Old 08-16-2011, 01:04 PM   #6046
Milar
Life is an adventure.
Milar's Avatar
Oddometer: 355
I did a quick search of the thread, but didn't turn up what I need, so thought I'd tap the wisdom of this list.
The starter torque limiter is starting to fail on my '06. The clacking is getting worse. I called the dealer who said he'd never heard of the problem. But "bring her in, we'll replace the starter."
Something tells me the fix isn't to replace the starter.
1. Is there a service bulletin I could refer the service manager to?
2. Is there a list of parts that need to be replaced?
Thanks for your thoughts!
M
Ridin' and writin'
Milar is offline   Reply With Quote
Old 08-16-2011, 01:29 PM   #6047
big_sur
Tarded
big_sur's Avatar
Oddometer: 710
M
Tech bulletin- http://cpmodem.smugmug.com/gallery/2...676_rwT6L-A-LB
I usually check out http://www.ktm950.info/ when I'm hunting for this kind of stuff. More often than not, they have everything I could possibly want to know there.
big_sur is offline   Reply With Quote
Old 08-16-2011, 01:50 PM   #6048
Navaho
Navaho's Avatar
Oddometer: 1,042
Originally Posted by KHVol View Post
Talk to NAttymo and Aeronaut...have spent a ton of time and money on getting it right..
What can be done to take the harshness out of the shock. Mine has been revalved twice. Each time he lessened the high speed compression and focused on plushness. Preload is 10mm. Still using WP valves. Still a bit harsh.
Fork revalve and new SKF seals helped the front a lot but not half as nice as my last bike.
Anyone know what weight the '06 950SM is sprung for. I'm 160. I wonder if the shock spring is too stiff?
'07 450EXC, '06 950 Supermoto, '09 YZ450F
Navaho screwed with this post 08-16-2011 at 03:52 PM
Navaho is offline   Reply With Quote
Old 08-16-2011, 02:42 PM   #6049
nattyMo
Oddometer: 569
Replied
Check your inbox.
NM
Originally Posted by Thumper996 View Post
NAttymo and Aeronaut, i sent you both a PM with some questions if you have time to respond i would greatly appreciate it.
nattyMo is offline   Reply With Quote
Old 08-16-2011, 03:21 PM   #6050
Thumper996
Thumper996's Avatar
Oddometer: 592
Originally Posted by snowhawk jockey View Post
Thumper996, That is a nice engine guard. I wish it had been around years ago to help my pipes... They are easily scrapped/flattened as you just found!
Do you have a pic of the scrub mark on the skid? Show us that trophy.
Here you go, hit the ground twice onfhast paced roller hills with enough air time to drop the skid plate over 6 inches to the ground. Yikes,
Thumper996 is offline   Reply With Quote
Old 08-16-2011, 03:46 PM   #6051
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,115
Nice pic...
Worth the price of admission, right there!
I don't know if your pipes would have felt that one, but now you know they didn't!!
snowhawk jockey is offline   Reply With Quote
Old 08-16-2011, 06:07 PM   #6052
Thumper996
Thumper996's Avatar
Oddometer: 592
For clarification this was on asphalt
Old 08-16-2011, 07:08 PM   #6053
900rider
Oddometer: 644
My oil sight tube is starting to split up top :(
12,000 miles
Gonna try some rc car fuel line. Wish me luck.
900rider is offline   Reply With Quote
Old 08-16-2011, 07:15 PM   #6054
aeronaut
Oddometer: 420
Originally Posted by nattyMo View Post
Check your inbox.
NM
Ditto.
aeronaut is offline   Reply With Quote
Old 08-16-2011, 07:17 PM   #6055
aeronaut
Oddometer: 420
Yea, at 160, you're springs are likely a bit stiff. STILL, I doubt that's the root problem. With 8" of travel, our springs are no where the rate of the springs on a 4" travel sport bike. But first, Who's revalving your shock? And, what are you static and rider sag numbers?
Old 08-16-2011, 07:17 PM   #6056
aeronaut
Oddometer: 420
12,000 miles
That's what I went too...the yellow stuff, but I can't see through it after 5k mi.
Old 08-16-2011, 07:26 PM   #6057
Thumper996
Thumper996's Avatar
Oddometer: 592
I got rid of mine and went with and adv dip stick
Old 08-16-2011, 07:36 PM   #6058
900rider
Oddometer: 644
This is my backup plan
Old 08-16-2011, 07:38 PM   #6059
snowhawk jockey
Slack Jaw Gaper
Oddometer: 1,115
Does the Adv stick work unmodified? I need to get my alternative lined up since I don't expect my tube to last.
Old 08-16-2011, 09:17 PM   #6060
Navaho
Navaho's Avatar
Oddometer: 1,042
Local RaceTech guy.
Shock:
Static = 23mm (11%)
Race = 53 mm (25%)
preload 10mm
Forks:
Static = 52mm (26%)
Race = 63mm (32%)
preload = 0mm
Times are GMT -7.   It's 12:06 PM.
