05-07-2009, 08:37 AM
#1576 | |
Oddometer: 393
05-07-2009, 08:45 AM
#1577 |
Oddometer: 315
Chain Maintenance
As noted, lots of different opinions on this. I have 12,000 miles on my 950SM. Sprocket is just starting to show a little wear. I am guessing I will replace the chain and sprockets before I hit 15k. I never clean or lube my chain. All on road riding, very lttle wet weather, 16T counter...
For what it's worth.... |
05-07-2009, 08:48 AM
#1578 |
Retriever
Oddometer: 632
Can't argue with a guy that gets 20,000 out of a chain on a big V-Twin. I've always found the Bel-Ray to be little messy. I use the Honda chain oil in the Red can.
I always try to run my chain looser than tighter. Modern chains are really pretty easy to care for.
JBird Aprilia Tuono Factory KTM 950SMR '02 Suzuki V Strom '08 Goldwing '08 CBR1000RR '98 Golden Retriever |
05-07-2009, 01:58 PM
#1579 |
Oddometer: 317
I Get it.
So maybe my thoughts on chain maintenance are based on old tech chains. Sounds like use of WD for cleaning and some occasional light application on the sprocket side of the chain to minimize sprocket wear is all that is needed. 20K out of chains and sprocket sounds good to me.
Thanks all. BTW, on a seperate note. I was trying to come up with a way to use my smallish Givi topcase as well as the KTM soft side removable tail bag. I think I got it. So when I purchased my bike it already had a metal plat (I think KTM part) with the SW Motec adapter and KTM removeable tail bag installed. I like this tail bag, but wanted to be able to install my Givi case for longer rides. Firstly, I ride this bike solo, so the rear handles came off and hard rubber spacers went in place of the handles under the rear KTM plate. Nextly, I was able to directly bolt the GIVI monolock plastic universal mount plate to the KTM plate without drilling any holes. Remount the KTM plate to the bike with the Givi plate bolted to it and Viola, Now I can use my Givi topcase or the KTM softside top case just by changing the adaprter plate that bolts to the KTM rear plate. Also, had my rear tire go flat yesterday. Truned out to be the Valve core being loose???? Check your valve cores. |
05-07-2009, 09:30 PM
#1580 |
Oddometer: 317
Bummer
So I bought a valve core tool to try to tighten the rear core and it was already tight and partly broken.. Now I have a completly broken core that I cannot remove. Took the wheel off. Going for a new valve assy. Glad this happened while at home. I have never had this happen. Seems like the core was originally improperly installed or overtightened. Any other have such an experience?
05-07-2009, 10:32 PM
#1581 |
Oddometer: 32
Re Chain
Chain manufactures recommend not to use wd40 or similar to clean your chain as it is a penitent and gets into the links and washers out the grease from the rollers causing premature were. I just wipe my chain with a rag and if particularly groty I wet the rage with kerosene and then hose off I lube the chain about every 800km depending on conditions with a premium chain lube my bike has done 23000km and I have never even had to adjust the chain and there is no visible were on the sprockets |
05-08-2009, 05:50 AM
#1582 |
I am smiling
Oddometer: 105
carb sync
Over in the OC I read that the proper way to sync. the carbs is to first sync at idle using the "air" screws, then at 3-4k rpms using the screw to adjust the linkage. In the HOW section it says to sync at idle using the linkage screw? Thoughts
Also anyone come up with a cleaver way to feed gas to the carbs while the tank is off.
Dave '06 950 SM '01 1150 GS '96 KLR 650 '88 ZX-10 |
05-08-2009, 10:13 AM
#1583 | |
Oddometer: 393
05-08-2009, 11:16 AM
#1584 | ||
Crank
Oddometer: 193
05-08-2009, 03:47 PM
#1585 |
Oddometer: 32
AERONANT one of the OZ mags ran a article on it some time ago with photos of chains that had been cut open a long with comment from chain manufactures the evidence was pretty damming against WD40 thy did not recommend any particular brand of chain lube so I assume it was a unbiased article.
05-10-2009, 06:24 AM
#1586 | |
Oddometer: 393
05-11-2009, 08:13 AM
#1587 |
Oddometer: 7,889
13, 529 (S)miles
A real nice 413 mile weekend: some hooning around Saturday and a ride to Cebala's in Hamburg Pa. yesterday. Some fantastic roads!
Just one photo with the bike in it.
Walter Barlow |
05-11-2009, 11:10 AM
#1588 |
Oddometer: 66
12V Accessory Plug?
I'm looking to install a 12V Accessory Plug on my SM (for a GPS). It does not look like KTM offers an option, but I'm sure some of you have done this. In fact I seem to remember reading about it, but the ADV search is no help for some reason (Why can't I search on 12V?) anyway will the accessory plug for the Adventure work? Easy project for an electrical neophyte? Any info or a link would be much appreciated. Thanks, all.
I leave you with some pics from yesterday, Hwy 49 north of Truckee (Lake Tahoe). ![]()
2012 Triumph Scrambler 2006 KTM 950 Supermoto * For Sale! 2006 Suzuki DRZ 400S 2000 Triumph TT 600 |
05-11-2009, 12:31 PM
#1589 | |
It hurts when I fall down
Oddometer: 589
05-11-2009, 03:36 PM
#1590 |
Old and In The Way
Oddometer: 1,082
I'm looking to add an accessory outlet too as my GPS is wired into the ACC1 (or maybe it's ACC2) plugs in the headlight harness. I also need a second outlet for powering my helmet cam. I think I am going to buy one from Powerlet, drill a hole in the headlight plastic somewhere and be done with it.
