Old 05-03-2009, 06:15 AM   #1546
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,349
Originally Posted by Taipan
Thanks for checking. Is your play damped as if the wheel is hitting rubber or does it clocnk like say tapping a screwdriver handle on the wheel rim, if you see what I mean?
It's metal on metal. The bushings in the wheel have metal sleeves in rubber, and the sprocket carrier has steel pins. I keep mine greased, but never noticed any noise or vibration coming from that area.
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 05-03-2009, 06:19 AM   #1547
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,863
Could you 950SM owners do me a favour please? My bike has a vibration problem which I'm trying to find. I just grabbed the rear sprocket and there is some for and aft play, which I expected to be between the cush drives. But mine isnt like that its metal hitting metal??? Can you see what yours is like please.
Many thanks
The cush drive bushings on these bikes are rubber with steel sleeves on the outside and inside diameters, so the pins on the sprocket carrier are actually contacting metal on the ID of the bushes.
Edit: Dang it! You're too fast fer me, Chuck.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 05-03-2009, 06:23 AM   #1548
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,349
Great minds think alike...
Old 05-03-2009, 07:09 PM   #1549
Bofaxrunner
Bofaxrunner's Avatar
Oddometer: 95
Originally Posted by aeronaut
FYI, I had a strong desire for a steering damper also. But, once I installed lower and more forward handlebars, and revalved/resprung forks, I never find myself wishing I had a steering damper.
Just Curious, what spring/valving changes did you have done to the fork?
Also, what's your weight and height for reference?
Thanks in advance.
BTW, I installed a Scotts and love it. I've been wanting to work on the forks, they just don't feel quite right.
Bofaxrunner is offline   Reply With Quote
Old 05-03-2009, 09:11 PM   #1550
nattyMo
Oddometer: 571
Yeah I was thinking of waiting on the damper until after I did my forks but after 650 miles of windy miles this past weekend I thought I'd go ahead and get the damper. I've been running the forks moved up in the tripple clamps by 10mm. Really like the way it turns into corners now but the stability in cross winds at highway speeds has diminished somewhat, esp in traffic. I don't think the modified fork dampening would affect the stabiliy much on the highway. I could drop the forks back down but as I said it turns so sweet in the twisties I enjoy most that I think I'll keep them raised and run a damper.
nattyMo screwed with this post 05-06-2009 at 06:44 AM
nattyMo is offline   Reply With Quote
Old 05-03-2009, 09:28 PM   #1551
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,349
Natty, what tires are you using?
Old 05-04-2009, 09:31 AM   #1552
nattyMo
Oddometer: 571
Iím using the stock Scorpion Syncs. Just installed my third set. Thus some of what I was feeling last weekend may have been due to the worn tires (4500 miles on them at the time). That said I've always felt a bit of wiggle at highway speeds in traffic and I've been playing with the idea of a damper for some time now. I know Walter and a few others are using the SD fender and find the bike a bit more stable in turbulent air, I was considering that idea as well. I donít think the damper is a MUST have more of a nice to have item for the type of roads Iím on 80% of the time. Still having used dampers on other bikes I keep thinking one would be a nice addition to the SMR.
Old 05-04-2009, 01:30 PM   #1553
MotoSteve
Functioning Motard
MotoSteve's Avatar
Oddometer: 363
I'd like to here more from people who have used a damper on the SM/SMR.
My understanding is it will help absorb deflections (and keep you on line)when you hit a rock or pothole, and help calm the front when really getting on it or setting it down from a wheelie. Seems like a nice safety feature on the street as well as for track days.
With the Scotts you can adjust the slow speed damping way down for the street, so you feel no drag on the bar when turning, while still maintaining the separate high speed circuit as a safety margin for when you hit something that would otherwise have taken you off line.
http://www.dirtbikeworld.net/Reviews...per_text2.html
KTM 950sm, Rattler 110.
MotoSteve is offline   Reply With Quote
Old 05-04-2009, 01:47 PM   #1554
aeronaut
Oddometer: 421
Originally Posted by MotoSteve
My understanding is it will help absorb deflections (and keep you on line)when you hit a rock or pothole, and help calm the front when really getting on it or setting it down from a wheelie. ..
In this case, a steering damper simply masks the problem of far too much high-speed-compression-damping in the front forks. Spend your money on revavled forks rather than steering damper.
That's my opinion, for what's it's worth!
aeronaut is offline   Reply With Quote
Old 05-04-2009, 02:01 PM   #1555
nattyMo
Oddometer: 571
Well that didn't take as long as I thought it would.
After a nice little deposit showed up in my checking account today (Thanks Uncle Sam), I forgot all about my auto repair blues. I just went ahead and ordered the Emig damper for my SMR. Should have it by Friday and installed with the new tires scrubbed by Sunday, if all goes well.
I'll report back first hand on the damper vs. no damper next week. Provided it stops raining and I can get the new tires scrubbed in...
Props to Emig, super to deal with.
Old 05-04-2009, 02:51 PM   #1556
Just Bob
Been There Done That
Just Bob's Avatar
Oddometer: 261
Before you all run out and buy a damper try this. Next time it feels like its wagging its head, try moving your weight forward a bit by sliding forward and/or bending forward and lighten your grip on the bars to about as much pressure as you would use to hold a small bird, ie; almost none.
The 950sm is extra sensitive to weight positioning because of the softer suspenders. And the wide bars set you up for over controlling the front end. Like Keith Code says, the bike is doing fine - its usually the rider messing it up.
Dampers are great on dirt bikes where you ram into big rocks. On road and track bikes they are there to stop a tank slapper - not head shake which is pretty normal.
Ditto others advice on fork setup having a major effect.
________________________________
Confidence is the feeling you have before you understand the situation.
Just Bob is offline   Reply With Quote
Old 05-04-2009, 03:18 PM   #1557
nattyMo
Oddometer: 571
MotoSteve,
Aeronaut and I both agree that the stock forks have too much High Speed compression dampening. The steering damper will mask this a bit. In an ideal world I'd have two (or more) rides and would have already sent my forks off to be re-valved. Sadly I'm down to one bike and don't want to miss any riding season hence my choice to bolt on the damper and keep riding until the snow flies.
The damper will aid handling in ways that suspension set up alone won't. Tracking across any object you may encounter especially ruts and railroad tracks, plus keeping the back end inline under hard braking and aiding in overall stability at speed.
All said the first step should always be to set your Sag and get your suspension working as best it can prior to adding the damper. I'm going about it a bit backwards by choice. Once I have the down time to do the forks I'll likely remove the damper when setting them up again.
Old 05-05-2009, 12:17 PM   #1558
MotoSteve
Functioning Motard
MotoSteve's Avatar
Oddometer: 363
All valid points, thank you.
I am not an expert rider and have limited knowledge of suspension set up. So I had a retired, national level SB racer of the same body weight set up my suspension for me. It feels great and even his opinion was that a damper was not necessary on the 950sm.
So now my suspension is sorted nicely and I've worn out my copy of Twist of the Wrist 2. Truth be told, I have not(luckily) had a situation where I needed the damper on the 950sm. Maybe I am just buying into the sales pitch and marketing.
Some folks just swear by them and say it is there to save your butt when you really need it.
I'm on the fence. They are expensive and maybe I should just spend the money on a few track days instead.
Old 05-05-2009, 12:40 PM   #1559
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,863
What tires have you guys used that you would characterize as being kind of slow- or heavy-steering? Or, at least linear in steering response.
I have a set of 950SM wheels for my SE with Pilot Powers, and the handling is way too nervous for my taste. The huge reduction in trail with the 17" front is the root of the problem, the the triangular profile of the PP is probably contributing to it. A shallower, more rounded profile would probably work better.
The Distanzia SM is the slowest-steering tire I've ever used, but it's not available in a 180/55-17 (a mistake on Avon's part, IMO). The Uly guys are using the 160/60-17 on 5.5" rear wheels with good success, but I'm not sure I want to go there.
Any recommendations on a stable-feeling sport or sport-touring tire that might help calm this thing down?
Stobie
-Albert Einstein
Old 05-05-2009, 01:28 PM   #1560
Taipan
Taipan's Avatar
Oddometer: 94
That does indeed confimr mine is "normal". Thanks for checking that guys, its appreciated.
Taipan is offline   Reply With Quote
Times are GMT -7.   It's 12:07 AM.
