Old 10-04-2012, 01:48 PM   #7771
BuckMoto
Adventure Napping
BuckMoto's Avatar
Oddometer: 321
Hey! How's your aspen?
Greetings from Colorado
-Buck
BuckMoto is offline   Reply With Quote
Old 10-04-2012, 03:08 PM   #7772
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,124
Good thing ya got all that hair hanging off your front tire! Those aspen leaves look pretty deep Aspenz r just goin from yellow to brown on the tree in the yard last weekend.
snowhawk jockey is offline   Reply With Quote
Old 10-04-2012, 03:10 PM   #7773
snowhawk jockey
Slack Jaw Gaper
Oddometer: 1,124
Corndog67 just got us the skinny on the FMF's for an SM...
I fixt between the arrows >...<
Originally Posted by corndog67 View Post
OK, just got off the phone with Mike from FMF technical department. They are the same >as the Adventure and SE< .
We're really cooking now.
edit to add
To be more accurate, he didn't mention the SE, just that the Adventure and the SM use the same part numbers. I guess FMF it is. ln about 2 weeks.
snowhawk jockey screwed with this post 10-04-2012 at 10:11 PM
Old 10-04-2012, 07:37 PM   #7774
KHVol
Oddometer: 2,476
Nice..where are you riding ?
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization"
KHVol is offline   Reply With Quote
Old 10-04-2012, 09:04 PM   #7775
preppypyro
preppypyro's Avatar
Oddometer: 578
Originally Posted by EastSideSM View Post
For me it was really bad fuel economy, rough running and hard starting. It got so bad that the bike wouldn't run at all, but it was something I didn't notice while it was happening, until it had gotten well past the rough /hard running/starting.
I also had an exhaust leak so I'm not sure which of those conditions was causing the really poor fuel economy.
Thanks for the reply. Mine is getting a tad harder to start somedays, and I often wonder if its in need of a carb sync.I get pretty good economy though, 43 mpg average so far. Over the winter I plan to remove the canister shit, (install tkc 80s, dr beans fuel pump mod, new clutch slave, check valves and finish my skid plate) and I was thinking maybe I should clean and sync the carbs up as well. Couldnt hurt I guess!
Where are you guys getting your 525 15 tooth sprocket? I wanna try one!
preppypyro is offline   Reply With Quote
Old 10-04-2012, 10:03 PM   #7776
corndog67
Oddometer: 1,281
corndog67 is offline   Reply With Quote
Old 10-05-2012, 02:02 AM   #7777
karviet
Oddometer: 28
Tires
Tank you ! I find André shore with another personn Who wants.
Originally Posted by samppa2005 View Post
In France you can get them for cheap from http://www.mynetmoto.com/
That's where i got them from.
To the 180/55
http://www.mynetmoto.com/motorradrei...radreifen.html
and 120/70
karviet is offline   Reply With Quote
Old 10-05-2012, 09:29 AM   #7778
Garry
Old and In The Way
Garry's Avatar
Oddometer: 1,262
After putting new rubber on the SMR this morning, I checked the wheel bearings before balancing the wheels. One of the rear wheel bearings is going bad. No complaints after 51K miles. I ordered two bearings and will have the local shop put them in as you need $300 worth of special gear puller/bearing pullers for the job. So no 950 for a week while waiting for the parts to come in. Hopefully it's good to go for next weekend.
2007 KTM 950 SM-R
2009 KTM 530 EXC
http://www.MotoRoads.net
Garry is offline   Reply With Quote
Old 10-05-2012, 09:38 AM   #7779
900rider
Oddometer: 645
Garry are you still running the Mobile 1 synthetic car oil in your 950?
5 star's giving me shit for not running the motor(ipoff)ex oil they sell for $70 a gallon
900rider is offline   Reply With Quote
Old 10-05-2012, 11:53 AM   #7780
Garry
Old and In The Way
Garry's Avatar
Oddometer: 1,262
Yes, I've been running Mobil 1 15W-50 for the entire life of the bike. I have used the Rotella synthetic in the winter because it's a little lighter. The only time the bike ever got Motorex was when the shop (Euro Moto in Wexford) did the service.
2007 KTM 950 SM-R
2009 KTM 530 EXC
Old 10-05-2012, 11:57 AM   #7781
900rider
Oddometer: 645
Cool. I've been doing the same and plan to continue doing so.
Nice to read some confirmation it won't self destruct if car oil touches it
Im at a hair under 16,000 on my 07 SMR and it's been treating me fairly well. Most of my trouble has been carb or battery related. Or fuel pump
Old 10-05-2012, 11:59 AM   #7782
snowhawk jockey
Slack Jaw Gaper
Oddometer: 1,124
The fellas at your shop aren't as networked as you are. Don't worry, they would run Mobil1, too, if they hung out with cool guys like us!
Edit to add:
Rotella for me
Old 10-05-2012, 12:03 PM   #7783
BuckMoto
Adventure Napping
BuckMoto's Avatar
Oddometer: 321
This was on trail 717 west of Westcreek. Had to turn around at a tangled off-camber root section a little ways further. Here's another pic on a nearby ridge.
I'm working with a spotty iPhone connection, so the pic may not post...
-Buck
Old 10-05-2012, 12:15 PM   #7784
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Other possible hard starting issues:
When my battery was heading south and it was harder to start the bike, once a new one was installed, it would fire right up.
I had an issue with the carbs (previous to them being out of sync) The rear carb would work its way off the intake a bit so that I was not getting a good seal. I make sure to occasionally open up the airbox and see that the carbs are seated all the way. I think the vibes on the bike will make them work themselves off over time.
These bikes are extremely sensitive to vacuum leaks. I now run the SAS block off plates, but previously one of the caps had fallen off the remaining plumbing and caused some running issues till it was plugged back up. ( My cannister and most of the plumbing was removed the first month or two I had the bike.)
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 10-05-2012, 04:48 PM   #7785
geoffh
Oddometer: 64
Originally Posted by Navin View Post
Nobody ever wants to believe it!
Geoff, did ya hit 50k miles yet? That was the pace you were on last I heard!
Working on it, almost 26k now!
geoffh is offline   Reply With Quote
Times are GMT -7.   It's 02:24 PM.
