Old 05-22-2009, 03:38 PM   #1681
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,467
Renazco. Talk to them...they get it.
2012 KTM 990 Adventure
Chuckracer is online now   Reply With Quote
Old 05-22-2009, 04:18 PM   #1682
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,699
I've been in touch with both Renazco and Bill Mayer and I am on Renazco's list. The Corbin is softer than the stock seat by a large margin. Any breaking in it does will only make it better. My description above for the Corbin was in error. While it is lower than the stock seat, the teper is gone so the seat is wider under the butt and with short legs some taper would be preferable.
I don't find the tippy toe issue a problem normally but I live on the side of a mountain and the only flat spot for several miles is the floor of my shop - and it's not big enough to turn the bike around. Negotiating the yard and the driveway (such as it is) can be problematic when you're inseam chalanged.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is offline   Reply With Quote
Old 05-23-2009, 08:42 AM   #1683
tahoe
tahoe's Avatar
Oddometer: 73
Originally Posted by 6USMC6
New 2007 SMR.
Stock seat is 34 3/4" off the ground.
Corbin is 34".
Both measurements taken on a level floor, bike level, unladen, stock suspension adjustments. The Corbin feels just as high as the stock seat but I think that's because the stock seat is tapered and the Corbin is flatter. I have a 29" inseam and I probably need more taper and less height. As soon as I figure out what I'm going to do I'll post the Corbin for sale here. It's black and orange and will of course fit both an SMR and a Super Enduro.
Thanks USMC. Sounds like the Corbin isn't much of a solution either.
The Renazco is tapered, but it doesn't help much. On mine the taper is actually set back a bit so you have to scoot higher back on the seat to take advantage of it. And the seat is a bit higher than stock. Really comfy though. If you go that route, have James shave more off the sides and top than he usually does. Even so I can't see it being much of an improvement on the Corbin (except maybe looks ).
Keep us posted. I still don't have a solution either but plan on doing something.
2012 Triumph Scrambler
2006 Suzuki DRZ 400S
2000 Triumph TT 600
2004 Moto Guzzi California EVII
tahoe is offline   Reply With Quote
Old 05-23-2009, 11:30 AM   #1684
mayner
Postal
mayner's Avatar
Oddometer: 146
Thought I'd say hello. Bought the SM two months ago and have been racking up the miles and smiles. Farkles on the way.
Just found this thread (Thanks Walter) a couple of days ago and have been burning through it to the bitter end. Took me three days! My wife would call you all a very bad influence.
"Too bad", I say! ;-)
1983 VF750F Honda Interceptor
2012 Yamaha Super Tenere (S10)
2012 Honda CRF250L
mayner is offline   Reply With Quote
Old 05-23-2009, 07:24 PM   #1685
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Mayner:
Congratulations. you are in for lots more smiles!! I'm on my 13,000 th smile after today. Almost one year since new. And thanks also Walter if i haven't thanked you in the past. This thread has been a great source of info and insight. It is great to see others that are getting to enjoy one of the best all around, daily driver, fun motorcycles ever made.
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 05-24-2009, 11:19 AM   #1686
Craiginwi
Brew City Bomber
Craiginwi's Avatar
Oddometer: 31
950sm or smr?
Good day all. I'm new to the forum and looking for some help. I started on trail bikes as a kid, progressed to motocross in high school, jumped to rockets when I got my license and through college and finally ended up on a custom chopper. I've finally gotten smart and am looking for a 950sm or smr. Does anyone have any leads on a used one that's not being loved or one that someone's wife can't stand anymore? I'm looking for a bike I can commute to work with, smoke my rocket friends in the twisties with and potentially ride year round here in Wisconsin. Any help is appreciated. Thanks, Craig
Craiginwi is offline   Reply With Quote
Old 05-24-2009, 12:24 PM   #1687
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,699
Craig,
There's an inmate named Brown Dog who posts on teh SE threads has an SM for sale.
http://www.advrider.com/forums/showthread.php?t=418922
Mike -
Old 05-25-2009, 12:22 PM   #1688
wpbarlow OP
Oddometer: 11,258
14,233 (S)miles
And big smiles they were today
We did a ride called "Monday Morning Mountain Motard Madness": and it was aptly named. 'nuff said
wpbarlow is offline   Reply With Quote
Old 05-25-2009, 01:07 PM   #1689
Garry
Old and In The Way
Garry's Avatar
Oddometer: 1,262
I know better, but I just got around to checking/setting the sag on my SMR. Hey, it's only been 15K miles...
If I believe the manual, the SMR comes with 0.58 fork springs versus the 0.56 springs on the SM. The fork preload was set as expected at 5 turns out (5mm) and I didn't have nearly enough sag with me on the bike (51 mm). I figure I'm shooting for about 68mm (1/3 of total travel).
So now the fork preload is completely backed out (10 turns) and I've only got 60 mm of sag up front. I guess the springs are too stiff for my weight. So now I'm pondering where to get new fork springs, what rate they should be, etc. And also considering having the valving redone because of too much high-speed compression damping that stands the bike up when hitting bumps while leaned over.
FWIW, I reduced the rear preload a couple turns to get it to match the front (60mm sag) to keep the geometry similar.
2007 KTM 950 SM-R
2009 KTM 530 EXC
http://www.MotoRoads.net
Garry screwed with this post 05-25-2009 at 03:56 PM
Garry is offline   Reply With Quote
Old 05-25-2009, 03:47 PM   #1690
doctor_big
It hurts when I fall down
Oddometer: 705
Editorial....
'Scuse me for drawing attention to the fact, but I'm a senior editor for a magazine here in Canada called Inside Motorcycles. Just thought I'd share with you an editorial that I wrote which was published a few months back. Sorry for the length of this post...
As a motorcycle journalist I get the opportunity to sample an inordinately large number of bikes. My job description mandates that I become exceedingly familiar with these bikes so that I can accurately report back to you, the reader, what it's like to ride them. At this point, I've ridden essentially every bike that I've ever dreamed of, and a fair number of those that I never imagined I'd get the opportunity to try. From Benelli's ultra-exotic TNT and BMW's flagship GS1200 Adventure, right down to such less esoteric but still exciting fare as Honda's CBR125R and Suzuki's Bandit 1250.
They've all got their charms, do these incredibly diverse cross-section of bikes. My enthusiasm for both bikes in general and the act of riding them gives me good insight into what makes each machine unique, and helps me to determine what each one is for and the type of rider it's aimed at.
But you know what? I love my own bike, more so than any other I've yet ridden.
I suppose it's just as well that I enjoy my bike. For a while there I was worried that I'd never be satisfied with any one motorcycle, and that I'd always wish for the newest, latest and greatest. However that hasn't happened.
My bike gets a good workout. I use it for track days, I commute on it, and recently I rode the thing 8300km over 14 days from Toronto to Las Vegas and back. It's a sport bike, a tourer and an urban commando assault unit all rolled into one. What bike can do all of these things? My 2007 KTM 950 Supermoto, that's what.
I've always been an avid dirt biker, and to me the upright riding position of the SM feels incredibly natural. I can see above traffic, my feet are underneath my ass, and my arms drape in what I consider the most neutral manner possible. It's easy to move around on the bike, and when the seat gets uncomfortable I just fidget into one of about three alternate positions. I'm good for 1000km days aboard this bike.
I get the strangest looks at track days. While I'm anything but fast (I recently moved up to the intermediate class) I can still hang with most of the guys, and it gives me great pleasure to blunder past some of the slower riders, all upright and clumsy-like.
And there's nothing better for city streets, I believe. I can stop on a dime, accelerate past any car and still hop curbs like I'm aboard a dirt bike. With my heated grips, HID headlight, heated vest hookup and GIVI bag setup, I'm good for short or long distances, warm or cold weather.
So why am I telling you all this? There is a point.
Neither the 950SM nor its successor, the 990SM, are available in Canada for 2009. The bike just didn't sell enough over here (or in the US for that matter) for KTM to warrant bringing in another year's worth. This, in my opinion, is a tragedy. On my recent trip through the US I saw at least ten cruisers for every one bike of any other kind. While I do see the appeal of a cruiser, I know they're nowhere near as much fun to ride as the 950SM, nor even remotely as practical. Also, being unique has to be worth something (but maybe I shouldn't shout this from the rooftops as people might catch on and I'll no longer be, well, special) but that's an intangible which is hard to quantify.
But uniqueness, fun and utility donít seem to be selling factors for motorcycles these days. It seems that many riders choose some sort of an image as their primary consideration when determining a prospective purchase. Iíve harped on before about sport bike riders who never hit the track, and cruiser riders who take more pleasure throwing chrome bits at their bikes than they do riding them. And while thereís nothing wrong with buying a bike as a fashion accessory or dreaming of riding fast even if your bike has a square rear tire, I remain amazed at the number of impractical, uncomfortable bikes that I see on the roads, while fun, practical bikes such as the KTM 950 SM languish on the sales floor. To me, this just doesnít feel right.
So year after year, the more innovative manufacturers do their best to create bikes that will titillate the riding public. However the companies are undoubtedly aware that they must temper their enthusiasm with the knowledge that motorcyclists are, in general, a stodgy lot who pay lip service to the new and exciting while spending their money on the old and familiar. A case in point is the Ducati Hypermotard. This was one of the most anticipated bikes of the decade, with both the press and the public clamouring to see one in the flesh. I have yet to spot one on the street, and thatís a shame because itís possibly the most entertaining bike Iíve ever ridden, and if I hadnít bought my KTM I have no doubt Iíd now be astride a Hypermotard.
So what's stopping people from buying bikes such as Yamaha's excellent MT-01 or KTM's Supermoto? Is it tradition? Is it expense (for I'm intimately aware that these bikes do command a premium compared to the more mainstream competition), or just plain closed-mindedness? Far be it for me to say that people are buying the wrong bikes. A motorcycle is a luxury item, especially here in Canada where they're little more than storage headaches for almost half the year. So you should feel free to buy whatever bike juices your lizard, and hey -- feel free to tell me to mind my own business. But next time you're considering buying a new bike, I urge you to take a good, long look around and think outside the box, because there are more than a few innovative, exciting bikes out there that deserve your attention.
Here at Inside Motorcycles weíd like to publicly applaud those manufacturers who are willing to innovate and take the commensurate risks. Rest assured weíll do our best to keep you informed about whatís new and exciting, and you can also be sure that Iíll continue to put my own money where my mouth is.
doctor_big is offline   Reply With Quote
Old 05-25-2009, 05:33 PM   #1691
never2old4fun
never2old4fun's Avatar
Oddometer: 483
Great artical about a great bike.
never2old4fun is offline   Reply With Quote
Old 05-26-2009, 03:52 AM   #1692
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,467
Brilliant, Dr. Big!
Someone really needs to start a KTM 950 SM Owners Club...and this needs to be required reading.
Actually that may be a cool thing. Kinda like this thread, but with all the information and wisdom doled out through the years in an easily accessible format. There's a metric ton of good information in this massive thread, but it's buried and hard to get to. That's a shame.
Old 05-26-2009, 12:43 PM   #1693
delusion39
delusion39's Avatar
Oddometer: 21
Anyone try to fit a 160 rear on their 950 SM? Not sure what that would do to the handling balance and from my brief research, I think you'd need to install a narrower rim. Thoughts? Obviously this would be done to open up more tire options.
delusion39 is offline   Reply With Quote
Old 05-26-2009, 01:56 PM   #1694
mayner
Postal
mayner's Avatar
Oddometer: 146
Got my Lower Frame Sliders, Fork/Axle Sliders, Swingarm Sliders, and KTM SM Tankbag today. Took me all of 30 minutes to put it all on.
What's next?
2012 Honda CRF250L
Old 05-26-2009, 04:00 PM   #1695
900rider
Oddometer: 645
Turbo kit.
900rider is offline   Reply With Quote
Times are GMT -7.   It's 05:19 PM.
