Go Back   ADVrider > Fluff > Sports
Thread Tools Rating: Thread Rating: 449 votes, 4.93 average. Display Modes
Old 08-02-2012, 10:09 AM   #24751
YakSpout
Obstacle Allusion
YakSpout's Avatar
Oddometer: 6,120
Originally Posted by RxZ View Post
I've a Strava question as well. The entire length of our local MTB trail is a segment. Not a problem really, except that when I only complete a part of it and pull off early, it still counts the time as the whole segment. For example, my personal best according to Strava is a 5.1 mile ride, when the total length is somewhat over 6 miles. So of course the shorter ride didn't take as long.
Granted, in a few weeks I hope that the entire route is faster than what the partial was, but then what if I only do part of it in the future? Anyway, seems like an odd quirk
That's a phone-based GPS issue. Quite a few posts about it on various tracking software forums. Phone GPS antennae and software aren't at the same level as a dedicated GPS unit's. (Comparing two rides/runs taken with a phone and a Garmin running at the same time will show pretty different tracks. The phone will be a smoother line, but, in general, the GPS will have a more accurate display due to better reception, higher sampling and better algorithmic accuracy.)
YakSpout is offline   Reply With Quote
Old 08-02-2012, 10:16 AM   #24752
YakSpout
Obstacle Allusion
YakSpout's Avatar
Oddometer: 6,120
Anybody seen this?
http://www.cerevellum.com/hindsight.aspx
I really don't need another gadget and it's too bad that there's so much stuff going on inside that thing. A tiny cam, built into the tail flasher with a shock sensor and a 5min loop recording would be enough. Have it turn on/off when you activate the flasher, then turn off and preserve the footage if the shock sensor detects a hit. No need for all the frippery. (ANT+ compatibility, video display, etc.)
Old 08-02-2012, 10:28 AM   #24753
Aurelius
Aurelius's Avatar
Oddometer: 22,684
Did it!
Woohooo! Just uploaded my first Strava run. I walked across the office parking lot at an average speed of 3.4 mph, achieving a top speed of 3.7 mph.
http://app.strava.com/rides/16098335
Beat that, you fuckers!
Dizave opined: Why do you care where the premises come from? They are above reproach. For all intents and purposes, you can just make up all your premises, since they can't be proven anyway. That's why we need premises.
Aurelius is offline   Reply With Quote
Old 08-02-2012, 10:32 AM   #24754
RxZ
Legal Drug Dealer
RxZ's Avatar
Oddometer: 1,889
That was with a Garmin The problem is, one day I only did part of the trail, the next ride I did the whole trail. The Strava segment is the whole trail. Strava says my partial lap is the fastest full lap that I have ridden. For some reason, I guess since I rode most of the trail on the partial day, Strava is thinking I rode the entire trail. Even though the partial ride was 5.1 miles, and the full was 6.2 miles. The data from Garmin is correct, the interpretation by Strava is not in this case.
RxZ is offline   Reply With Quote
Old 08-02-2012, 12:01 PM   #24755
ImaPoser
adventure imposter
ImaPoser's Avatar
Oddometer: 15,886
Originally Posted by Aurelius View Post
Does Strava allow you to delete runs that you don't want saved? I'm going to do some experimental ones just to see how it works, but I don't want these to be saved. I also just realized that I'm going to be at a competitive disadvantage because I have to put away the cell phone once I start the run and then take it out again to stop it. That's going to add precious seconds to my times!
No worries, the app is pretty intelligent. It tracks moving time and stopped time, and uses some kind of magic to figure out average speed. I have forgot to sip the app when i got hone before, and it showed the ride time a very close to a typical ride once i finally hit the finish button.
I have noticed it on my phone immediately after a ride that some of the data is way off, even when initially uploaded it may show errors, like i managed to drop to sea level and then back up to the real elevation within a quarter mile giving my total elevation gain an extra 1000 feet. But within a few hours, it is showing a corrected, believable figure.
Now last nights ride, it managed to cut me off right in the middle of one achievement, and show i rode cross country and reconnected my course right after the start of the next, not giving me any data for either one.
ImaPoser
Save 20% when you open your own smugmug account. Just go here...
ImaPoser is offline   Reply With Quote
Old 08-02-2012, 12:05 PM   #24756
YakSpout
Obstacle Allusion
YakSpout's Avatar
Oddometer: 6,120
Ah, I misunderstood. Yep, the partial segment thing is also a glitch. I've seen that on some of my rides as well. (I'll get a time for an entire lap of a nearby park when I know that I only rode about 1/3 of the way. It doesn't seem to just hand out a KOM for that partial, though. )
Old 08-02-2012, 12:06 PM   #24757
ImaPoser
adventure imposter
ImaPoser's Avatar
Oddometer: 15,886
Originally Posted by ducnut View Post
What size did you end up with?
I went with the 23. I like the way they look.
ImaPoser
Old 08-02-2012, 01:47 PM   #24758
rbrsddn
3banger
rbrsddn's Avatar
Oddometer: 2,767
That's what I run. I used to ride the 20's, before I knew better...
rbrsddn is offline   Reply With Quote
Old 08-02-2012, 02:23 PM   #24759
pierce
Aven'Tourer
pierce's Avatar
Oddometer: 10,111
i was reading a year or two back, the LD racers, like the grand tours, are running larger tires now, as big as 27s/28s, because the new tires are just as light, and have excellent rolling resistance and a smoother ride.
when I rode road bikes 30+ years ago, I used to run a skinnier tire in the front and a fatter one in the back, but these were Clement silk tubulars (we called them sew-ups back then), so I don't know the exact sizes. IIRC, I ran a Campianto(sp?) Del Mundo in the rear which was probably about a 28, and a Criterium or ?? in front which was a 21 or so or a paris-roubaix which was a little bigger and tougher, maybe a 23 (just guessing on the sizes). I think sometimes I ran p-r in rear and crit in front, heh, especially when I was running lighter 'blue label' rims instead of the sturdier 'red' rims. for touring with front/rear panniers, I'd run the del mundos on both rims.
I was even pretty good on roadside sewup repairs, when you get that 3rd flat on a trip. hah.
[typed while sitting on my ass feeling like crap, broken right foot (car accident) elevated on ice because I had surgery yesterday]
when I get my foot back, I *AM* going to beat myself up into shape, I have to lose like 50 lbs, being fat (230 lbs) sucks. my new ebay 700c hybrid is fedexing its way to me now. what really sucks is, the ER and the doc showed me as having high blood pressure... damn, I used to have LOW blood pressure.
Experience is what you get when you don't get what you want.
pierce is offline   Reply With Quote
Old 08-03-2012, 09:23 AM   #24760
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,726
Just got back from 2hrs on the bike with 2 x 20min over/unders. 2min over LT with 2min just under (sorta) repeat for 20min.
Lemme tell ya, them last few are TOUGH!
...Especially when yer doing em into a headwind.
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 08-03-2012, 09:51 AM   #24761
2whl-hoop
2whl-hoop's Avatar
Location: Cottage Grove, the ragged edge of suburbia, MN
Oddometer: 997
This is my primary ride of late, an Electra Verse...
We take it 6.2 miles to the Y, then I do a 45 min spin class, then we ride home. Usually we're able to do it 2-4 times a week. The last 1/2 mile is uphill, spiking to 10% near the end. If I figure the spin class at 12 miles, I'm usually getting over 100 miles a week in, but only about 30 of it is recorded with my gps, and that's only if I take my "real" bike out on the weekends... I may have to look into the Strava app for my phone...
I don't know what the whole rig weighs with the boy on board, but it's gotta be around 50 pounds. It rides nice though and the long top tube gives plenty of room so the seat doesn't hit my knees.
2whl-hoop is offline   Reply With Quote
Old 08-03-2012, 11:06 AM   #24762
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,351
I haven't ridden in a week.
Got to start going to be earlier and eating more.
Uncle Pollo is offline   Reply With Quote
Old 08-03-2012, 11:17 AM   #24763
neanderthal
globeriding wannabe
neanderthal's Avatar
Oddometer: 1,897
Anybody seen this?
Add an option for bluetooth capability to be able to stream the image to your phone and I like it.
'O=00=O'
BMW 2002. long live the legend
neanderthal is offline   Reply With Quote
Old 08-03-2012, 11:40 AM   #24764
k7
Ancien cyclist
k7's Avatar
Oddometer: 19,626
Sinus infection is kicking me down. I'm support to ride an easy 60-miler tomorrow and thought I'd drive to the ride and cut the distance in half. Now, I'm thinking of skipping it the ride in order to get better quicker.
k7 is offline   Reply With Quote
Old 08-03-2012, 08:11 PM   #24765
djb_rh
djb_rh's Avatar
Oddometer: 576
Anybody seen this?
I not only have one, I've corresponded with the founder quite a bit.
It's a neat unit, but still needs some software refining. Battery life isn't great, either, but I haven't tried turning down the recording resolution to see if that helps (it may, since it won't be working as hard on compression). If you ride three hours or less, the battery is fine. If you're training for longer stuff, it may let you down. I've also had some trouble getting ANT+ data to display right, but I haven't worried much about that since I can't live without my Edge 800 anyway.
And for anyone that cares about Leadville, I've been updating my blog pretty much daily. Today's features data from a Powerline climb as well as a picture of my nearly taco'ed rear brake disk. Ugh.
--Donnie
My blog
djb_rh is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 11:09 PM.
