05-05-2009, 06:18 PM
#1561 | |
Old and In The Way
Oddometer: 1,082
05-05-2009, 06:28 PM
#1562 |
Small Town Hick
Oddometer: 369
I have to admit that when I had more free weekends and was able to do several track days, my senses were just sharper and I was able to appreciate minor tweaking of suspension settings. So much so that I ended up with Ohlins on the rear and a performance-pro 929 front end on my track only superhawk.
But now I'm older and fatter and just plain not capable of being dissatisfied with the SM's WP pieces. I am sure that on a track I would feel different about it, but on the street I am crazy about the characteristics of the long travel and added plushness at my disposal while still behaving like a hooligan. In fact, I haven't ever had a bike that came with so much "range" of adjustment. You guys must be really pushing it to find its weakness! Keep in mind I do lots of miles on a KLR nowadays. It makes jumping on the SM that much more incredible every time. Cheers
*********************** 12 Super Tenere...........04 DRZ 400E 06 950SM (Yehaw!!).... 96 DR350SE 06 KLR 98 VTR (Track Bike) |
05-05-2009, 06:30 PM
#1563 |
More Ride, Less Google
Oddometer: 5,751
Pirelli Diablo Stradas - the "Sport Touring" tire.
I've been through three sets of Syncs (20k miles) and got tired of the sliding and tread squirm on the pavement. I had a set of these on my Ducati 749 and loved them - they get sticky to the touch in the twisties and should last a long time. But more importantly to this topic, the front tire steers quite slow and steady. Important to me because I was dropping the front 10mm, and I hate steering dampers. The bars move a little when I get ham-fisted throwing the bike around, but I don't care. She ain't going anywhere. She's just a Thoroughbred reminding me shes alive!
2003 Kawasaki KLR650 "Reality" 1993 Ducati 900SS "L'evento" |
05-05-2009, 07:30 PM
#1564 |
Oddometer: 509
Got my bags finally!
Thought Id throw up a couple shots of the SMR with the rack and bags I got for it.
I also added heated grip inserts and built a little dash to mount the switch on. Not sure how I feel about it yet. I may build another one with a different shape. http://img354.imageshack.us/img354/8071/smr001.jpg http://img24.imageshack.us/img24/7503/smr002.jpg http://img9.imageshack.us/img9/1566/smr004.jpg http://img25.imageshack.us/img25/9449/smrrack.jpg http://img9.imageshack.us/img9/104/smrj.jpg 900rider screwed with this post 05-06-2009 at 06:38 AM |
05-05-2009, 07:32 PM
#1565 | |
Oddometer: 554
05-05-2009, 08:52 PM
#1566 | |
Oddometer: 5,751
05-05-2009, 09:27 PM
#1567 | |
Functioning Motard
Oddometer: 361
Nice looking bike! I'm mounting the same grips and switch on mine and have seen a few others do the same. All have placed the switch on the dash, just above the ignition to the right of the speedo. It looks pretty clean that way, almost stock. I'll post up a pick later in the week if you like.
KTM 950sm, Rattler 110. |
05-06-2009, 02:34 AM
#1568 |
Oddometer: 90
If you fit race cans do you have to disconnect the SAS?
Recently fitted some race cans to my 950SM. Sadly I wont be keeping the bike much longer so dont want to make any major changes to it as I'll revert it to standard to sell. But is it necessary to disconnect, if not remove, the SAS system once you have fitted race cans?
05-06-2009, 05:59 AM
#1569 | |
Oddometer: 509
My switch needs a 13/16 hole and I didn't think it would "fit" well up by the spedo. I also didn't want to make a change to the bike that I could not undo without buying a replacement part
05-06-2009, 06:22 AM
#1570 |
Oddometer: 554
900rider,
Nice looking setup. Who's rack is that? Also the large photos are causing the page to load S-L-O-W. |
05-06-2009, 06:37 AM
#1571 | |
Oddometer: 509
The rack is a TCI Denali rack. http://www.turbocity.com/product_inf...roducts_id=641 I bought the rack and bags from newenough.com |
05-06-2009, 06:54 AM
#1572 | |
Oddometer: 554
nattyMo screwed with this post 05-06-2009 at 07:36 AM |
05-06-2009, 07:30 AM
#1573 | |
Oddometer: 509
05-07-2009, 08:20 AM
#1574 |
Oddometer: 317
Chain Lube
I will research this also.
I have a 950 SMR. This is my first non shaft bike in 20 years. Have no clue how to take care of a chain these days. I have done some asking around and the responses seem similar to the oil question. So on the standard O ring chain, how often and how do you clean the chain and how often and how do you lube it? Some say wipe it down with WD40 and do no more, others say use this special non fling Bel ray product, yet other say do nothing it is internally lubricated. (OK what about sprocket wear then?) Help a brother out. How do we take care of these big twin chains. BTW, no off road for my SMR. Thank you. |
05-07-2009, 08:34 AM
#1575 |
Oddometer: 5,751
Answers will vary and opinions will fly, just like an oil thread.
Here's my 2 centavos: I get at least 20,000 miles out of any chain and sprocket set by wiping the chain with WD-40 occasionally and lubing it when it's warm with a small amount of Bel Ray Super Clean, sprayed on the inside of the chain run to cushion the roller-to-sprocket impact. It works. *edit* While we're here, don't adjust it too much. Let it run loose. A loose chain is WAY better than a tight chain.
