Go Back   ADVrider > Fluff > Sports
Thread Tools Rating: Thread Rating: 402 votes, 4.92 average. Display Modes
Old 08-18-2009, 08:00 AM   #12001
PASSMORE
Just the last name...
PASSMORE's Avatar
Oddometer: 4,250
Originally Posted by Gummee!
If the tires and rims are ready its pretty simple: sealant and a pump. I hear it makes a big difference in the ride. Kinda like tubies on the road... Lower pressures (more traction) and no pinch flats.
Stan's makes a good sealant. I haven't actually done any of em, but I've read about em both road and mtn
M
Stan's site was where he sent me for do-it-myself
Any downside outside of the theoretical massive unrepairable blowout? Heck, not like I am riding the snot out of this thing. Just for tooling around our place and riding around the back trails with the nephews/nieces...
- Michael
facebook.com/passmoreranch
PASSMORE is offline   Reply With Quote
Old 08-18-2009, 08:12 AM   #12002
Javarilla
Escapee
Oddometer: 23,456
You tried something like my Regal? Old skool but still ridden at the top levels.
I like mine.
M
Regal, eh? S'ok, I'll see if I can track one down for a trial. Thx!
Javarilla is offline   Reply With Quote
Old 08-18-2009, 08:16 AM   #12003
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,487
Until yer out in the wuds, racin, etc. I really wouldn't worry about it too much. Tubeless comes into its own in low-traction sichyashuns.
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 08-18-2009, 09:40 AM   #12004
Oznerol
The Happy Machine
Oznerol's Avatar
Oddometer: 996
I usually run conventional tires converted to tubeless using Stan's on my MTB wheels.
Until you get the hang of it, tubeless makes for much more troublesome, messier tire changes. If you're someone who regularly changes tires to suit the conditions of a particular trail you're about to ride (doesn't sound like it), that's a problem.
Even after you get the hang of it, getting a tire mounted tubeless using only a floor pump can be a bit dicey -- unlike with a tube, you don't know 100% for certain that you're going to be able to get the beads seated. An air compressor helps make the process a lot more reliable.
The big advantage of tubeless is the ability to run lower pressures without risk of pinch flats. The extra traction and small bump absorption this provides on technical trails are both great.
But for the riding you describe, it's probably not worth it. If you're not regularly having your rear wheel spin out on steep climbs or failing to make it through rock gardens because of your front wheel getting bounced around like an overinflated basketball, then you won't notice a huge difference by going tubeless
Oznerol is offline   Reply With Quote
Old 08-18-2009, 10:08 AM   #12005
elchulopadre
Hairodynamic
Oddometer: 2,997
What's wrong with Trek's touchup paint? Didn't get any?
M
Nope, neither shop had any. But I spoke to a rep at Trek, and he said nail polish was fine. I'm going to try to apply it in dimple patterns for aerodynamic efficiency.
elchulopadre is offline   Reply With Quote
Old 08-18-2009, 01:48 PM   #12006
Flaco
Zombie Holocaust
Flaco's Avatar
Oddometer: 2,324
Originally Posted by ImaPoser
I fell in love with the Look 566 on a test ride up in Chicago. It's at the top of my list, but also above the top of my price range.
I would probably be just as happy with a specialized roubaix, which at the component level I want is just barely within my price range.
Then, there's a handful of others in contention based on just how deep the dealers are willing to discount them as they are leftovers.
Just so long as they match my riding gear, it's all good.
Excel Sports in Boulder often closes out Look frames.
VIVA LOS MTNADS
Flaco is offline   Reply With Quote
Old 08-18-2009, 01:56 PM   #12007
Gummee!
Gummee!'s Avatar
Oddometer: 28,487
Originally Posted by Flaco
I've been lusting after a Look (ot Time) for a long time. Too bad they're still spendy even on closeout!
AFA the interview: Didn't sound too promising
M
Old 08-18-2009, 02:34 PM   #12008
Flaco
Zombie Holocaust
Flaco's Avatar
Oddometer: 2,324
Downside?
Adding a large amount of complexity to something very simple and straightforward?
VIVA LOS MTNADS
Old 08-18-2009, 02:59 PM   #12009
ImaPoser
adventure imposter
ImaPoser's Avatar
Oddometer: 15,825
Oh man, thanks. They got what I want at 30% off. Any idea how much it would cost to build up a frameset with ultegra level components and comparable wheelset?
If I could only be certain about which size frame to get. The geometry numbers are so screwy on relaxed bikes any more.
ImaPoser
Save 20% when you open your own smugmug account. Just go here...
ImaPoser is offline   Reply With Quote
Old 08-18-2009, 05:37 PM   #12010
flip18436572
Broke ex-YMCA employee
flip18436572's Avatar
Oddometer: 3,047
I bought a bit o stuff from there too.
Oh, speaking of buying things... I'm headed to an interview tomorrow PM to be the manager of an LBS.
I'll let y'all know what happens.
M
Are you planning on staying put????? I thought you were always moving.
Do you like bicycles, running, triathlons, marathons, etc........ Go to http://www.friedquads.com and thank BALDY!!!!!
flip18436572 is offline   Reply With Quote
Old 08-18-2009, 06:12 PM   #12011
Gummee!
Gummee!'s Avatar
Oddometer: 28,487
We're in a lease till Dec. IF I'm makin $$, we're here till Spring-ish. Then we're prolly headed back to Denver for a long time.
M
Old 08-19-2009, 04:32 AM   #12012
flip18436572
Oddometer: 3,047
Did you get the interview?
I have to got to work. Planning a 40 mile ride as soon as I get done working and then quoting some other jobs.
Old 08-19-2009, 06:22 AM   #12013
NativeSon
NativeSon's Avatar
Oddometer: 6,761
http://www.competitivecyclist.com/za...LCULATOR_INTRO
see if that helps
edit: i've never used it, but I've always been curious by it.
NativeSon screwed with this post 08-19-2009 at 06:35 AM
NativeSon is offline   Reply With Quote
Old 08-19-2009, 06:53 AM   #12014
ImaPoser
adventure imposter
ImaPoser's Avatar
Oddometer: 15,825
see if that helps
Been there, done that. But, like I said, the current bikes I'm looking at have weird geometry with things like curved and angled top tubes, and are intentionally made to not conform with what would be considered "normal" top tube to seat tube ratios and whatnot. The bike I'm riding now has a 61cm top tube. The model I'm considering has a 55cm top tube. They are both listed as being size large. You have to take in to account seat tube/head tube angles, head tube height, length from BB to head tube, etc.
I may end up with just having to choose from what I can actually get a test ride on from the LBS and rule out those that aren't sold locally.
ImaPoser
Old 08-19-2009, 07:03 AM   #12015
NativeSon
NativeSon's Avatar
Oddometer: 6,761
I don't know enough about bikes for that to make sense to me. good luck though.
Thread Tools
Times are GMT -7.   It's 12:35 PM.
