10-10-2009, 04:25 PM
#12541 | |
Aven'Tourer
Oddometer: 9,702
in general, the setup is pretty much like a motorcycle. with your full weight on the bike, the suspension should be preloaded about 25-30% of its full range travel, and there should be just enough damping to keep it from pogoing. once I have the preload set correctly (I had to replace the spring in my forks with a much stiffer one, and I put about 220PSI in my rear Fox Float R air shock to offset my 225lb bulk), then I start with the damping on the minimal (none) setting, and increase it until it just damps out the bounce. assuming you have an air shock in the rear, do realize, you need a special HP pump for those, don't go thinking you can get 200PSI or so out of a normal bike pump or tire inflator.
Experience is what you get when you don't get what you want. pierce screwed with this post 10-10-2009 at 04:34 PM |
10-10-2009, 05:43 PM
#12542 |
That's MR. Toothless
Oddometer: 25,543
I've heard good things about 531 tubes...
Them and 753. There's a 753 La Vie Claire Look that I have lust for. M
There. I've moved back to VA. Can you PLEASE change the weather?! |
10-10-2009, 05:57 PM
#12543 |
Destroyer of Motorcycles
Oddometer: 2,207
I rode 63 miles on a group ride ("Ride for the Cure"). I've only been on a few group rides and assumed this would be like the other....all riders start at the same time but ride their own pace to the finish.
I was surprised when the ride organizer announced that we would all ride together at "no faster than 15mph" and if we get ahead of the police escort then we are "on our own with no support". It wasn't too bad really til the last leg when the whole group (22 riders) pulled over and waited..in the sun...on the shoulder of a busy road while one of the ride organizers fixed a flat. The support vehicle that stopped was out of water. We rode the last 15 miles at around 12-13mph "because of all the hills". This was around Darien, GA on the way into Brunswick. I had a good time and it was for a great cause...but am not sure if I'd do it again knowing it was so structured. I think riding to the ability of the slowest rider is dangerous...whether on a bicycle or motorcycle. Are group rides such as this one typical? As in, all the riders must stay together or "get no support"? It was the easiest 63 miles I've ever ridden. |
10-11-2009, 09:02 AM
#12544 |
Takin' a trip?
Oddometer: 709
What is the consensus on slime tubes for road bikes? My experience has been less that satisfactory. Last summer I bought two and put them on my bike, or tried to put them on. Both blew out at 85 PSI (the max pressure for the cross tires I was running. I must have forgotten that because I orderd two more last week after two flats caused by small wires I picked up.
Last night I put on the front, pumped it up to 120 and walked away. About ten minutes later, POW. Is it me, or is it the tubes. |
10-11-2009, 09:09 AM
#12545 | |
Oddometer: 25,543
![]() IMO you're better off with the kevlar liners (not Mr Tuffys Too farging heavy and a PITA)One of the ways to get a sealant inside yer tire is Tufo sealant. You'll hafta have valves you can take the cores out of... Put the Tufo goop in there and you *should* be ![]() M
10-11-2009, 09:33 AM
#12546 | |
adventure imposter
Oddometer: 14,829
This sucks
It's sunny and beautiful outside. But, 42 degrees.
I have no idea how to dress for riding when it's not hotter than hell outside. Let me guess, about 200 pages ago, this was discussed thoroughly? Anybody wanna help a poser out?
ImaPoser Save $5 when you open your own smugmug account. Use code: DeAGMxYPTdjUA Quote:
10-11-2009, 09:55 AM
#12547 |
Oddometer: 25,543
base
light insulating layer SS jersey vest thick-ish arm warmers shorts tights or knee warmers or leg warmers toe booties or shoe covers DO NOT wear cotton. ![]() M
10-11-2009, 02:33 PM
#12548 |
In giro in moto
Oddometer: 8,321
Yup, you got it, Gummee. Layering is where it's at.
Cover your ears, too. There are several brands of hats made for fitting under a helmet that work great. A neck gaiter is nice, too.
Siamo tra qui e lė. |
10-11-2009, 04:59 PM
#12549 |
Perma-n00b
Oddometer: 10,398
Busted by the Man!
OK, so we weren't actually cyclocross racing *in* the cemetary, just at the park next door, but it must have been close enough. Apparently once the mayor started getting phone calls at home, they sent in the police. We had permission and everything, so they just took all our beer (Hey, those were our trophies!) and left. It was about 37 degrees out, so nobody really missed the beer much anyway. We just want to know where the cops are going to be partying tonight.
10-11-2009, 05:09 PM
#12550 | ||
adventure imposter
Oddometer: 14,829
10-11-2009, 06:37 PM
#12551 | |
Oddometer: 2,207
You should be cold the first 10 minutes (or so) of your ride (otherwise, you overdressed). Cold tolerance is something that can be acquired. YMMV.
10-11-2009, 07:02 PM
#12552 | ||
adventure imposter
Oddometer: 14,829
![]() It got up to the low 50's here today. To cut the grass, then take the boy fishing, I wore long johns under jeans, medium thickness wool socks in insulated boots, an underarmor long sleeve base layer, t shirt, long sleeve tshirt, then a hoodie sweatshirt(yes, four layers). That was with plenty of sunshine. I am one cold blooded mofo. It can get up to 80 and I'll still be wearing long pants and long sleeved shirts.
10-12-2009, 08:30 AM
#12553 | ||
Oddometer: 25,543
Cover them knees! Old rule of thumb: if its below 60, put something over yer knees. I fudge that a bit and go mid-50s, but the thought's the same. Quote:
Oh, and always ride into the headwind on the first part of yer ride, that way you have the tailwind (in theory!) on the way home. Do it the other way and yer gonna be bucking a headwind when yer all sweaty an shit. Not nearly as much fun. DAMHIK ![]() M
10-12-2009, 12:00 PM
#12554 | |
"Tacticool"
Oddometer: 934
There is never a tailwind...
"To the everlasting glory of the Infantry!" Diligentia -- Vis -- Celeritas Rob Save $5 on SmugMug-- zpTBLRFvcME2c |
10-12-2009, 01:03 PM
#12555 | |
Oddometer: 25,543
Yer just going the wrong way! M
| Thread Tools | |
