10-11-2012, 04:35 PM
#7831 | |
Hall Monitor
Oddometer: 8,225
http://www.advrider.com/forums/showp...postcount=7728 I've started with beer. Gonna try that first.
"Hard Work Often Pays Off After Time, but Laziness Always Pays Off Now." ![]() Big Apple Tag-o-Rama Maps: Click Here! |
10-11-2012, 04:59 PM
#7832 |
Oddometer: 511
Does it use those rubber nut things that squish as they get tighter?
10-11-2012, 05:27 PM
#7833 |
Oddometer: 554
10-11-2012, 05:30 PM
#7834 | |
Oddometer: 554
You only need to unplug the headlamp the other wires stay connected. You'll need a stubby phillips screw driver to remove the screws from the plastic side plates other then that it was pretty easy for me. Didn't try it while I was drinking though.
Good luck. Quote:
10-11-2012, 05:47 PM
#7835 |
Oddometer: 511
Hold the screen up to the bike, mark the holes with a Sharpie, remove screen, drill holes, install rubber squishy things, instal screen.
That's how it went for me at least. |
10-11-2012, 06:05 PM
#7836 |
SuperSportTourer
Oddometer: 1,005
There are a number of bikes with a 5.5" rear wheel that came OEM with a 190/50 rear tire.
Ducati 999 is one of them. Anyhow, I have a 190/50 on my 950SM...I found the handling quite nervouse with a 180/55 on it while towing my sungle wheeled trailer, so I switched to a 190/50 instead. Overal rolling circumference is almost identical and it cause less than 2km speedo change at highway speed, but the flatter profile made the bike much more stable while towing the trailer with it, at the cost of some flickability. But I find the OEM geometry of the 950SM so incredibly nervous that the switch to a slower turning tire didn't make it hard to ride at all. In fact, even with the 190/50 on there I can still ride it as hard as I dare with very little effort compared to supersport bikes.
XR200R KTM 950SM CBR Fireblade-GTU Endurance racebike 1996 YZF 600-Lost Era racebike 1999 R6-Rookie Challenge racebike |
10-11-2012, 07:52 PM
#7837 |
Oddometer: 462
10-12-2012, 03:43 AM
#7838 |
Hall Monitor
Oddometer: 8,225
Installed!
Alright! Mission windscreen complete!
Here's a photo journal of the process, with my awesome and pithy comments: http://www.flickr.com/photos/jerlbau...978844/detail/ The answer to the question is, to get the front fairing off the cowling, you have to remove the instrument panel first! Unscrew the four Phillips screws, and then you can access the two side screws which hold the front fairing on: ![]() ![]() Remember to use all your specialty tools! ![]() After some drilling and screwing: ![]() ![]()
10-12-2012, 09:28 AM
#7839 | |
Isn't that dangerous?
Oddometer: 1,222
EastSideSM: '06 950SM Black, '01 Honda RC51 |
10-12-2012, 09:31 AM
#7840 | |
Slack Jaw Gaper
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 750
Correct, the stock exhaust from a >950< ADV would bolt right on to the heads. Since the ADV has a longer subframe, the y-pipe mounts are a distance from the SM subframe holes, so I bolted on a hanger bracket/extension to carry the pipe. I got a 990 exhaust, thinking they would be the same, not so. The routing is the same, but the flanges at the head were not the same size, 990 flange too big. So, a little cutting and welding of my flanges onto the the 990 system and yup, we got high pipes. I also cut and shaped the "y" into a 2-1. Cutting the flange off my stock exhaust can and welding it onto a Termignani Ducati muffler with slip fit muffler mount, let me bolt it right up. ![]() So that is the story of my high pipes. WORD OF CAUTION: I wanted the 2005.5 and newer headers since they have a long heat shield, at the frame. An additional heat shield must be added onto the straight section, where it passes over the clutch and waterpump. It is a pants burner and I do mean *instant death* to pants...
KTM 950 SliderMoto with 19/17 spokes, FCR41's, 2-into-1 high pipe, single side front brake and handcut flattrack style tires. Gettin Slideways is good! justin@giantloopmoto.com www.giantloopmoto.com |
10-13-2012, 06:01 AM
#7841 |
Oddometer: 554
10-13-2012, 01:16 PM
#7842 |
Adventure Napping
Oddometer: 238
Hello from the trails!
So sad- have to go back home tomorrow..
![]() Pike's Peak earlier today..
-Buck |
10-13-2012, 01:49 PM
#7843 |
Slack Jaw Gaper
Oddometer: 750
Buck that is some lovely landscape ya are rolling through, there.
My BIL's GreatUncle Zeb would be happy to see "his" hill getting a fresh dust o'snow. SPEAKING OF SNOW!!! snow is a good reminder for me to get my shxt organized for my winterization projects...
10-15-2012, 06:49 AM
#7844 |
Hall Monitor
Oddometer: 8,225
Scotts Oil Filter
How many of you installed the Scotts (Scott's?) oil filter?:
http://www.ktmtwins.com/scotts-ktm-9...lc8-oil-filter ![]() I'm planning my first oil change for the next couple weeks or so, so I'm wondering if I should just install one now.
10-15-2012, 08:34 AM
#7845 | |
Oddometer: 1,222
