Go Back   ADVrider > Fluff > Sports
Thread Tools Rating: Thread Rating: 423 votes, 4.92 average. Display Modes
Old 07-27-2009, 06:52 PM   #11776
InfoManiac
Always Learning
InfoManiac's Avatar
Oddometer: 5,889
Pedaled around the parking lot of one of the LBSs on this a bit today.
Very impressed! Might have to spec it on my next all-mountain rig.
"Goin' to "The Farm" - wherever it may be - makes JM what it is. It ain't the basement - more like a foundation...... and it's better with rough edges." ---DireWolf
"Knowledge is an unending adventure at the edge of uncertainty" ----- Jacob Bronowski
"I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man." -----Thomas Jefferson
Smugmug coupon ----- 5w5TPcXpTtBdw --- Save $5.00!!
InfoManiac is offline   Reply With Quote
Old 07-27-2009, 07:28 PM   #11777
PaleRider
gelande/strasse
PaleRider's Avatar
Oddometer: 9,980
Originally Posted by elchulopadre
Try this, maybe it'll work for you. Never worn a wool jersey myself, though.
What kind of synthetic fabrics give you rashes? All of them, or are there any particular offenders?
... that jersey looks like it might work (I'm not a fan of looking like a neon popsicle anyhow ... not that there is anything wrong with it if'n you look more a part of the Peloton than I )
... I haven't yet figured it out ... Any non-100% cotton T will do the same thing (if'n I B swet'n).
... the detergent thing isn't the issue (I don't think) as I've had the problem for awhile. So, I finally have just broke down and wear a cotton T-shirt and stash a light rain jacket for the quick Colorado cold/rain shower. But that really hasn't been satisfactory
"Spirit ain't worth spit without a little exercise."
- Preacher
One Life. Live It.
PaleRider is offline   Reply With Quote
Old 07-27-2009, 07:30 PM   #11778
PaleRider
gelande/strasse
PaleRider's Avatar
Oddometer: 9,980
After re-reading your post, I think another possibility is that it might be chafing - if your jersey is a bit loose and it flaps around in the wind, the synthetic fibers might be rubbing your skin. If this sounds reasonable, then you can either get a tighter shirt that won't flap, or you can try using body glide, chamois butter or something similar on the affected area beforehand.
... you could be on to something ... I don't like skin tight "condom" fit so my jersey is loose, like a comfortable old T-shirt
... maybe I'll have to man-up and get a smaller jersey ... counter intuitive, huh?
... chamois glide! ... haven't used/heard of that? ... sounds like it may have multiple uses .. maybe that is worth a try
thanks all for the responses
- Preacher
One Life. Live It.
Old 07-27-2009, 07:45 PM   #11779
nomiles
Sledge-o-matic
nomiles's Avatar
Oddometer: 4,020
Originally Posted by PaleRider
This has likely been covered in this thread, but not sure how to search for this specific issue?
Issue:
My poor little sensitive white skin cannot take the synthetic bike jersey material. I break out into a mini pimple mine field on the portion of my back where the jersey drapes. This is worse on long rides (>2hrs.). Almost rash-like. It goes away after a couple of days.
Question:
What alternatives are out there (brand names, material, etc.)? Cotton doesn't do this, but it also doesn't wick the sweat.
sorry no pictures
Kucharik The best wool jerseys for the last 45 years. I have several.
Wabi Woolens newcomers to wool jerseys.
Vintage Velos has NOS jerseys.
Vintage cycling jerseys are very collectible.
Everybody is someone else's weirdo.
nomiles is offline   Reply With Quote
Old 07-27-2009, 08:02 PM   #11780
elchulopadre
Hairodynamic
Oddometer: 2,997
There's a whole bunch of goop designed to keep skin comfy. Good article here. Most of the stuff is creamy, and on long rides I apply fairly liberally to the nether-regions. I also put it in my running shoes when I run sockless (very handy for triathlons).
Body Glide is similar, except it looks like a stick of deodorant. Better for rubbing onto other problem areas, such as nipples and just below my underarms when running.
More information than you needed.
elchulopadre is offline   Reply With Quote
Old 07-27-2009, 08:42 PM   #11781
Signal
Cynical Idealist
Signal's Avatar
Oddometer: 8,627
Um...
This just happened:
there is now no excuse ofr gettin dropped by an old fat guy
'cept now you do need some real zoot Zipp Wheels, maybe the 404's.....
Signal is offline   Reply With Quote
Old 07-27-2009, 08:45 PM   #11782
PaleRider
gelande/strasse
PaleRider's Avatar
Oddometer: 9,980
... I have used good old fashioned Vasoline when running (crotch). ... I'll have to give these products a look as they might perform better, hmmm ... thanks again
hey nomiles! ... thanks for those links ... I'll check 'em out too. (... the Vintage Velos wool are way cool )
- Preacher
One Life. Live It.
Old 07-27-2009, 09:50 PM   #11783
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,614
Back to the chafing now that my computer wants to let me on it!
Seriously: snug is good. Tight is bad. Repeat that till you have it memorized.
Someone mention Swobo? I don't remember right now. PBS usually has some wool stuff. Hincapie made the wool base layer I like the best.
HTH
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 07-28-2009, 08:25 AM   #11784
Javarilla
Escapee
Oddometer: 23,456
Originally Posted by neanderthal
I suggest starting somewhere high, and ending somewhere low.
I'm just saying....
That would be unfair.
I can descend faster than tandems.
I had some bike sprite pull up beside me on the ascent then slowdown and gimme the uber condescending "Man, good for you, out working over this hill." I was just spinning so we talked for a bit. Turned out he wasn't an asshole. Told him, I heard there was powerlifting contest at the top where I get a spotted a minute for every lb more I could lift. We figured he woulda had to finished four hours back in order to finish on my time.
It's good bein' a clydesdale as long as you ride your own ride and don't go chasin' fairies.
Javarilla is offline   Reply With Quote
Old 07-28-2009, 08:27 AM   #11785
Javarilla
Escapee
Oddometer: 23,456
HTH
M
These guys do good work, too...
Earth, Wind & Rider
Old 07-29-2009, 05:08 AM   #11786
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,515
when I was racing a lot (slowly) there was one event with a Clydesdale class every year-no matter how hard I tried I couldn't get my weight up another 5 pounds to qualify. I figure it's gotta be one of the most fun classes anywhere to be in
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 07-29-2009, 06:02 AM   #11787
Askel
Perma-n00b
Askel's Avatar
Oddometer: 10,472
I dunno. Yeah, sometimes you get to duke it out with big dudes that are more muscle than fat- but they inevitably put the clydes in the short version of whatever race you're doing. It's also quite popular with the just started racing and still have a lot of fat to lose crowd.
Doing the short race to beat up on a bunch of novices just doesn't appeal to me. I usually just go age category and have fun surprising a few of the whippets. Besides, these days it seems single speed is the hang out of choice for big guys that can ride.
Askel is offline   Reply With Quote
Old 07-29-2009, 08:28 AM   #11788
Stinez
Rhymes with Heinz :D
Stinez's Avatar
Oddometer: 49,490
I just bought one of these although I kinda bought it as a snowboarding jersey more than a bike jersey.
I hope they're right about going a size bigger...
The GOP puts the "Con" in Conservative.
Stinez is offline   Reply With Quote
Old 07-29-2009, 10:58 AM   #11789
soewe812
Wag more Bark less
soewe812's Avatar
Oddometer: 1,000
Preventative Maintenance Question
How often should I clean and lube wheel bearings ,head set, and the bottom bracket?
soewe812 is online now   Reply With Quote
Old 07-29-2009, 11:00 AM   #11790
Zodiac OP
loosely portrayed
Zodiac's Avatar
Oddometer: 31,742
what type, high end sealed, or none?
Black Shadow of Vincent, falls on a Triumph line
I've got my motorcycle jacket but I'm walking all the time...
Zodiac is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 07:29 AM.
