Old 01-13-2013, 06:25 PM   #8161
ridemorestressless
ridemorestressless's Avatar
Oddometer: 47
Originally Posted by Thumper996 View Post
Well as i am down until March re-habing from knee surgery, i thought it was a good time to check the valves. Bought the bike with 5k on it and the PO had the original post break in valve check done. I have put about 15k on it myself, so got this far today. Anyone know if the HotCam Crf450R shims are the same size.
Where did you get the mounts and upper frame sliders?
Is that a 950sm?
ridemorestressless is offline   Reply With Quote
Old 01-13-2013, 06:39 PM   #8162
Thumper996
Thumper996's Avatar
Oddometer: 506
Originally Posted by mcmann View Post
Thanks, I have two HotCams kits already for the CRF250R and the CRF450R. I will measure them and see if either is 10 mm. The CRF450 shims are 9.48mm, so I wonder if they will work.
Thumper996 is offline   Reply With Quote
Old 01-13-2013, 06:47 PM   #8163
Thumper996
Thumper996's Avatar
Oddometer: 506
Nope they won't work. Dang it.
Old 01-13-2013, 06:49 PM   #8164
Thumper996
Thumper996's Avatar
Oddometer: 506
Is that a 950sm?
Mounts, you mean foot pegs?
I am going all black and will be pulling the upper Orange frame sliders as well as front and rear Orange axle sliders in the near future for resale.
Old 01-13-2013, 08:31 PM   #8165
ridemorestressless
Oddometer: 47
I meant the method of attatching those upper frame sliders by mount. I have looked but can't find 950sm upper frame sliders anywhere. I would also prefer black sliders. Thanks.
Old 01-13-2013, 08:43 PM   #8166
preppypyro
preppypyro's Avatar
Oddometer: 457
Valve adjustment, never done one on my ktm yet either.
Is it pretty tough to do for you guys that have done them? Im going to be doing a ton of work on my bike next month ish, and I should probably check the valve adjustment while I have everything torn down.
Looks alot more complicated then the ones on my xt600 haha.
preppypyro is offline   Reply With Quote
Old 01-13-2013, 08:47 PM   #8167
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 3,493
Follow the procedure in the "HOW". It isn't really difficult, just a bit time consuming. It's easier on the SM/SMR than an Adventure.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is online now   Reply With Quote
Old 01-13-2013, 09:01 PM   #8168
preppypyro
preppypyro's Avatar
Oddometer: 457
Time I have haha. Ill have to order a valve shim kit and check it out. Sure would like to have my bike running 100 percent tip top this summer!
Old 01-13-2013, 09:33 PM   #8169
ridemorestressless
Oddometer: 47
valves
where is a good how to on checking valves?
Old 01-14-2013, 04:28 AM   #8170
cnw126
Oddometer: 103
http://www.ktm950.info/how/Orange%20...djustment.html
I am in the middle of doing this for the first time. So far so good.
cnw126 is offline   Reply With Quote
Old 01-14-2013, 06:21 AM   #8171
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 3,493
There is an EXCEL shim calculator in there (or PM me with your email and I'll send it to you) that makes determining the correct shim a piece of cake.
Mike -
Old 01-14-2013, 09:42 AM   #8172
KHVol
Oddometer: 2,078
it sat for a gew months before I bought it. I put 1500 miles on after jetting and she ran great. I was out of town for 10 months and she sat. no stabilozer or any prep. Fuel tank was almost empty . I added gumout, fuel injector carb cleaner and filled up. I have run about a 1/4 tank of that.
any suggestions on other addives?
will turning the air fuel mixture screw in or out help with the constant backfiring under constant throttle.
Hey Ridemore, The problem with backfiring is due the bike sitting up so long. The adjustments were right before it sat up and should be right now.
It does not take long for sitting gas to gum up the jets. I have usually been able to just run the bike with Sea Foam or something similar and get it eventually cleaned out (except for a VFR which sat for 2 years.)
You may have to take the carbs off and clean the jets, nothing major. (I thought I had really screwed mine up when that happened but it cleaned out after several minutes)
Good luck.
Keith
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization"
KHVol screwed with this post 01-14-2013 at 03:30 PM
KHVol is offline   Reply With Quote
Old 01-14-2013, 01:36 PM   #8173
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,738
KTM bring the heat.
http://www.asphaltandrubber.com/news/ktm-sales-2012/
2012 Triumph Bonneville
2006 Suzuki Vstrom
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 01-14-2013, 01:44 PM   #8174
KHVol
Oddometer: 2,078
Originally Posted by goodcat8 View Post
I can easily see myself owning another KTM. So far, after a lotta years of riding, my former 950 SM is the most enjoyable motorcycle I have ever owned ( XR650R is second) . The new ones are supposed to be $20,000 + which will be a stretch.... I have unfortunately not seen anything about an 1190 SM.
KHVol screwed with this post 01-14-2013 at 03:29 PM
Old 01-14-2013, 02:32 PM   #8175
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 3,493
From what I've read so far, the new 1190 Adventure is closer to an SM than an Adventure and that's what I am shooting for.
Now the new 1290 Super Duke should be a whole other ball game!
Mike -
Times are GMT -7.   It's 06:15 AM.
