05-17-2012, 08:22 PM
#7261 | |
Oddometer: 508
What kind of mileage are you getting now? |
05-18-2012, 08:53 AM
#7262 | |
Isn't that dangerous?
Oddometer: 1,222
I'll keep you posted on the BMC though. My torque limiter replacement did provide a cure for the clakety clack on startup though. I don't remember the bike ever starting so quietly.
EastSideSM: '06 950SM Black, '01 Honda RC51 |
05-18-2012, 10:16 AM
#7263 | |
Adventure Napping
Oddometer: 239
I have Leos, stock air filter and the SAS blocked off but have decided to keep the cannister. My thought is that all the ethanol they're putting in gas is known to absorb water out of the air and venting through the charcoal may block the moisture. I don't ride to work during the week and can't get out every weekend so contamination from moisture is more of a possibility. Don't know if this is wrongful thinking though.
-Buck |
05-18-2012, 01:26 PM
#7264 |
Oddometer: 7,886
33,199 (S)miles
Seems like a long time since I posted mileage. Mainly because it has been
. Between it needing tires, a chain/sprockets, seat redo, water pump redo and the radiator repair in succession, a rainy week; the new bike; and some SE dirt riding; there just wasn't a whole lot of time to ride it: except that I was missing it.Glad to say it's still a fun ride and kick-ass bike ![]() I like the result: tires (Pilot Road 3), sprocket set (16/41), and seat work (Butt Buffer in Pa.). Crappy tag picture from today's 150 miler.
Walter Barlow |
05-18-2012, 04:33 PM
#7265 |
Old and In The Way
Oddometer: 1,082
Any suggestions on how to hold the water pump impeller still so that I can remove the bolt holding it onto the shaft? Obviously I do not have the special KTM tool. I saw the homemade one in the HOW, but I have no metal stock laying around to attempt that with. I tried using channel lock pliers, but couldn't get the bolt to break loose. That sucker is on there. I would like to get the repair done this weekend rather than wait for a one-use tool to arrive from KTM.
EDIT: Got the bolt out, case off, and am cleaning old gasket off. Haven't tried to swap the seal, shaft, etc yet. There was a big blob of beige goo in the clutch cover, so I guess that is proof that I have a leaky seal. Garry screwed with this post 05-19-2012 at 04:56 AM |
05-18-2012, 06:18 PM
#7266 |
SuperSportTourer
Oddometer: 1,004
Walter...can I get some pics of that seat? Is it any lower than stock?
XR200R KTM 950SM CBR Fireblade-GTU Endurance racebike 1996 YZF 600-Lost Era racebike 1999 R6-Rookie Challenge racebike |
05-18-2012, 06:21 PM
#7267 | |
Oddometer: 429
i'll give the 16T a try when it's time to swap my chain/sprockets. is anyone else getting better mileage with the 16T..? |
05-19-2012, 05:17 AM
#7268 |
Oddometer: 7,886
Glad to see you got it out. My friend had the tool, so I would have been of no help.
Walter Barlow |
05-19-2012, 05:20 AM
#7269 | |
Oddometer: 7,886
![]() Seat height is pretty much the same. I guess it can be lower if needed- higher as well with a different cover.
Walter Barlow |
05-20-2012, 11:35 AM
#7270 | |
Oddometer: 17
windscreen
hi walter, you are on this forum since the beginning, so maybe you can help me.
i have read a link for a screen, not colored which can be used with all the bike. If you don't know, can you tell me how can make a research of link on this forum and a research of picture too. thank you for your answer. Quote:
05-20-2012, 02:23 PM
#7271 | |
Old and In The Way
Oddometer: 1,082
Here you go: Laminar Lip tall screen for the KTM 950 supermoto. Tall, clear screen that mounts to the headlight mask with 3M "dots". I have a smoked version: http://www.laminarlip.com/supermoto.php |
05-21-2012, 05:51 AM
#7272 |
I am smiling
Oddometer: 105
H2W jet kit should get you 38-40mpg.
Dave '06 950 SM '01 1150 GS '96 KLR 650 '88 ZX-10 |
05-21-2012, 10:30 AM
#7273 | |
Oddometer: 7,886
The screen I have (from Hyde Racin) is no longer available. Sorry.
Walter Barlow |
05-22-2012, 07:44 AM
#7274 |
Ok fellas, I'm in!
Nurettin |
05-22-2012, 08:04 AM
#7275 |
Oddometer: 2,078
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization" |
