Old 12-21-2011, 01:44 PM   #6526
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 3,007
Tiny little bastard.
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 12-21-2011, 06:08 PM   #6527
Just Bob
Been There Done That
Just Bob's Avatar
Oddometer: 261
Fantastic! Now you can get rid of those tractor tires and spoon on some dual compound donuts. "But dear, I had to. No way is it safe to ride on that damaged tire".
Or not...
Keep it under 130mph and you'll probably be okay.
________________________________
Confidence is the feeling you have before you understand the situation.
Just Bob is offline   Reply With Quote
Old 12-21-2011, 06:10 PM   #6528
goodcat8
goodcat8's Avatar
Oddometer: 3,007
I love those tires. Won't run anything on my 950 other than.
Old 12-21-2011, 10:30 PM   #6529
goodcat8
goodcat8's Avatar
Oddometer: 3,007
I bought a replacement rear from rocky mountain ATV, for $133 which was $20 lower than the shop I was on the phone with would go (even though they'll "beat any price")their tire was still $20 more. And the rocky mnt tire shipped an hour after I ordered!
Then a buddy said, why don't ya just patch the tire?
Anyone done that? Makes me nervouse, but would be a hell of a lot cheaper....
Old 12-22-2011, 05:07 AM   #6530
KHVol
Oddometer: 2,471
I have applied them many times to the inside of a tubeless car tire and a couple of times to dirtbike rears, never had any problems but don't know that I would do that to my SM tire...
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization"
KHVol is offline   Reply With Quote
Old 12-22-2011, 05:15 AM   #6531
900rider
Oddometer: 644
I've patched bike tires before and lived to tell the tale.
Id use one of those mushroom shaped plugs that install from the inside. They're better and safer (and can't come out) than a tar strip style plug.
Patch it. You'll be fine.
900rider is offline   Reply With Quote
Old 12-22-2011, 07:16 AM   #6532
wpbarlow OP
Oddometer: 10,877
Plugs on the meat/center of the tire are fine. I've run many thousands of miles on a few plugged tires. I've always used the strip type applied from the outside.
Just for grins, if you decide to plug the tire, when the time comes to eventually replace the tire, try to pull the plug out from either side.
wpbarlow is offline   Reply With Quote
Old 12-23-2011, 07:27 AM   #6533
aeronaut
Oddometer: 421
Ditto, I've plugged many, never had a problem. Tire companies, shops, and insurance companies love to have you believe you'll DIE if you use a plug.
aeronaut is offline   Reply With Quote
Old 12-23-2011, 10:36 AM   #6534
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Yup, I picked up a nail at the end of September in my rear Scorpion Sync that was less than halfway done. I plugged it, it was in a similar spot your nail was, almost dead center on one of the meaty sections. I got a plug kit form auto zone for about $6,tar strip type, punched in fro
m outside, it took like 2 minutes to fix it right at the gas station (it was only losing air slowly with the nail in maybe 2 lbs loss over a week), I've put at least 4,000 more miles on it since plugging it.
Some guys will scream "oh my god that isn't safe, you MUST REPLACE IT!!" etc etc, but these days $6 or $140, I'm good with the $6. I did it once before on my 1200 Bandit. I picked up a nail in a month old tire, plugged it and ran it out till it needed replacement.
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 12-23-2011, 12:48 PM   #6535
goodcat8
goodcat8's Avatar
Oddometer: 3,007
I too like $6bucks.
Old 12-23-2011, 11:35 PM   #6536
daveknievel
daveknievel's Avatar
Oddometer: 689
I worked at a kawi shop, and i would take good tires with nails in them(that customers would buy new ones), use a plug patch from the inside and either use them on my own bike,or sell for 50 bucks. they can be dangerous if the steel belt is compromised.
daveknievel is offline   Reply With Quote
Old 12-24-2011, 04:17 PM   #6537
KTMmiker
Moto Junkie
KTMmiker's Avatar
Oddometer: 143
Plug Away
In that location, center tread, I would plug er up and ride it till it was gone. Sidewall would be different, especially if it bulged under proper inflation pressure. But to ride it to safety or the shop.... patch it baby!
07 Tiger 1050
KTM 950 SM (Frost heave ride)
Past Flings: 08 990 Adventure, 05 Tiger, 03 Caponord ,02 Aprilia Futura , O8 Guzzi 1200 Sport , 08 Speed Triple, 02 Falco, 07 Tiger, 04 Sprint RS, 2000 VFR (Pretec), 00 KTM 640e, Bonnevilles and Tbird's (Triples)
KTMmiker is online now   Reply With Quote
Old 12-24-2011, 06:54 PM   #6538
goodcat8
goodcat8's Avatar
Oddometer: 3,007
Noticed this on my bikes warm up today. Little oil spits out of the pipes after cold start. Thoughts?
Old 12-24-2011, 08:35 PM   #6539
900rider
Oddometer: 644
Where's your oil level at?
You sure its actually oil and not just dirty water droplets?
Old 12-24-2011, 08:52 PM   #6540
renogeorge
Oddometer: 1,382
Ride
I think you should go for a good long ride......
renogeorge is offline   Reply With Quote
Times are GMT -7.   It's 10:21 PM.
