Old 10-21-2011, 01:53 PM   #6316
aeronaut
Oddometer: 421
Hey guys, remind me, stock chain size and length? 17/41 are stock sprockets, correct? (950SM)
Ok, a little searching reveals 525 x 120 links, and 17/41 sprockets as stock. If someone can confirm, I need to buy! :)
aeronaut screwed with this post 10-21-2011 at 02:06 PM
aeronaut is offline   Reply With Quote
Old 10-21-2011, 02:13 PM   #6317
nattyMo
Oddometer: 571
Hey Aero,
Yes 17/41 are stock w/525 120 link chain.
Here's what I'm running:
http://www.ktm-parts.com/mm5/merchan...e=D18525VM2120
http://www.ktm-parts.com/mm5/merchan...de=60033129016
http://www.ktm-parts.com/mm5/merchan...=6111005104104
NM
nattyMo is offline   Reply With Quote
Old 10-21-2011, 02:28 PM   #6318
aeronaut
Oddometer: 421
Thanks Natty, looks like a good setup. I'll either go with that, or I'm thinking about a VM2 kit with AFAM sprockets from sprocket center for $200.
http://www.sprocketcenter.com/p/3991...oto-06-09.html
Old 10-21-2011, 04:03 PM   #6319
Willis
Don't want a pickle...
Willis's Avatar
Oddometer: 618
If anyone wants a spare radiator for their SMR. I have a brand spanking new one for $200.
07 KTM 990 SUPERMOTO R
09 APRILIA TUONO FACTORY
Willis is offline   Reply With Quote
Old 10-21-2011, 04:58 PM   #6320
EMPTYHEADTECH
Oddometer: 4
Question
Hey guys- great thread- lots of good info!
I've got an 06 thats new to me about a month ago. 1100 miles and all stock from what I can see. I noticed today while the bike was warning up that the exhaust pipe off the rear cylinder got cherry red. The the rest of the exhaust looked normal. Went for a short ride- bike ran normal- went I got off it was red in the same spot and the fan was kicking on with 4 bars on the temp gauge. Should I be concerned?
Please advise....
EMPTYHEADTECH is offline   Reply With Quote
Old 10-21-2011, 05:50 PM   #6321
900rider
Oddometer: 644
I've had that happen at idle with the choke all the way on.
If this is happening without the choke on I'd say you've got quite the lean condition happening.
900rider is offline   Reply With Quote
Old 10-21-2011, 07:27 PM   #6322
imxz28
imxz28's Avatar
Oddometer: 20
I agree with 900rider, and will add to the point... These are high compression engines with a moderately agressive cam. It's perfectly normal. I wouldn't be concerned.
imxz28 is offline   Reply With Quote
Old 10-21-2011, 08:07 PM   #6323
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 3,010
Please advise....
I'd gut that puppy of her pipes and miles of hose restrictions ASAP though. My bike felt liberated once complete.
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 10-21-2011, 09:12 PM   #6324
Willis
Willis's Avatar
Oddometer: 618
4-5 bars is normal if you get above that your starting to over heat.
Old 10-22-2011, 03:23 AM   #6325
EMPTYHEADTECH
Oddometer: 4
Pissed red pipes
Thanks guys. Pleasant weather is getting scarce here in the North East; I plan on removing the evap can when I put it up for the winter and eventually the SAS when I can scrape up enough cheddar for some new cans. Right now I can't stop riding it long enough to mess with it.
Again- great thread fellas, I really appreciate the input.
Old 10-22-2011, 01:39 PM   #6326
9secondsflat
Oddometer: 302
9secondsflat screwed with this post 04-06-2012 at 05:50 AM
9secondsflat is offline   Reply With Quote
Old 10-22-2011, 05:00 PM   #6327
KHVol
Oddometer: 2,473
Originally Posted by 9secondsflat View Post
Just purchased last week an 07 950 Supermoto...8500 miles 99% condition, included a KTM tank bag ,heated vest and Motorex synthetic oil...total cost $5,000.00.
You better go into hiding....stealing is a felony............welcome, you won't be disappointed.
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization"
KHVol is offline   Reply With Quote
Old 10-23-2011, 07:28 PM   #6328
omnivore
SuperSportTourer
omnivore's Avatar
Oddometer: 1,013
Welcome 9 sec......you stole that bike!! How do you go about gettting 40% discount? LOL
XR200R
KTM 950SM
CBR Fireblade-GTU Endurance racebike
1996 YZF 600-Lost Era racebike
1999 R6-Rookie Challenge racebike
omnivore is offline   Reply With Quote
Old 10-23-2011, 09:51 PM   #6329
goodcat8
goodcat8's Avatar
Oddometer: 3,010
Reminder, when bleeding your clutch, make sure to put the little runner boot/gasket from the resevoir back on facing the right direction. I put mine on backwards.....which I found out on top of a mnt 40 miles from the nearest town tonight. We popped the cover, spun it and we're able to get enough pressure at the lever to work me up to 4th gear. Which got me home. Got air in the lines and will need to re-bleed with unicorn blood, I mean Magura Blood tomorrow.
Old 10-24-2011, 07:19 AM   #6330
Garry
Old and In The Way
Garry's Avatar
Oddometer: 1,244
I had a clutch issue this weekend while on a 3 day trip to WV. The bike wouldn't downshift coming into my gas stop at Franklin, WV. After gassing up, it seemed OK again, so I headed north for Petersburg. Bike shifted OK for a bit, then the clutch lever went totally soft. So I made it to Petersburg, jammed a couple downshifts to poke through town (hit the light green even) and stopped in a Sheetz.
Sure enough, the clutch reservoir was way low and I had managed to get air in the line. Sigh. No place to get Magura unicorn blood on a Sunday, so I recalled that people have suggested using lightweight fork oil (no joy on a Sunday) or ATF. So I bought a quart of ATF and flushed/bled the system right there in the Sheetz parking lot. Clutch felt great, so I continued home with no issues.
After I got home, I googled around a bit and found many people recommend using ATF over the Magura blood because it has good lever feel, is cheap and readily available if needed, and won't hurt the engine if some was to leak into the engine oil.
I don't know where my clutch fluid went, but I did just install an Evoluzione slave cylinder a few weeks ago. I've put 2K miles on it without issue, but perhaps I had tiny leak at the bango bolt or something. I hope the slave seal is good (since it's brand new), but if not, it comes with spares. So I'll keep a close eye on the fluid level and watch for any leaks or minor changes in clutch lever feel.
So that's something to remember if you find yourself needing clutch fluid in the middle of BFE...
As an aside, I turned over 43K miles on the SMR this weekend. The SMR now has more miles on it than my previous high mileage bike, a 2002 Triumph Sprint RS that I put 42,968 miles on. Can't think of a bike that I would replace the SMR with, so it'll get a lot of mid-life preventative maintenance this winter, and I'm just going to keep putting the miles on.
2007 KTM 950 SM-R
2009 KTM 530 EXC
http://www.MotoRoads.net
Garry screwed with this post 10-24-2011 at 07:25 AM
Garry is offline   Reply With Quote
Times are GMT -7.   It's 05:27 AM.
