Old 05-22-2012, 10:03 AM   #7276
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Originally Posted by duroturk View Post
Ok fellas, I'm in!
Welcome!!!!!
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 05-22-2012, 11:35 AM   #7277
BuckMoto
Adventure Napping
BuckMoto's Avatar
Oddometer: 319
Ok fellas, I'm in!
Let the good time roll!
-Buck
BuckMoto is offline   Reply With Quote
Old 05-22-2012, 11:58 AM   #7278
karviet
Oddometer: 28
THANK YOU , do you like your screen? is it easy to install ? What about protection? I wonder to put one or install a wind screen on the handlbars . In fact, it s for riding with my wife . It s for the comfort.
Originally Posted by Garry View Post
Here you go: Laminar Lip tall screen for the KTM 950 supermoto. Tall, clear screen that mounts to the headlight mask with 3M "dots". I have a smoked version:
http://www.laminarlip.com/supermoto.php
karviet is offline   Reply With Quote
Old 05-22-2012, 12:04 PM   #7279
karviet
Oddometer: 28
thank
Thank you, for the answer.
I try to find some plastic parts.
The bike i bought,
slid on the two sides.
i can t find some plastic part for ou supermoto in france,
except the ktm parts of course.
Do you know a company which make some plastic parts for our bike ?
Originally Posted by wpbarlow View Post
The screen I have (from Hyde Racin) is no longer available. Sorry.
Old 05-22-2012, 03:58 PM   #7280
nattyMo
Oddometer: 570
Here in the US, aftermarket carbon fiber is cheaper than some of the KTM plastic (front mask and fenders excluded). I have replaced most of my stock plastic parts with carbon parts from these guys:
http://hfcarbon.de/index.php?main_pa...e8b81c90b50a89
Frank at HF is excellent to deal with.
Good luck! and welcome,
NM
The bike i bought,
nattyMo screwed with this post 05-22-2012 at 04:04 PM
nattyMo is offline   Reply With Quote
Old 05-22-2012, 04:12 PM   #7281
Just Bob
Been There Done That
Just Bob's Avatar
Oddometer: 257
Handlebar risers for sale in flea market.
http://www.advrider.com/forums/showthread.php?t=793254
________________________________
Confidence is the feeling you have before you understand the situation.
Just Bob is offline   Reply With Quote
Old 05-22-2012, 05:50 PM   #7282
Garry
Old and In The Way
Garry's Avatar
Oddometer: 1,222
Yes, I like the screen. I've had it on the bike for over 40K miles. No complaints. It keeps the windblast off my body, but doesn't cause wind buffeting on my helmet (probably adds some wind noise). It installs using adhesive double-stick "dots". They are very strong and easy to install. I've done several track days with the windscreen and it stays put. It mounts to the headlight mask, not the bars.
2007 KTM 950 SM-R
2009 KTM 530 EXC
http://www.MotoRoads.net
Garry is offline   Reply With Quote
Old 05-22-2012, 06:54 PM   #7283
Garry
Old and In The Way
Garry's Avatar
Oddometer: 1,222
Slowly doing my water pump rebuild this week. Everything is fighting me because the parts have been on there for so long. Gasket stuck to cases. Seal stuck in place (pushing it out via the shaft didn't work). The "special" washer behind the impeller was stuck to the shaft. The old impeller broke while removing the bolt. Good thing the rebuild kit includes all new parts...
A few water pump rebuild action shots:
Bad juju: that tan milky goo inside the clutch cover is a bad sign...
Old shaft (w/ 45K miles on it) vs new shaft:
2007 KTM 950 SM-R
2009 KTM 530 EXC
Old 05-23-2012, 09:40 AM   #7284
nattyMo
Oddometer: 570
Good to see you're well on the way to getting the pump seal replaced Garry. Sorry to hear it's putting up a bit of a fight, mine did as well. Guess you're happy you didn't try to do the job prior to you last long ride after all.
Old 05-23-2012, 12:15 PM   #7285
karviet
Oddometer: 28
plastic
thank you for the link !
NM
Old 05-23-2012, 02:50 PM   #7286
BuckMoto
Adventure Napping
BuckMoto's Avatar
Oddometer: 319
Hi Garry,
Was your bike making any more noise than the usual LC8 ruckus before you took it apart?
-Buck
Old 05-23-2012, 04:22 PM   #7287
Garry
Old and In The Way
Garry's Avatar
Oddometer: 1,222
Originally Posted by BuckMoto View Post
Hi Garry,
Nope. The bike sounded and ran perfectly normal. I noticed the oil filter wasn't perfectly pleated on the last two oil changes, so I figured it was time. And the fact that I have 45K miles on the original shaft/seal and the replacement parts have been sitting on the shelf for two years.
2007 KTM 950 SM-R
2009 KTM 530 EXC
Old 05-23-2012, 06:28 PM   #7288
Garry
Old and In The Way
Garry's Avatar
Oddometer: 1,222
RE: Water Pump Rebuild
I got the old bearings out and the new bearings installed. So what do I use to lube the seal and shaft for reassembly? The HOW says "silicon grease". Advance Auto doesn't have it, but I think (in retrospect) they have something called P-80 seal lube. I have water proof high temp wheel bearing grease, and a tube of lithium grease. Is either of those appropriate or do I have to go shopping?
2007 KTM 950 SM-R
2009 KTM 530 EXC
Old 05-23-2012, 06:47 PM   #7289
nattyMo
Oddometer: 570
I used Dielectric grease per Pyndon's guide here:
http://www.ktm950.info/how/Orange%20...ater_pump.html
http://www.acehardware.com/product/i...ductId=3506555
Be VERY careful to press the seal in evenly, be sure not to drive it in at an angle.
Good luck!
NM
Old 05-23-2012, 06:52 PM   #7290
Garry
Old and In The Way
Garry's Avatar
Oddometer: 1,222
Good luck!
NM
So that dielectric "Tune Up" grease is "silicone grease" per the Pyndon how to? I couldn't find anything called "silicone grease", but I did see a tube of the Tune Up grease on the rack.
2007 KTM 950 SM-R
2009 KTM 530 EXC
Times are GMT -7.   It's 05:43 AM.
