Old 11-08-2012, 06:48 PM   #7966
Thumper996
Thumper996's Avatar
Oddometer: 593
Lowered Suspension
Well after lowering the bike (SPS did the work) last winter and riding it all year i have to say i enjoy the 950SM much better now. The bike just handles better with correct springs and valving for sport riding and the lowering just adds to it. I grunted after spending so much $$$$ on the suspension re-work, but it was worth every $.
Bike just leans and turns so much better and i find i am dragging knee all over the place that i didn't before. If you are thinking about a winter project and you haven't put any $$ into suspension i would recommend it.
Thumper996 is offline   Reply With Quote
Old 11-09-2012, 07:09 PM   #7967
omnivore
SuperSportTourer
omnivore's Avatar
Oddometer: 1,013
How much did you have it lowered?
How much shorter is the shock now?
Did the shock and the forks get lowered internally, or did you just slide the forks thru the triples to match the new rear ride height?
SPS ( is Superlush?)
Is it neccessary to do valving etc? Or will they simply do the lowering and leave valving alone. I find that all out suspension performance is rally wasted on my street bikes. Even at stock height, riding like a maniac on Bridgestone 023's, dragging knee from VA to TN, I can't outride the stock suspension. I think the valving is good enough for what I do with it.....and I don't plan to race or trackday the KTM so all out performance isn't that important to me....for that I have racebikes. I would rather just have it lowered and ride it.
What was the damage if you don't mind me asking?
XR200R
KTM 950SM
CBR Fireblade-GTU Endurance racebike
1996 YZF 600-Lost Era racebike
1999 R6-Rookie Challenge racebike
omnivore is offline   Reply With Quote
Old 11-09-2012, 07:31 PM   #7968
Thumper996
Thumper996's Avatar
Oddometer: 593
My biggest complaint was height (30 inch inseam) and bike wallowing in higher speed turns. Front end seemed to want to push out in tight technical turns. All were prior to getting work done. Yes SPS is SuperPlush and i chose to have mine revalved to tighten up the bikes travel and lowered internally. Forks are back at the normal position on the triple trees.
I don't have my notes with me at this moment, but i seem to recall i lowered the forks and shock about 3/4 to 1". Rear spring was fine and re-useable, but forks required custom cut shorted spring for my weight (200 lbs) and both ends were re-valved.
It's not cheap, but i was close to selling the bike due to the suspension. It's now closer to a SuperDuke than and SM. I raised the pegs as well.
Old 11-09-2012, 09:31 PM   #7969
renogeorge
Oddometer: 1,424
Lowering
I shortened the shock to yield 1 1/2" lowering. Used stock spring no revalving. Just slid forks up in clamps about 1/2" to balance out the front. I went a little stiffer on the front springs for my weight and to reduce dive when breaking--not due to the lowering. I also removed a shim from the from the valve stack to lighten the dampening up a little. I am about 190#. I have been very happy with this set up
FWIW.
renogeorge is offline   Reply With Quote
Old 11-12-2012, 04:10 AM   #7970
gkaan
Bikes on the Brain
gkaan's Avatar
Oddometer: 505
950 SM carbon fibre wheels
im selling my 950 SM carbon fibre wheels in flea market. best perfromance upgrade you can do to your SM.
gkaan is offline   Reply With Quote
Old 11-12-2012, 04:48 AM   #7971
900rider
Oddometer: 645
Can't find your fs post
Link?
900rider is offline   Reply With Quote
Old 11-12-2012, 12:00 PM   #7972
BuckMoto
Adventure Napping
BuckMoto's Avatar
Oddometer: 321
Ooooh! Nice wheels gkaan!
Here's another video from Colorado. More pavement this time.
http://www.youtube.com/watch?v=9v9NF5rtf4Y
-Buck
BuckMoto is offline   Reply With Quote
Old 11-12-2012, 02:20 PM   #7973
gkaan
Bikes on the Brain
gkaan's Avatar
Oddometer: 505
http://advrider.com/forums/showthread.php?t=840507
Link?
Old 11-12-2012, 06:27 PM   #7974
nattyMo
Oddometer: 573
New Ducati HyperMotard...
Interesting?
http://www.ducatiusa.com/bikes/hyper...otard/index.do
nattyMo is offline   Reply With Quote
Old 11-12-2012, 06:30 PM   #7975
nattyMo
Oddometer: 573
Originally Posted by gkaan View Post
Nice looking set of wheels. Wish I had the cash, good luck with the sale.
NM
Old 11-12-2012, 06:46 PM   #7976
KHVol
Oddometer: 2,476
Interesting?
Look at the Hyperstrada...a KTM 950/990 SM/T dupe in every way
http://www.ducatiusa.com/bikes/hypermotard/hyperstrada/index.do
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization"
KHVol is offline   Reply With Quote
Old 11-12-2012, 09:12 PM   #7977
Thumper996
Thumper996's Avatar
Oddometer: 593
SuperDuke 1190
This should be a beast
http://www.asphaltandrubber.com/news...uke-spy-photo/
Single sided swingarm
Edit correction 1290 cc 150 HP
Old 11-13-2012, 06:49 AM   #7978
wpbarlow OP
Oddometer: 11,257
Worth a picture
wpbarlow is offline   Reply With Quote
Old 11-13-2012, 07:24 AM   #7979
wiseblood
Hall Monitor
wiseblood's Avatar
Oddometer: 13,269
http://hellforleathermagazine.com/20...a-180hp-naked/
"Hard Work Often Pays Off After Time, but Laziness Always Pays Off Now."
Big Apple Tag-o-Rama Maps: Click Here!
wiseblood is offline   Reply With Quote
Old 11-13-2012, 01:53 PM   #7980
nattyMo
Oddometer: 573
I wonder if those forks will make it onto a production SD1290 here in the US... Looks very sweet to my eye.
Times are GMT -7.   It's 02:29 PM.
