05-31-2012, 07:04 AM
#24106 | |
That's MR. Toothless
Oddometer: 25,549
M
There. I've moved back to VA. Can you PLEASE change the weather?! |
05-31-2012, 08:16 AM
#24107 | ||
Rides a dirty bike
Oddometer: 1,417
![]() It's held onto the hub by a hollow allen bolt (10mm?). You have to pull out the axle and bearings, then unscrew the bolt. After that, you drop the replacement on and reassemble. IIRC, there are only a couple of options for shimano freehub bodies - but they are fairly durable. You broke the "dog"s, but they probably trashed the springs and damaged the pockets in the center section. Here's the DIY: http://sheldonbrown.com/k7.html#transplant ![]() I broke a DT hub this way once, but it failed due to heat treat issues and was warrantied. Got a new hub - I did the wheelbuild. The shimano freehub failures I've seen have all been due to lack of maintenance over time - and it's a PITA to get to the ratchet on these. Best bet is a Morningstar Freehub Buddy, which allows you to push solvent or lube thru the freehub and take care of the ratchet and the two sets of loose ball bearings in there. But you have to strip it down just as far to maintain it as to replace it.
Two roads diverged in a wood, and / I took the one less traveled by, / And now where the hell am I? 'Being an adult is so much better when you forget that you're supposed to be boring' (D.Corsetto, 9/7/12) |
05-31-2012, 09:14 AM
#24108 |
Oddometer: 10,301
3737 as of this morning's ride. 477 in May! Highlights included a 75 mile day and an impromptu 1 hour time trial (I got a late start this morning) that netted me 19.25 miles. I'm at 1387 for 2012. I should be at 1458, but goddammit, that's progress! As far as my 1012 goals, a century is looking pretty damn doable. My 3500 mile goal looks legit, barring disaster. 20 miles in an hour is still looking pretty sketchy. I can cruise along OK between 19 mph and 20 mph, but someone drops a load of bricks on me at 20.1.
Jim Moore "Marines good. Press bad" -Turkish |
05-31-2012, 09:16 AM
#24109 | |
Oddometer: 503
However Gummee brings up a good point about ebay. I would get your existing hub fixed under warranty and then sell the wheelset. You can find a complete front and rear wheelset for $200 with XT hubs. Velocity and Mavic rims are good. DT Swiss wheelsets are good too. I would stay away from complete Mavic wheelsets though. They look cool but I broke several spokes (proprietary spokes) and my buddy trashed his freehub three times. |
05-31-2012, 10:24 AM
#24110 |
Oddometer: 1,910
Went up to Ohio to see my nephew off to the air force this past weekend. For the heck of it I tossed the poprad into the trunk of the rental car. Stayed in Fancy Gap Virginia thursday eve and was hoping to pedal a bit of the blue ridge friday morning. But there was pea soup fog when I woke up friday. Got a couple rides in around my parents house in Ohio. Was nice to pedal the roads I did as a youngster. Even found a gravel rail trail while out on a road ride that was a nice change. The rolling hills were kicking my arse good. Note to self do not eat a Mr Hero Romanburger a few hours prior to pedaling...
05-31-2012, 10:30 AM
#24111 |
PowerPoint ADV
Oddometer: 5,110
Once upon a time I raced bicycles and was pretty good at training and not so much at the racing part since I'd used up my competition gene somewhere around 13. I started racing bicycles in my early 30's. I was lucky to be in Colorado and because I began from working as a motorcycle marshal with the Coors Classic I gained access to a lot of great information and training. That made for learning not only how to train but how to recover from training and injury. I got to ride with some pretty special folks and got a lot of great advice, training direction and how to set a bicycle up and why.
All that, as well as growing up a snow skiing and racing those and playing football. Football was stupid except for some of the conditioning, I learned soem stuff there. the rest of it was and is about the worst thing you can do to a body. But, I'll not climb too high on that horse. The trick I know is that with my age, (59) recovery takes longer. and if I rush things it just makes it ultimately take even longer and hurt more. So, yes I'm back to time in the saddle but at a sustained effort. Right now I try to keep my speed down around 15 mph for the first half hour to get good and warm. And chase as few rabbits as possible. That means I can stay in the saddle longer. Monday was said to be mid 80's, but felt like 90's. I've ridden in over a hundred but being in condition makes a huge difference. When I was racing heat didn't bother me. I liked it hot and dry I seemed to ride a lot harder then. The tough part in recovery is holding back. Right now I am real weak compared to where I was before my back went nuts. My back is just OK to ride not perfect so even pushing a little is a bad thing. The PT I was doing was useless. The usual hot pad with that electric muscle twitch thing. They added some homework, yoga stretches which are the only useful part of the program. I stopped going, I know I need to strengthen my core, but to do that I need to get my cycling back a good bit, with some walking at lunch and after work during the week. eventually I'll get back to riding the big hills and running. THat stuff builds my core back. I am so far amazed that my so called "Cadillac Insurance" plan always finds useless stuff like this here. In Colorado I had basically the same thing with an HMO from BCBS Colorado so I went to my old sports medicine PT shop and paid cash. That was good stuff. They actually did sports work not some crystals and newage noise aroma therapy garbage. My plan is to go on my own dime to a sports medicine doctor in Newport Beach a friend has used for opinion. Then I'll take a swipe at the insurance company. In Colorado before I had the crappy HMO, I told my GP I wanted to go to Andy Pruit for an evaluation of my knee, and PT, and bike re-set. My doc didn't know of Andy so I showed him, pointing out the miles I put on the bike. he agreed and went to bat for me with the insurance company. I got re-habed and my bike set up and some home PT to do. A month later I was back in the saddle doing good miles. I'd blown up my bad knee at a timetrial where the wind kicked up big after the turn around. So, now I'm back to slow and steady again. I will get back to all day in the saddle at a reasonable clip, and not feeling like I've been beaten afterward. Just takes some time. And I got some of that for now.
...Dick "...the road goes on forever and the party never ends..." - Robert Earl Keen Go Pyndon! Go Ned! Eight Years |
05-31-2012, 10:31 AM
#24112 |
Oddometer: 60
Thank god bicycles are still alive on this world full of petrol running beasts
My Signature ------------------------------------- One day, I will take it easy. Today won't be that day... ------------------------------------- |
05-31-2012, 03:37 PM
#24113 |
PowerPoint ADV
Oddometer: 5,110
Unfortunately I am still putting more miles on the gas-burner than on the fat burner.
For May I manage 103 miles on the bike once I got the OK from the doc. So a little under 500 so far for the year. Nowhere near what I expected back in January.
05-31-2012, 06:24 PM
#24114 |
Oddometer: 5,982
Upgrade.
What is your current repair stand of choice for the home shop?
Once in a while you get shown the light in the strangest of places if you look at it right |
05-31-2012, 06:31 PM
#24115 | |
egregious outlier
Oddometer: 3,365
"Correct spelling, correct punctuation, correct grammar. Hundreds of itsy-bitsy rules for itsy-bitsy people. No one could remember all that stuff and concentrate on what he was trying to write about. It was all table manners, not derived from any sense of kindness or decency or humanity" - Robert Pirsig, Zen and the Art of Motorcycle Maintenance |
05-31-2012, 06:44 PM
#24116 |
Perma-n00b
Oddometer: 10,398
05-31-2012, 06:47 PM
#24117 |
Oddometer: 5,982
![]() I'm looking to upgrade.
05-31-2012, 07:07 PM
#24118 |
Oddometer: 503
Feedback Sports Pro Elite but it's hard to go wrong with Park Tools.
05-31-2012, 08:16 PM
#24119 |
Oddometer: 5,982
Great choices guys. I was also looking at the Park PCS 4 in that range ($200) but am not sure of the feet. I like the stability of the tripod feet on both the units suggested above, Topeak and Feedback for breaking loose stubborn pedals or bottom brackets.
Anyone with the Park who can attest to the stability?
05-31-2012, 08:17 PM
#24120 | |
I just wander.....
Oddometer: 1,279
2009 Husaberg 450FE 2007 Factory Husaberg 380FE 2007 Montesa 4rt 1984 Husqvarna 500AE |
| Thread Tools | |
