Go Back   ADVrider > Fluff > Sports
Thread Tools Rating: Thread Rating: 450 votes, 4.93 average. Display Modes
Old 03-07-2012, 04:32 PM   #23416
Bimble
In giro in moto
Bimble's Avatar
Oddometer: 8,350
Originally Posted by k7 View Post
Wish me luck - I could die.
That looks awesome. Good luck!
Ya know, Paris-Brest-Paris is in 2015.
I bet you will qualify.
Siamo tra qui e lė.
Bimble is offline   Reply With Quote
Old 03-07-2012, 05:17 PM   #23417
ducnut
Oddometer: 3,320
Originally Posted by Aurelius View Post
Weird. Where was that taken?
Santos.
Originally Posted by rob feature View Post
I've gotten those, too. Though, I'm not sure from which state/trail.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 03-07-2012, 05:29 PM   #23418
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,727
4+ hrs with a head/side wind today. Mostly headwind for the last hr+
Solo. Would've been nice to have company tho.
Beautiful day despite the wind.
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 03-07-2012, 05:53 PM   #23419
rob feature
Domain Ranger
rob feature's Avatar
Oddometer: 4,587
I never met one 'till I moved to Colorado. Then I got to know them very well and very quickly
The most common name here amongst cyclists is the Goat's Head, but the species name is Tribulus terrestris. They creep along the ground as they grow, widening their path of destruction and are really hard to see unless you're looking for them and moving slowly. I couldn't get in a single ride without a flat. That's when I went to the tire strips and gooey tubes - nary a flat since. I'm taking a weight penalty, but it's that or fix flats every day.
rob feature is offline   Reply With Quote
Old 03-07-2012, 06:01 PM   #23420
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,146
I've yet to lose a Park patch, but have a 3 patch rule. If I've just put number 3 in there, it gets swapped ASAP.
I keep a good supply of Park GP2 glueless patches on hand. In almost 20 years of mountain biking, I haven't had one fail. And they're soooooooo easy to put on. They're itty bitty too and the glue's already on, so there's no mess. They also come with a little slice of sandpaper and a plastic box it all goes in. It's all about the size of a postage stamp, only thicker.
Hmm, I tried the gp2s, didn't have good luck with them. . . . they'd last one ride, then the heat cycling would pop them off (I guess). Went back to glued patches, never had a problem with them.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 03-07-2012, 06:19 PM   #23421
rob feature
Domain Ranger
Oddometer: 4,587
Bizarre. Maybe it's a matter of method.
I scuff up the tube while inflated to about where it's gonna be. Then inflate it as much as possible to reflect where it'll be in the tire. Then put on the patch and mash the snot out of it. Then put it all back together - never fully deflating the tube.
The patches are flexible, so putting one on with the tube deflated or overinflated might make the patch wander and fail. Bubbles, debris, and/or ridges will also botch the job. But with properly applied patches, I've had great success.
Might have something to do with tire pressure too. I rarely run over 35 psi. Haven't run one in a 29er tire either - always 26. I'm hoping my strips will make it a non-issue.
Old 03-07-2012, 09:56 PM   #23422
pierce
Aven'Tourer
pierce's Avatar
Oddometer: 10,111
those goats head thorns grow in the more arrid areas around here. nasty buggers.
Experience is what you get when you don't get what you want.
pierce is offline   Reply With Quote
Old 03-08-2012, 05:15 AM   #23423
trailer Rails
trailer Rails's Avatar
Oddometer: 4,591
We have these lovelies to deal with
They don't look so bad on the surface. But they have a defense mechanism - and it seems it's specifically tailored to bicycle tires.
I pulled 42 of these out of one tire
I have changed tubeless tires and discovered dozens of thorns in the tire but it never went flat.
Low pressure helps with climbing and rear wheel traction. You have to play with the pressure, too low and the tire will squrim out from under you, too high and you will skip off little rocks and roots.
trailer Rails is offline   Reply With Quote
Old 03-08-2012, 10:40 AM   #23424
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,076
With either the thornproof/sealant setup or tubeless/sealant - when something finally kills it and you have to put in your spare tube, you will spend most of the time clearing thorns from the tire so the spare tube is not immediately destroyed. The record was about 45 minutes time from stop to ride away.
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 03-08-2012, 12:26 PM   #23425
fullmonte
Reformed Kneedragger
fullmonte's Avatar
Oddometer: 5,399
I assume it's possible to get lost if the trail isn't clearly marked. I was thinking of taking along a wrist worn GPS left over from my kayaking days, but I don't know whether the tree cover will block reception. Anyone using these?
Its very possible. I'll never forget the time I almost had to spend the night in the woods because of unfamiliarity with an unmarked mtb trail system. We rolled back onto the main entrance road well after 9pm. This was back before GPS was common, so I say bring it and make sure you turn it on before leaving the parking lot.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides
"A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad
fullmonte is offline   Reply With Quote
Old 03-08-2012, 01:16 PM   #23426
inyang
5secs away
inyang's Avatar
Oddometer: 419
LCC Crit Race
Went to watch a race at Port Harcourt last month - Feb 26.
Was organised by the local club (Lifestyle Cycling Club) based there.
Nice
Took part in the old part of the town, 7 km per lap X 5 laps
More pics here
https://picasaweb.google.com/1020946...rtLCCCriterium
'11 - 690R
inyang screwed with this post 03-08-2012 at 02:42 PM
inyang is offline   Reply With Quote
Old 03-08-2012, 01:20 PM   #23427
Gummee!
Gummee!'s Avatar
Oddometer: 28,727
Debating selling this f/f/hs:
I need the $$, but don't really *want* to sell.
M
Old 03-08-2012, 02:49 PM   #23428
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,742
I like that one.
Good luck!
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 03-08-2012, 05:59 PM   #23429
dolomoto
Destroyer of Motorcycles
dolomoto's Avatar
Oddometer: 2,657
So, there I was...cranking out the 140th mile in 3 days of commuting on Hunter AAF. I check my mirror and there's another bike way back. I keep cranking...I check the mirror again after about 100m and this guy is closing...fast.
And, he's on a tricycle.
I was already spinning 100rpm at 15mph into a 15mph headwind...I went past LT..and watched as this dude...on a TRICYCLE..passed me (I was gasping).
He was in ACU's and just spinning at about 70rpm..as he passed, he looked over at me and remarked: "wanna race?".
I gasped: "no"
As he pedaled merrily away, I noticed the battery pack on the rear axle. It was a huge battery case.
I can't beat electric assist (at least not after 3 hard days of riding).
Catch me after a couple days off the bike....well, then.
Anyone else seen electric assist bikes? I read in Bicycling magazine that they're starting to trickle into the rental bike fleets. Wave of the future?
Hot, Nasty, Bad-Ass Speed tours: 2008,2010,2014
Things I've ate/cooked.
dolomoto is offline   Reply With Quote
Old 03-08-2012, 07:18 PM   #23430
MK Bike
D2T
MK Bike's Avatar
Oddometer: 142
80% of the delivery guys use electric assist bikes here in the NYC. Some of the electric bikes style and size practically qualify them as a moped. Also starting to see more electric bikes at commuter stations as commuters ride them to station instead of driving. Curious to see how the electric bike segment will play out. Though to be honest, I grumble a little when I see an electric bike in a bicycle lane.
MK Bike screwed with this post 03-10-2012 at 11:13 AM
MK Bike is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 07:38 AM.
