09-07-2012, 06:42 PM
#7636 |
SuperSportTourer
Oddometer: 1,004
Hey y'all. The SMT has the same chassis as the 950 SM no?
Think this would work? http://www.ktm-parts.com/62112955033.html
XR200R KTM 950SM CBR Fireblade-GTU Endurance racebike 1996 YZF 600-Lost Era racebike 1999 R6-Rookie Challenge racebike |
09-07-2012, 06:45 PM
#7637 | |
Adventure Napping
Oddometer: 239
Bailing wire & duct tape
You could start a whole rat rod supermoto trend with bailing wire and duct tape farkles! I saw this bike at a car show several years ago. The dryer vent exhaust is a nice touch!![]() ![]() ![]()
-Buck |
09-07-2012, 08:22 PM
#7638 | |
Oddometer: 2,076
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization" |
09-07-2012, 09:02 PM
#7639 |
Oddometer: 43
Here is an old picture of the splash guard. The picture is not very good and i had to chop it a bit since but you get the idea. You can also see it in the pics i posted previously. A couple of things you need to do:
1. Cut off about 5mm from the sides because it rubs on the swingarm. (this is important. Not seen in picture) 2. Make a bracket for the chain guard. I used a piece of PEHD plastic to bend an L-shaped piece. 3. Bolt on the splashguard. If you are lazy just use self tapping screws I made the holes through and put on proper bolts. Very easy and cheap after all! As for the oiltank and underbelly there is the KTM/SW-motech "skidplate" you can get. It's expencive though at something like 200€. And the design is somewhat suspicious. It's listed for the 990 but i'm 95% certain it'd fit the 950 as well. Can't think of a reason why it wouldn't http://www.ktmtwins.com/ktm-990-supe...o-t-skid-plate I made a skidplate myself of 10mm PEHD plastic. It's not pretty but neither am i The thing that some people forget is that a supermoto is supposed to be able to go offroad. the 950/990 SM (not SMT/SMR) have a suspension travel of 200/210mm (front/back) and a standard version adventure has 210/210. So in that respect the only difference is the valving. Other then that it's just making sure things don't break when going offroad (skidplate. headers, .splash guard...). And yes ofcourse the wheel dimensions. Spoked 19/17 wheels would be optimal i think But running the 17/17 is just biasing it to the pavement.
09-07-2012, 09:28 PM
#7640 | |
Oddometer: 43
The suspension travel is different. The 950 SM manual says it has a travel of 200/210 and the SMT has only 160/180. So it might not work.Or if it does it'll drop the bike a lot more then that 25mm. |
09-07-2012, 09:37 PM
#7641 |
SuperSportTourer
Oddometer: 1,004
Great. I want 2" of drop!!
I am 5'4" with a 29" inseam. I used ratchet straps to figure out what I would like for seat height....and at 2" lower than stock I find the bike much more manageable. The height it is now, while right foot is tippy toe, I can't even get near the sidestand to put it up. I have to hop up on the bike, and while it's balanced straight up, quickly drop my left leg and sweep the sidestand up, and hurry to get a foot down before I tip over. Here is a pic to demonstrate just how short I am on it: ![]() I think once I get it as low as I am willing to go, I will have to chop off the pegs and weld them on higher up. I already drag the pegs when riding in the mountains now, even on Bridgestone 023's. When I forst got the bike it was alot more of an issue. Now I am just used to it the way it is. I am certain it is amusing for others to watch though,LOL. I do however, find two uppping dreadful. Not while riding, it's just the 30 seconds while the passenger gets on. I have such little footing that any "off" movements the passenger makes while getting on, off, or even at a stoplight could have me dropping the bike. Funny thing is that hasn't happened yet, but I don't ride 2 up much on it either. I would like to start doing more bad pavement, gravel, backroads, and abandoned places int he future, and I think better footing would help. If I sacrfice a little cornering prowess in doing so, oh well, that's what my racebikes are for.
09-07-2012, 10:05 PM
#7642 |
Oddometer: 43
Have you thought about getting your seat lowered? Or did you already do that? If i recall correctly at least on the 990 versions for example the KTM gel seat is 25mm lower then the stock. If you are already used to the height, lowering the seat might just do the trick without compromising the handling. If you haven't done that i'd look into that first. There are some special lowered seats available (seatconsepts at least ?).
09-07-2012, 10:12 PM
#7643 |
SuperSportTourer
Oddometer: 1,004
Problem is that the stock seat pan is so high that you can't take much foam out. I think I will get a Corbin, which is supposed to be 3/4" lower than stock, but everyone else who does seats tells me they can't do much with the stock seat and keep it comfy. I don't do short rides. Ever. Minimum, one full day....prefer a weekend to a week. Bike's gotta be comfy.
The SMT seat will not fit onto an SM. Different tank, spoilers, tail etc. I wish it would. I test rode the SMT at Indy and loved the seat....didn't like the FI though, not nearly as smooth as the 950's carbs.
09-08-2012, 04:31 AM
#7644 |
Oddometer: 7,884
I'm not 100% positive, but I think the SMT is based on the SE chassis. Not sure how that might change things.
Walter Barlow |
09-08-2012, 07:49 AM
#7645 |
R.I.P. Party Boss
Oddometer: 3,477
Omnivore -
First, Vario makes a footrest "system" that allows 360 degree adjustment and the drop can be controlled with 23mm, 30mm or 50mm adapters. Second, The first aftermarket seat I bought for my SMR was a Corbin. It wasn't much more comfortable than the stock seat. And, while it was 1/2" or so lower, it was also wider and there was absolutely no difference in reach. I'm 5'5" and have a 29" inseam. Third: I lowered my 950 Adventure 2" front and back and the only handling problem I saw was dragging the foot pegs. If anything, it handled better and the suspension had the same travel as my SMR. Which by the way, has the same suspension as the SM. The only KTM Supermoto with shorter legs is the SMT. I spoke to half a dozen suspension shops and they all said that if both ends were lowered at the same time there would be no loss in handling other than that the bike would turn a little quicker. I only had the Adv up to 105 and it was rock solid.
Mike - "For those who fight for it life has a flavor the protected never know." USMC 65-68 RVN 66-67 |
09-08-2012, 10:48 AM
#7646 | |
Oddometer: 43
My thought was that for the 990 sm there used to be a gel seat available that was the same as the stock only with gel instead of foam making it (if i recall 25mm lower). The aftermarket seats are usually made very comfortable and therefore wider as well. The stock with gel inside would be narrow, at least as comfortable as the stock and a bit lower. I'm sure someone has tried that and can say something about it. Honestly i'm dreaming of longer suspension travel and a higher bike so i shouldn't say anything about lowering a bike |
09-08-2012, 01:00 PM
#7647 |
R.I.P. Party Boss
Oddometer: 3,477
I should have added to the seat comments:
When I had my SMR I tried Corbin - 1/2" lower but wider; Renazco - 1/2" lower but nearly as uncomfortable as the stock seat; Bill Meyer - 1/2" lower but wider and outstanding comfort. I've ridden 500 miles in a day and only got off the bike to pee. I have a Russell on my Beemer right now and the Bill Meyer was every bit as comfortable as the Russell.
09-08-2012, 05:53 PM
#7648 | |
Oddometer: 2,076
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization" KHVol screwed with this post 09-09-2012 at 02:25 AM |
09-09-2012, 02:01 PM
#7649 | |
Adventure Napping
Oddometer: 239
-Buck |
09-09-2012, 04:09 PM
#7650 | |||
Slack Jaw Gaper
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 744
Thanks muchly!! Quote:
![]() edit to add: Don't forget to order fork seals if you get the lowering kit!
KTM 950 SliderMoto with 19/17 spokes, FCR41's, 2-into-1 high pipe, single side front brake and handcut flattrack style tires. Gettin Slideways is good! justin@giantloopmoto.com www.giantloopmoto.com snowhawk jockey screwed with this post 09-09-2012 at 04:39 PM |
