Old 04-30-2009, 05:19 AM   #1516
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
Originally Posted by clay
.The 950 starts perfectly-then purrs at idle.The next 1000 or so rpms is like ridding a bike that has contact points that kick in after rpm builds,then perfect again.I figured the float bowl/needle jet would let it idle,then die when throttle is turned.
CLAY
contact head2wind on this board. He will set you up with a way better jetting solution.
MookieBlaylock is offline   Reply With Quote
Old 04-30-2009, 10:28 AM   #1517
SteveAS
Crank
Oddometer: 193
It sounds like some small orifice or orifices (jets) in the carburetors have varnish deposits from sitting for 18 months. I'd try disassembling them and using carburetor cleaner on all the jets.
SteveAS is offline   Reply With Quote
Old 04-30-2009, 11:03 AM   #1518
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,474
18 months? Oh yeah...carb rebuild time. This is the problem with bikes that sit.
I order all my parts from Munns in Texas, but there are other good choices.
http://www.munnracing.com/
For Sale: 2012 KTM 990 Adventure
Chuckracer is online now   Reply With Quote
Old 04-30-2009, 11:25 AM   #1519
clay
CLAY JUSTICE
Oddometer: 49
bought 950 sm in california
I just thought of something.He bought the bike in ca 4/28/2007.he used it for commuting back and forth to work.When he moved to tampa he worked at home.it was used very little there,That means it is jetted for ca. and also has all of that smog junk still on it.
What do i take off?I will clean carb as I rejett.
THANKS,CLAY
clay is offline   Reply With Quote
Old 04-30-2009, 12:10 PM   #1520
iammemares
Oddometer: 318
Do I gotta?
So on my new to me SMR, it has LV peipes and has been rejetted, though I do not know the detail. It has @ 1300 miles on it now.
I am fairly certain it has not been decannistered, etc. I was planning on doing that. BUT, This thing runs SO WELL. Carburates so well. Starts perfectly, idles perfectly, no flat spots. I am concerned about messing with it. I have heard these can be a bit finnicky on jetting etc. So am I missing something. Sure, it will get rid of a bunch of hosing and a few pounds, but I thought the primary reason for the work was to improve running, stalling, etc. I no gots these problems. What to do?
THX
iammemares is offline   Reply With Quote
Old 04-30-2009, 12:43 PM   #1521
wpbarlow OP
Oddometer: 11,298
13,116 (S)miles
Did a club ride Sunday. Combo of slow 'n tight, and fast 'n twisty and curving. And a bit of slab to get to the start and then to get home. Good time had by all.
No pics from the day; so one from the archives
wpbarlow is online now   Reply With Quote
Old 04-30-2009, 01:59 PM   #1522
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,474
Clay and Immemares (??), I'd suggest if it ain't broke...
Walter, I want one O them SD front fenders!
Old 04-30-2009, 05:37 PM   #1523
Just Bob
Been There Done That
Just Bob's Avatar
Oddometer: 262
If it feels like it surges when you hold the throttle and speed steady at that point raising the needle one clip should smooth it out.
________________________________
Confidence is the feeling you have before you understand the situation.
Just Bob is offline   Reply With Quote
Old 04-30-2009, 06:23 PM   #1524
aeronaut
Oddometer: 422
THX
Decannister will not effect fueling during running at all. Helps startup, and removes hoses. Otherwise, your choice.
aeronaut is offline   Reply With Quote
Old 04-30-2009, 06:58 PM   #1525
MookieBlaylock
Oddometer: 2,581
canister really has to go. once fuel gets backed up into the canister,and it will with a full tank and a hot day or a tipover, the carbs cant vent. The starter gets abused the battery dies and you get stranded.
Old 04-30-2009, 07:12 PM   #1526
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Just Bob +1 on that. When I got my bike I noticed that at low RPMS and around a steady 35 mph or so the bike had a slight surge. When I took it in for the first service that is exactly what they did and it solved the problem. Still running stock cans and jetting (hoping to get some Wings this summer) and the bike has been a champ. I did de-sas it but was too lazy to remove the rear cannister in the tail.
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 04-30-2009, 07:18 PM   #1527
EastSideSM
Oddometer: 1,490
Hey Walter I just noticed I am catching up to you, I've got almost 11,856 smiles on my Katie.
Old 04-30-2009, 09:34 PM   #1528
iammemares
Oddometer: 318
OK so decan it is.
For those that have decaned, has there been any need to adjust jetting or air/fuel screws, etc.
If the the no start condition occurs due to the canister, what is the immediate solution. Waiting, bump starting, turn off the fuel supply for a while,??
Old 05-01-2009, 08:08 AM   #1529
aeronaut
Oddometer: 422
For those that have decaned, has there been any need to adjust jetting or air/fuel screws, etc...
Removing cannister and the carb jetting are unrelated. So if you're happy with jetting as is, the answer to your question is NO.
...If the the no start condition occurs due to the canister, what is the immediate solution. Waiting, bump starting, turn off the fuel supply for a while,??
10-30 seconds of starter cranking worked for me. But eveyone's bike seems to be a little different in this respect.
Old 05-01-2009, 10:36 AM   #1530
wpbarlow OP
Oddometer: 11,298
Keep going! My "problem" with accumulating miles on the SM is that I always have other bikes I like to ride for different reasons/circumstances- so no one bike gets really significant mileage. I like the SM the best; but like the others as well.
Times are GMT -7.   It's 03:58 PM.
