Old 02-25-2012, 02:30 PM   #6766
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,738
That chain looks bad ass natty.
2012 Triumph Bonneville
2006 Suzuki Vstrom
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is online now   Reply With Quote
Old 02-25-2012, 03:00 PM   #6767
KHVol
Oddometer: 2,078
Originally Posted by nattyMo View Post
Running the 16/41 combo. Very happy with the performance, 6th is usable at near legal highway speeds. Went a touch showy on the chain 525 DID.
Like the sprocket and black swing arm, still thinking about the chain, cleanest 950 I've ever seen
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization"
KHVol screwed with this post 02-25-2012 at 04:56 PM
KHVol is offline   Reply With Quote
Old 02-25-2012, 09:37 PM   #6768
omnivore
SuperSportTourer
omnivore's Avatar
Oddometer: 1,005
I got me an EK orange chain...gonna paint sprocket black.
Made the switch to 16T front sprocket, and was more pleased with gearing. I wonder if a 15 up front would be even better? Or a 44 out back instead.
XR200R
KTM 950SM
CBR Fireblade-GTU Endurance racebike
1996 YZF 600-Lost Era racebike
1999 R6-Rookie Challenge racebike
omnivore is offline   Reply With Quote
Old 02-26-2012, 04:51 PM   #6769
wpbarlow OP
Oddometer: 7,887
Originally Posted by KHVol View Post
... cleanest 950 I've ever seen
Yeah, disgusting, ain't it
Walter Barlow
wpbarlow is online now   Reply With Quote
Old 02-27-2012, 10:13 AM   #6770
Navin
Unwounding
Navin's Avatar
Oddometer: 4,326
It is.
Navin is offline   Reply With Quote
Old 02-27-2012, 11:12 AM   #6771
nattyMo
Oddometer: 562
That old pic was taken back during the dark days of my recovery. Had a too much time for bike cleaning and I wasn't ridding. Admittedly it's still pretty darn clean, just not totally disgusting any more.
nattyMo is offline   Reply With Quote
Old 02-27-2012, 04:47 PM   #6772
BuckMoto
Adventure Napping
BuckMoto's Avatar
Oddometer: 239
I would recommend the 15 tooth front. That would allow you to switch between the 16 and 15 with only a chain adjustment. You would probably need more links if you went with the 44 rear. The 15 is a hoot and the bike feels 20lbs lighter with it. I've never been to Deals Gap like you you have been doing, but from watching videos, you would probably feel less beat up at the end of the day with a 15! I don't know if you ever get to use much of 6th gear on those days, so you probably wouldn't miss the bigger front sprocket.
-Buck
BuckMoto is offline   Reply With Quote
Old 02-27-2012, 05:46 PM   #6773
omnivore
SuperSportTourer
omnivore's Avatar
Oddometer: 1,005
I almost never break 90 mph on the KTM...feels like I am gonna blow off anyways at that speed,LOL. Much different than the litrebikes I was riding before that aren't even breathing hard at 150!
Maybe I will order up a 15 as well. I have heard that the smaller the front sprocket you use, the more strain on output shaft bearings, but my bike tech assures me that on any bike, as long as I stay 15T or bigger, it should be a non issue.
And I am dying to orderup a set of TKC's now....so a 15T would be a good gear to use on trails/fire roads etc too
XR200R
KTM 950SM
Old 02-27-2012, 07:07 PM   #6774
Navin
Unwounding
Navin's Avatar
Oddometer: 4,326
It runs like a bull to 100 MPH with 15/41 or 16/44. Great gear combo.
Old 02-27-2012, 09:11 PM   #6775
BuckMoto
Adventure Napping
BuckMoto's Avatar
Oddometer: 239
Hi Navin
Thanks for turning me on to the 15 tooth countershaft a while back. I can't think of any other $29 purchase that has had as dramatic an effect or been so much fun!
-Buck
Old 02-27-2012, 09:46 PM   #6776
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 5,987
That chain looks too tight to me. Might want to check for proper adjustment/slack.
Old 02-28-2012, 07:45 PM   #6777
Navin
Unwounding
Navin's Avatar
Oddometer: 4,326
Originally Posted by BuckMoto View Post
Hi Navin
The gearing is as hard a sell as the 9.0 clutch master. Both are awesome, almost nobody will try them. I'm glad you like it, mine will never see taller cogs again. The bike is a riot with the right gears.
Old 02-28-2012, 08:07 PM   #6778
Thumper996
Thumper996's Avatar
Oddometer: 506
SPS Suspension
Well guys after a year plus of wanting to get my forks and shock tuned for my sportriding nature and weight i pulled the trigger and sent it all to SPS in California.
My requests were valving more geared toward sport asphalt riding than the soft ADV/SE valving that's in there from KTM and re-spring as needed. i also asked for them to drop the length 20mm on both ends.
Well got the good news today, my suspension is on its way back with the requested setup and new custom cut fork springs to fit the shorted length and .74kg/mm. They also fixed the shock rebound adjustment that was corroded internally and would not turn at all. As well they replaced the other normal wear seals and bushings and the rebound needles on the forks as they to had corroded due to moisture and lack of lubrication from KTM.
I will report on the feel and ride once i get them back and installed in a week or so.
Thumper996 is offline   Reply With Quote
Old 02-28-2012, 08:41 PM   #6779
omnivore
SuperSportTourer
omnivore's Avatar
Oddometer: 1,005
Keep us posted....Also really interested in the length shortening. DId you ask for shock to be shortened 20mm or seat height to be 20mm lower?
Most bikes have shock angles and or linkages nearing 3:1 ratio...so a 20mm shorter shock would lower seat height about 60mm ish.
Being 5'4" with a 29" inseam, I may need to go Corbin seat and shortened shock, and then figure a way to raise footpegs and try to adjust foot controls accordingly...already dragging pegs on sport touring rubber at stock ride height....lowered will become worse.
XR200R
KTM 950SM
Old 02-28-2012, 08:56 PM   #6780
Thumper996
Thumper996's Avatar
Oddometer: 506
Yep both ends, i have a 30" in seam myself and i got tired of the seat height and peg dragging a year ago. Searched and searched on mods and finally made my own mods with some hardware for other bikes. I also dumped the Renazco seat that came with my bike (too damn tall) and had a stock seat reworked and lowered by Sargent. All being considered the stock suspension is way to soft for sport riding and by stiffing it up with springs and valving the peg dragging will be limited even more as the bike will not compress as much in the turns.
here are some old pics of the seat and peg mods.
Thumper996 screwed with this post 02-28-2012 at 09:02 PM
Times are GMT -7.   It's 12:41 AM.
