Go Back   ADVrider > Fluff > Sports
Thread Tools Rating: Thread Rating: 405 votes, 4.92 average. Display Modes
Old 05-11-2007, 02:01 PM   #4006
Speaker
What's an estart?
Speaker's Avatar
Oddometer: 888
Originally Posted by Perry
Mine's on the left, guess I have no issue with confusing which bike I'm on. I'll leave well enough alone.
Me neither, my mountain bikes and bmx bikes are set up normal left=front. but since I only have one brake on the fixed, I'll have it on the right.
Speaker is offline   Reply With Quote
Old 05-11-2007, 02:09 PM   #4007
Ri-Ra
Burgeoning
Ri-Ra's Avatar
Oddometer: 6,336
I had a thought.. Any mtb'ers live in the AngelesNotionalForest area, eg. MarshalCanyon, Clairmont'ish area. I'm always looking for people to ride with, hit me up..
"][" {[]} {[]} ][_
Ri-Ra is offline   Reply With Quote
Old 05-11-2007, 02:41 PM   #4008
Oznerol
The Happy Machine
Oznerol's Avatar
Oddometer: 998
Originally Posted by Gummee!
Also far less likely to launch yerself if you 'oops!' and grab too much brake. Useta be less of an issue 'cause like old Tullio sez 'brakes are just there to slow you down...'
Personally, though my right hand has much better dexterity than the left, it's not that much stronger (this suggests that the difference is just a few percent, for most folks). With decent brakes, either hand can generate enough lever force to put me over the bars if I'm not careful, and I can better modulate lever force for progressive braking with the right.
I've never had a problem with grabbing too much brake, set up this way. A couple of days ago a slower moving cyclist stopped suddenly ahead of me, and the surrounding traffic situation was such that I had no alternative but to grab a big handful of front brake. Though my ass was in the saddle, the rear wheel came off the ground a bit (first time I've ever done that on any vehicle). But I was nowhere near going over the bars.
Oznerol is offline   Reply With Quote
Old 05-11-2007, 02:44 PM   #4009
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,502
I've SEEN what happens when noobs grab big handfuls of front brake. Not pretty.
Experienced riders = usually OK.
YMMV
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 05-11-2007, 05:36 PM   #4010
Queen
Escapee
Oddometer: 24,468
Mtn bike or road bike?
If its a mtn bike, just remove the cable ends from the levers and swap the whole shootin match from one side to the other. Iffen its road brakes, then yer gonna hafta unwrap and re-wrap (or cut the housing and install in-line adjusters) and possibly get a new cable for the rear brake. I allatime re-use the rear cables as fronts. Saves $$
:wrenchin
M
MTB, good thing since my re-wrap jobs suck!
Queen is offline   Reply With Quote
Old 05-11-2007, 05:39 PM   #4011
Gummee!
Gummee!'s Avatar
Oddometer: 28,502
Kewl. You won't even need any wrenches!
I like that kind of wrenching!
M
Old 05-11-2007, 06:04 PM   #4012
Agitator
Professional Ashole
Agitator's Avatar
Oddometer: 280
not be a hard-on, but I've got an on-topic question
What speed do bicycle digital speedometers go up to? Do all of 'em max-out at the same speed?
And it is a riot when someone tries out a bike and pulls the wrong brake
you win some and you lose some, you can't win them all so it doesn't matter what the hell you do as long as you do something.
Husqvarna 610 "The Humongous"
Yamaha XV1100 Virago
Agitator is offline   Reply With Quote
Old 05-11-2007, 06:12 PM   #4013
KiLeR650
Renegade Wheel-peeler
KiLeR650's Avatar
Oddometer: 7,157
I just bought a new cat-eye after my 6 week old ascent took a dump. It advertised like 189mph max, or something utterly ridiculous like that. If you're thinking motorcycle use, I tried on my KZ. I couldn't come up with a way to mount the magnet that I liked.
Originally Posted by Pete™
It wasn’t one of the good days. It wasn’t one of those banner days that involved pants.
KiLeR650 is offline   Reply With Quote
Old 05-11-2007, 11:36 PM   #4014
Plan B
"Never Cry Shitwolf"
Plan B's Avatar
Oddometer: 1,018
Originally Posted by pierce
I have on all my bikes except my new stumpjumper, which has hydraulics, so its not so easy to switch.
Hey Pierce,
You must have Shimano integrated units because otherwise you just pull the grips and swap the levers (leaving the lines intact) . Most disc brake levers are designed to run swapped out like this. Or, if you are lucky, your levers have a double clamp and you don't even need to pull the grips. I borrow a friends Nomad when I'm visiting Santa Cruz and he rides moto and I ride NA standard so I do a quick swap before the ride and put it back when I'm done.
You can see in this pic of my Avids that the lever clamp is a two-piece/two bolt design which makes swapping a cinch.
There is no right and wrong on brake/side position, it's all just preference.
Go with what you think is safest for you.
Viva la Evolution
Plan B is offline   Reply With Quote
Old 05-12-2007, 12:08 AM   #4015
pierce
Aven'Tourer
pierce's Avatar
Oddometer: 10,101
Originally Posted by Plan B
Hey Pierce,
they are -are- shimano, I guess I should look closer and see if the brakes are seperate from the gears. per specialized webpile, my 03 SJ FSR Disc has...
  • BRAKE LEVERS - Shimano M-525 full hydraulic disc
  • SHIFT LEVERS - Shimano M-510 Deore, 9 speed
  • FRONT BRAKE - Shimano M-525 full hydraulic disc, resin pads, 6" rotor
  • REAR BRAKE - Shimano M-525 full hydraulic disc, resin pads, 6" rotor
  • FRONT DERAILLEUR - Shimano M-510 Deore, 34.9mm clamp, top pull
  • REAR DERAILLEUR - Shimano M-750 XT, long cage
Experience is what you get when you don't get what you want.
pierce is offline   Reply With Quote
Old 05-12-2007, 12:32 AM   #4016
Plan B
Plan B's Avatar
Oddometer: 1,018
Looks like you are golden........should be an easy swap.
How's the weather in beautiful SC? Have you checked out the new bike park down by the boardwalk? (at the site of the old skateboard park)
Viva la Evolution
Old 05-12-2007, 01:23 AM   #4017
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,022
Nice rig!!
What your gear inches on that, what size the chainring?
That's a commuter alright
44
1768.3
Sheldon Brown's website
44
1577.4
That would be more like it in a month of training
6 months ago i was running
44
1389.3
Source : http://www.sheldonbrown.com/gears/
Uncle Pollo is offline   Reply With Quote
Old 05-12-2007, 06:12 AM   #4018
Dranrab Luap
E-Tarded
Dranrab Luap's Avatar
Oddometer: 31,618
Well, I went and test rode the Trek 7.5 yesterday and it totally brought out the hooligan in me.
I pick her up on Saturday.
That's a sweet mount Queen. Those paired spoke wheels look nice. I have a flat bar road bike too. It loses some of the aero advantage and unless you put on bar ends, your hands can get tired. I put short bar ends on mine. Having multiple hand positions can make a big difference in comfort on longer rides.
Dranrab Luap is offline   Reply With Quote
Old 05-12-2007, 07:15 AM   #4019
Queen
Escapee
Oddometer: 24,468
Thanks Paul! I have a Trek 1500 for my road bike so I've got the longer rides covered, this new one is going to be my commuter bike. I think the 32's for tires will be plenty zippy for the commute (as opposed to the mtb tires I've been riding).
Old 05-12-2007, 07:19 AM   #4020
Zodiac OP
loosely portrayed
Zodiac's Avatar
Oddometer: 31,735
Originally Posted by Don_Alejo
44
1768.3
44
1577.4
44
1389.3
For some reason I can't get this calculator to figure my fixed gear ratio (or I'm really stupid this morning).
I think I'm riding a 76 inch - with a 48-17 drive.
You were riding an 89.3 Damn dude, that's huge!
Zodiac is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 06:28 AM.
