10-29-2012, 02:00 PM
#25861 | |
Oddometer: 2,448
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
10-29-2012, 02:40 PM
#25862 | |
Aven'Tourer
Oddometer: 9,706
Experience is what you get when you don't get what you want. |
10-29-2012, 02:50 PM
#25863 | |
Oddometer: 2,448
I'm over 5K miles on the same complete 10spd Apex drivetrain and the chain (PC1071) is still within spec. Maintenance is the key to making anything last.
10-29-2012, 03:22 PM
#25864 |
Lacks Freetime
Oddometer: 4,919
This may be a silly question. I have a GT MTB..and it has three gears in front and IIRC, 8 in back. BUT, I almost feel like I can not really use all of them, because if I have it on the inside gear in front, and try to use the outside most gear on the rear wheel, it feels like the chain is almost too cocked? Does this make sense.
When I first noticed this, I thought the crank bearings on my new bike were bad right outta the box...but then when riding more, kinda figured out that it was the way the chain was rubbing against the front derailer. Can that be adjusted out by shop? FWIW...shifts with no issues.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011 WRR/X rear shock adjustment , DZ Moto Photo Bloggin' , Learning photography thread - Ryder Joseph Z. , Born 11/26/12-- the next Adventure begins. |
10-29-2012, 03:34 PM
#25865 |
Oddometer: 2,944
They all do that
![]() No, really, the drive train is not set up to run small/small or large/large on most mtbs. Ther is a combination of chain length and chain line that makes these combinations tough on components. You have enough duplication of ratios to prevent these situations. |
10-29-2012, 03:39 PM
#25866 | |
Aven'Tourer
Oddometer: 9,706
and don't use the biggest 2-3 rear cogs with the big back cog, either. like, for example if the front cogs are L,M,H (L is smallest, H is biggest), and the rear cogs are 1-8 (1 is largest, 8 is smallest), shift something like L1, L2, L3, L4, M2-M7, H4-H8 give or take. this gives you maybe 16-18 usable gears instead of the theoretical 24. The M and H ranges probably overlap and there may well be evenly spaced gear ratios that require double shifting (say, M6 to H4 to M7 to H5 to H6-7-8 or whatever...)
10-29-2012, 03:51 PM
#25867 | ||
Lacks Freetime
Oddometer: 4,919
10-30-2012, 10:07 AM
#25868 |
That's MR. Toothless
Oddometer: 25,583
The 'I've got all this Gore Tex cycling stuff, fuck it let's ride' ride.
So Sandy's sticking around the area and I'm going stir-crazy cause I ain't ridden in a day. So I went riding! Gore jacket. Gore gloves (BMW Summer Rains ![]() There's been a few trees knocked over. There's at least one power line down. LOTS of debris on the roads. Only reason I was chilly was I was overdressed under the jacket. Got sweaty, then chilly. I was going hard enough to not get cold, but not so hard to stay warm. All-in-all ![]() M edited to add: fenders rawk!
There. I've moved back to VA. Can you PLEASE change the weather?! Gummee! screwed with this post 10-30-2012 at 10:13 AM |
10-30-2012, 11:42 AM
#25869 | |
Obstacle Allusion
Oddometer: 5,162
![]() I, on the other hand, forgot my shoes for Sunday's ride, stayed in and played with the baby while my wife and f-in-law hit the road. Well, I did give my bike a thorough cleaning while the YakSprout was sleeping. I'll also take the easy way out on tomorrow's ride with the club and drive over to it rather than ride 13mi to the meeting point, do the ride and then ride 6mi to work. Too damn dark at 5:30am to try riding over. Next week should be better after the time change. Solvang Prelude Metric is on Saturday, though, and we've got a group together to ride that. Lunch after at Firestone Brewery.
10-30-2012, 01:30 PM
#25870 |
Legal Drug Dealer
Oddometer: 1,570
Well, the sun is setting at about 1830 now, and starting next week it will be 1730
![]() Not enough time for me to get a ride in after work. So I just ordered a MagicShine MJ-808 headlight Some local semi-pro racers are putting on a MTB skills clinic this Sunday as well. Should be fun, and very educational since I can tell while riding that I am doing stuff probably not the best way
10-30-2012, 03:07 PM
#25871 | |
Obstacle Allusion
Oddometer: 5,162
http://www.ebay.com/itm/261073771436...84.m1497.l2649 I should have it in 2-3 weeks. |
10-31-2012, 08:19 AM
#25872 | |
Your What Hurts???
Oddometer: 235
10-31-2012, 09:12 AM
#25873 | |
Aven'Tourer
Oddometer: 9,706
found some online reviews on bike forums of these exact lights, this is a brief summary of what I gathered using my subjective reality filter... Yes, they are in reality 700-900 lumens not '1800' or '1200' as advertised. they run moderately hot but not too bad because the aluminum body is a heat sink. the beam is a little too much of a spotlight, several guys added spreader lenses to make them more of a horizontal spread. they ARE about as bright as a single motorcycle low beam. the supplied mount is suckage, one guy drilled and tapped 3 small holes in his and screwed it to pieces from an old catseye bar clamp, much better. the battery pack works OK, and uses standard 18650(?) liion cells available from Battery Junction and others for cheap, so even if the supplied batteries conk out early, no big deal. the wiring is a bit funky, but not hard to redo when needed. this was probably the best of those forum reviews... http://forums.mtbr.com/lights-night-...mp-759177.html
10-31-2012, 09:41 AM
#25874 | |
Your What Hurts???
Oddometer: 235
10-31-2012, 10:16 AM
#25875 |
Oddometer: 25,583
+1
I'm lucky in that I have a buddy that owns an LED lighting company. I figger if anything goes wrong, I have a source to either get it fixed or upgraded. Mine's not here yet either. I'm thinking Sandy may have had something to do with that. ![]() M
There. I've moved back to VA. Can you PLEASE change the weather?! |
| Thread Tools | |
