.5" of cable sticking out at the brake. Should I pull the cable and replace the sleeve (keep the same length) or just leave it? ![]()
11-09-2010, 03:53 PM
#17954 | |
Oddometer: 875
Call me Mel. Some years ago- never mind how long precisely- having little or no money in my purse, and nothing particular to interest me at home, I thought I would ride about a little and see the other parts of the world. It is a way I have of driving off the spleen and regulating the circulation. |
11-09-2010, 04:54 PM
#17955 | |
Oddometer: 616
I did 30 miles last weekend throught some rolling hills east of me (Fountain Hills) and it kicked my butt. I did purchase clipless pedals since my photo and that is making my riding more efficient. Thinking of becoming more serious about this hobby......
John M. '08 Kawasaki Versys '11 Victory Cross Roads |
| Thread Tools | |
