Go Back   ADVrider > Fluff > Sports
Thread Tools Rating: Thread Rating: 402 votes, 4.92 average. Display Modes
Old 05-21-2010, 04:05 PM   #14281
trailer Rails
trailer Rails's Avatar
Oddometer: 4,065
Originally Posted by Askel
My main beef with disc brakes on road bikes is that it's tough to find a good deal on wheels with 130mm disc hubs. So very few CX bikes actually spec a 135mm rear hub.
Yup, I just have a 135mm hub shoehorned in the back of my cannondale.
trailer Rails is offline   Reply With Quote
Old 05-21-2010, 06:33 PM   #14282
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,487
You can get away with that on a steel bike. You may wanna take out a few spacers and get that spacing back down to where the bike wants it.
AL don't like being stretched...
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 05-21-2010, 09:00 PM   #14283
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,090
M
I may be sitting on a ticking time bomb, but my klein road bike (built for 126mm hubs) is now using 130mm hubs, with no apparent problems. It does add a couple seconds to rear tire changes.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 05-21-2010, 09:20 PM   #14284
pierce
Aven'Tourer
pierce's Avatar
Oddometer: 10,099
I gotta stretch the back of my cruiser about 1cm. haven't measured it yet, but it used to fit a 70s vintage 5-speed freewheel mtn bike hub, and now it has a late 90s 7 speed cassette hub which is about 1cm wider. was reading on sheldon brown's site about using a 2x4 ;)
went for a good ride around town this afternoon, took the levies, checked out the bike routes around the harbor.
Experience is what you get when you don't get what you want.
pierce is offline   Reply With Quote
Old 05-22-2010, 05:15 AM   #14285
trailer Rails
Oddometer: 4,065
M
I am not worried, it is a 5mm difference, 2.5mm on each side. The bottom bracket shell flexes more than that back and forth when I crank up a big hill.
Old 05-22-2010, 09:58 AM   #14286
Gummee!
Gummee!'s Avatar
Oddometer: 28,487
Just keep an eye on yer chainstays. They crack in this situation. I'm sayin this as a mechanic, not just some wanker on the 'web.
M
Old 05-22-2010, 11:37 AM   #14287
pierce
Aven'Tourer
pierce's Avatar
Oddometer: 10,099
another consideration is if when spread, the dropouts are still parallel. if they aren't, it puts a nasty torque load on your axle and can lead to either bearing failure or broken axles.
Old 05-22-2010, 12:12 PM   #14288
trailer Rails
Oddometer: 4,065
Thanks guys,
I have been a bike mechanic for the last 18 years, I know a thing or two about these things.
I am not sure how to figure this out but I think my chainstays are somewhere around 15", I moved them 2.5mm. OMG, that has to at at least a quarter of a degree out of alignment. It is amazing my my axle did not break or my bearings did not fail already!
Old 05-22-2010, 12:25 PM   #14289
pierce
Aven'Tourer
pierce's Avatar
Oddometer: 10,099
Thanks guys,
15" is 380mm. atan(2.5/380) in degrees == about 0.4 degree.
yeah, thats not a lot, but when you clamp down that quickrelease, you'll be applying torque on the dropout as well as the axle... if there's any carbon fiber in your stays, i"d be watching the joint where the dropout joins the stay. stressed carbon is unhappy carbon.
Old 05-22-2010, 02:18 PM   #14290
Gummee!
Gummee!'s Avatar
Oddometer: 28,487
yeah, thats not a lot, but when you clamp down that quickrelease, you'll be applying torque on the dropout as well as the axle... if there's any carbon fiber in your stays, i"d be watching the joint where the dropout joins the stay. stressed AL is unhappy AL.
fixt
M
Old 05-22-2010, 06:05 PM   #14291
pierce
Aven'Tourer
pierce's Avatar
Oddometer: 10,099
heh. resurrected another pile of junk from my driveway. my boy's old GT Rebound, something we'd bought used when he was 5' tall, that he long ago outgrew... this is the bike that donated its wheels to repair my cruiser as overly documented above....
so, I took the wheels of my other kids even tinier Hardrock, cleaned up the GT, readjusted everything, a bit of triflow on important bits, soaked the chain in WD40 and wiped down several times, then airdried and dribbled a bit of triflow on it, and took the uber-phat gel seat I'd just gotten for my wife's ancient heavy stumpjumper, and removed the lame bar end extenders (never liked those things, the balance is just wrong with them). I hope my wife likes it, its trigger brifters instead of friction thumbshifters like her old bike, and the pedals are funkier (but I could probably swap those), but its 10 lbs lighter, and rides great, and the old Rock Shox still has some boing to it. I think this is one of the old rockshox that used a polymer spring-shock thing, but its got some adjustments, and on stiff and hard, its not bad at all.
I wonder if she'll like it? (she's gone til tomorrow, then we leave Wednesday for the spring strawberry music festival, where I expect she'll be riding it). I still have to figure out how to mount the fenders on it as its likely to be a wet and muddy strawberry. I'm thinking I can use some kind of clamps on the springer forks, and hang the fender from the brake bridge. the back of the bike has fender lugs already. the fenders are off -my- old stumpjumper, which is now my son's college ratbike. loved riding those old things but they are -so- heavy. strongest bike frame ever made, I do think.
pierce screwed with this post 05-22-2010 at 06:31 PM
Old 05-23-2010, 02:49 PM   #14292
trailer Rails
Oddometer: 4,065
fixt
M
Thanks guys, but do you have any idea how much your frame flexes when you climb a hill?
Even Al and carbon frames move quite a bit on every pedal stroke.
Old 05-23-2010, 03:08 PM   #14293
Gummee!
Gummee!'s Avatar
Oddometer: 28,487
Yup. I know how much it flexes. I also know that you're pulling it out of its 'happy spot' and bad things happen when you do that.
M
Old 05-23-2010, 03:16 PM   #14294
trailer Rails
Oddometer: 4,065
M
We will see, I have been riding it that way for over 2 years now. I'll let you know when it breaks.
Old 05-23-2010, 09:08 PM   #14295
kbasa
Colnago!
kbasa's Avatar
Oddometer: 69,112
What I did yesterday. There's a sort of messed up section by the Altamont Pass, so this overstates the route by about 9 miles. If you mouse over the graph at the bottom, it'll show you where that is on the map. Free, too!
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 10:46 PM.
